    change export filename
    4 Posts 2 Posters 2.2k Views 2 Watching
    • D Offline
      dgm
      hello ,
      I have enabled the export on my serialChart. I would like to change the filename that mango assigns to the download and appears at bottom left in the download tab . (ex. "mangoChart 37" change to "my filename 38")
      also how to change the text at top of the column in csv report. it currently uses the xid and i have been changing that to something more relevant but was hoping to change it to the name property.
        You don't. If you want you want a means to have a custom csv download with your own naming convention you'll have to write the code for it yourself.
        • D Offline
          dgm
          Thanks MattFox,
          I was able to customize the tab name at the top of web page so I thought i'd give this a shot.
            @dgm I have an update for you.
            I am unsure if it will work in the dashboard because I write controllers to do this for me. But I revisited this for you and I have some good news:
            options="{'export': {
            				enabled: true,fileName: 'MyFilename'}}" export="true"></ma-serial-chart>
            You can override using the options attribute to set your export filename. Apologies for misleading you, I was unaware without looking at the source that the export options were as easily accessible than I had first assumed...
            However you're still stuck with that XID value.
