    Cron pattern to copy over a USB drive
    24 Posts 3 Posters 27.8k Views 3 Watching
      sky_watcher
      This is the command and the error:
        It could be caused by the filesystem type not supporting Linux permissions. Perhaps you could reformat the drive to an ext3 or ext4 filesystem?
          sky_watcher @phildunlap
          @phildunlap I get same error in mango and the drive is formatted as ext4, is mounted and the mango user has wrights to write on the usb0 folder.
            Hi guys, just gonna give a suggestion, cd into /media/usb0/
            then do the chown again
            sudo chown mango:mango . -R
            then enter the
            ls -la
            That should give us all info for that directory to start. Skywatcher, assuming you are using putty if you highlight the text, you can then paste into here with code tags.
            You should be able to create a file just with touch file
            no sudo required
              Also ensure the mango user has at least read permissions to /media
                sky_watcher @MattFox
                @mattfox said in Cron pattern to copy over a USB drive:
                total 24
                drwxr-xr-x  3 mango mango  4096 Aug 29 14:54 .
                drwxr-xr-x 12 root  root   4096 Aug 29 11:45 ..
                drwx------  2 mango mango 16384 Aug 29 14:54 lost+found
                root@mangoES3324:/media/usb0$touch file
                root@mangoES3324:/media/usb0$la -ls
                total 16
                 0 -rw-r--r-- 1 root  root      0 Aug 29 15:22 file
                16 drwx------ 2 mango mango 16384 Aug 29 14:54 lost+found
                  You're logged in as root, you need to be the mango user if you want to test effectively, also please use those code tags, it makes a lot easier to read.
                  Edit: Thanks!
                  Ok dir permissions look good. Try doing the touch newfile as mango, if you can do that, there should be no issues with mango creating files. I'll check my server for you soon if wanted to compare configs.
                    @mattfox
                    mango@mangoES3324:/media/usb0$ls
                    file  lost+found
                    mango@mangoES3324:/media/usb0$touch newfile
                    file  lost+found  newfile
                    mango@mangoES3324:/media/usb0$ls -la
                    total 24
                    drwxr-xr-x  3 mango mango  4096 Aug 29 15:43 .
                    -rw-r--r--  1 mango mango     0 Aug 29 15:43 newfile
                      Perfect, try doing backups now with mango
                        sky_watcher
                        ok, now worked, I can use that path and my back-up was saved there.
                        Also I have a question, this feature of writing directly the location of the USB drive into the Backup Directory works only in V3? In V2.8 is it working or not?
                          @sky_watcher said in Cron pattern to copy over a USB drive:
                          Nicely Done!
                          It'll work in both instances as long as your directory permissions are set correctly. Under the hood mango V2 and V3 are still running java, V3 just has a new shiny interface.
                            sky_watcher
                            ok, Thank you a lot!
