    how to make style blinking via value?
    4 Posts 3 Posters 2.1k Views 3 Watching
    • O Offline
      ozone
      I learned form the style via value example and modified for my data point. i am trying to use this to indicate status for good, warn, alarm, fault and isolate. The data point value will be 0, 1, 2, 3 and 4. Quite happy as it does change color when value changes. Below is the code I used. But the color will be all steady. I want to have steady green color only when "good" , but when alarms I wish to make it blink. Could you help what I need to code to make it blink when alarms? Thanks.
      <style>
          .default {
              background-color: black;
              color: white;
              position: absolute; left:100px; top: 200px;
              height: 30px;
              width:30px;
          .good {
              background-color: green;
          .warn {
              background-color: orange;
          .alarm {
              background-color: red;
          .fault {
              background-color: brown;
          .isolated {
              background-color: lightgrey;
      </style>
      <ma-get-point-value point-xid="DP_1ff7e5b2-2d09-4134-aaf8-305005db3483" point="myPoint"></ma-get-point-value>
      <div class="default" ng-class="{'good': myPoint.value === 0, 'warn': myPoint.value === 1, 'alarm': myPoint.value === 2, 'fault': myPoint.value === 3, 'isolated': myPoint.value === 4}">
          <ma-point-value point="myPoint"></ma-point-value>
        Hi @ozone
        using CSS animations will be you best way I believe. Here are 2 links showing you how to do it.
        https://css-tricks.com/almanac/properties/a/animation/
        https://bytutorial.com/blogs/css3/how-to-create-blinking-background-color-and-text-using-css3-animation
          @ozone There's actually a CSS class built into Mango which will make this really easy.
          Just add ma-throb-opacity to your ng-class expression.
          ng-class="{'good': myPoint.value === 0, 'warn': myPoint.value === 1, 'alarm': myPoint.value === 2, 'fault': myPoint.value === 3, 'isolated': myPoint.value === 4, 'ma-throb-opacity': myPoint.value > 0 }"
          If you want to see how it works, or modify it a bit, the CSS is supplied in this Mango example -
          /ui/examples/single-value-displays/led-indicator
          O 1 Reply Last reply Reply Quote 0
          • O Offline
            ozone @Jared Wiltshire
            @jared-wiltshire
            Thank you so much for the help. . I finally got it working using code you suggested, studied the example and modified to what I wanted. Works really well.
