    Cron pattern to copy over a USB drive
    24 Posts 3 Posters 28.7k Views 3 Watching
      I wouldn't think so. Did you sudo? What response did you get from running the command?
        I edited the command, as there was no reason to give the mango user access to /media/boot/
          sky_watcher
          This is the command and the error:
            It could be caused by the filesystem type not supporting Linux permissions. Perhaps you could reformat the drive to an ext3 or ext4 filesystem?
              sky_watcher @phildunlap
              @phildunlap I get same error in mango and the drive is formatted as ext4, is mounted and the mango user has wrights to write on the usb0 folder.
                Hi guys, just gonna give a suggestion, cd into /media/usb0/
                then do the chown again
                sudo chown mango:mango . -R
                then enter the
                ls -la
                That should give us all info for that directory to start. Skywatcher, assuming you are using putty if you highlight the text, you can then paste into here with code tags.
                You should be able to create a file just with touch file
                no sudo required
                  Also ensure the mango user has at least read permissions to /media
                    sky_watcher @MattFox
                    @mattfox said in Cron pattern to copy over a USB drive:
                    total 24
                    drwxr-xr-x  3 mango mango  4096 Aug 29 14:54 .
                    drwxr-xr-x 12 root  root   4096 Aug 29 11:45 ..
                    drwx------  2 mango mango 16384 Aug 29 14:54 lost+found
                    root@mangoES3324:/media/usb0$touch file
                    root@mangoES3324:/media/usb0$la -ls
                    total 16
                     0 -rw-r--r-- 1 root  root      0 Aug 29 15:22 file
                    16 drwx------ 2 mango mango 16384 Aug 29 14:54 lost+found
                      You're logged in as root, you need to be the mango user if you want to test effectively, also please use those code tags, it makes a lot easier to read.
                      Edit: Thanks!
                      Ok dir permissions look good. Try doing the touch newfile as mango, if you can do that, there should be no issues with mango creating files. I'll check my server for you soon if wanted to compare configs.
                        @mattfox
                        mango@mangoES3324:/media/usb0$ls
                        file  lost+found
                        mango@mangoES3324:/media/usb0$touch newfile
                        file  lost+found  newfile
                        mango@mangoES3324:/media/usb0$ls -la
                        total 24
                        drwxr-xr-x  3 mango mango  4096 Aug 29 15:43 .
                        -rw-r--r--  1 mango mango     0 Aug 29 15:43 newfile
                          Perfect, try doing backups now with mango
                            sky_watcher
                            ok, now worked, I can use that path and my back-up was saved there.
                            Also I have a question, this feature of writing directly the location of the USB drive into the Backup Directory works only in V3? In V2.8 is it working or not?
                              @sky_watcher said in Cron pattern to copy over a USB drive:
                              Nicely Done!
                              It'll work in both instances as long as your directory permissions are set correctly. Under the hood mango V2 and V3 are still running java, V3 just has a new shiny interface.
                                sky_watcher
                                ok, Thank you a lot!
