    Raspberry PI 3 B+ Mango and java oracle installation
    10 Posts 2 Posters 5.4k Views 2 Watching
      JF89
      I followed your tutorial to install mango on raspberry PI.
      I’m blocked whith the command prompt :
      sudo update-alternatives --install java /usr/bin/java /usr/local/java/jdk1.8.0_221/bin/java
      as you can see with the following screenshot :
      i don’t know linux , and I found on the web a syntax to declare the path for
      :/usr/local/java/jdk1.8.0_221/bin but i don’t know if it’s the good syntax.
      Here it’s what I wrote on the /etc/environment file :
      Is-it correct for the path ?
      If yes , have you got any idea of my problem ?
      I can obtain JDK as you can see in the following screenshot, but not the java version :
      Best regards
        Hi JF89,
        What precisely is your question? How to run that update alternatives command?
        Setting JAVA_HOME in the /etc/environment should be sufficient to have Mango find the java executable, and is in fact preferred in the startup scripts to resolving java from the PATH.
        I would strongly advise against assigning to the PATH variable in /etc/environment as you seem to be doing.
        Have you tried to start Mango?
          JF89
          Hello Phil,
          i have many difficulties how to use linux, and i followed your tutorial step by step.
          But I encountered the problem with the path.
          In your tutorial you said :
          Add the following to the file
          JAVA_HOME=/usr/local/java/jdk1.8.0_131
          If you have path settings add at the end of PATH following :/usr/local/java/jdk1.8.0_131/bin”
          save /etc/environment (ctrl+x)
          But the syntax is not given by the tutorial.
          So that’s why I’m lookink for help.
          With your previous comment I know now that the path is not good . But i still don’t know how to write that path in etc/environment.
          I tried to start mango with sudo ./ma.sh start command in the bin directory of mango , but mango doesn’t work
          is_it because java JRE is not answering ?
          because when I check java -version , I have no answer.
          When you install JDK, does it install in the same time JRE ?
          best regards
            JF89
            here is the screnshot of the check starting mango
              You can see in Mango/bin/ma-init.sh that it would preferentially use JAVA_HOME.
              From your error image, although i do not speak the language, I wonder if you have a /usr/bin/java and if it is executable. But, you should be able to launch Mango using only JAVA_HOME. I would add an echo into ma-init.sh to see what JAVA_HOME is when it is deciding how to find Java.
                JF89
                Hello Phil ,
                The file /usr/bin/java is present , but when i try to execute it nothings happens.
                ma-init.sh is containing already echo but i don’t know how to add one.
                As I said I don’t know how to use linux, just very few commands.
                The situation has been improved but not at all.
                I can start Mango , but it’s blocked with 5% starting
                I was unable to have the good echo when usin oracle jre 1.8.0_221
                So with the command sudo update-alternatives --config java , I choose an another version than oracle 1.8.0_221 :
                Java-8-openjdk-armhf
                ![0_1568378879190_20190913_143216.jpg](Uploading 100%)
                Now I can have a good echo for java -version
                I updated the etc/environment file with the following
                JAVA_HOME= »/usr/lib/jvm/java-8-openjdk-armhf/jre/bin/java»
                Of course there’s a problem to launch the display , because I use VNC viewer but I can see the Mango software starting when typing localhost :8080 in the webbrowser bar.
                But why Mango is blocked at 5% when starting ?
                Is-it because it’s not a oracle version of java ?
                Thanks for your help
                Best regards
                  JF89
                  Here is the screenshot of java versions available0_1568379059946_20190913_143216.jpg
                    The screenshot of launch output's stacktrace could be prevented by setting the env.properties entry web.openBrowserOnStartup=false
                    Those screenshots prove Mango has found Java and that is not the problem, as Mango is using the JAVA_HOME variable to locate Java.
                      JF89
                      Hello Phil,
                      It works now , connecting directly to the raspberry PI .
                      But the display between custom pages or settings pages takes about 3 to 5 seconds delay, and sometimes more.
                      Is-it due to the ram (only 1 gb with raspian ?)
                      With a computer core I5 8th generation 3,5 Ghz , 8 GB ram , W10 , the display between pages is less than a second.
                      Is it as fast for the MangoHTS ( 8GB RAM max ). (display between pages less than a second ?)
                      Best regards
                        The amount of memory, other things you're doing with your browser, all could affect it. I don't know specifically where the bottlenecks are in your circumstance, nor have I collected that benchmark.
