    SSL Installation on the mango cloud
    14 Posts 5 Posters 8.2k Views 7 Watching
      Hi Jerry
      Did you use a password when creating the keystore, not the key? The logs show Mango cannot access the keystore.
      What did you put on this line in your env.properties:
      ssl.keystore.password=morethan6characters
        JMbayo @CraigWeb
        Hi craigweb i did put : ssl.keystore.password=freetextpassword
          @jmbayo said in SSL Installation on the mango cloud:
          Caused by: java.security.UnrecoverableKeyException: Password verification failed
          Your logs show that the password is not correct. You need to first test your password on the keystore.
            this is the link i got information from: https://forum.infiniteautomation.com/topic/3725/external-ip/7
            Did you use the keytool command exactly as it appears in this thread? If so, your keystore password would likely be changei
              Jimmy Kabuya
              This post is deleted!
                I trust you got things sorted Jimmy? Welcome to message via chat as well if you have any concerns
                  Hi Jimmy
                  The process is as follows:
                  1. Create a keystore.jks to hold your keys
                  2. Import the certificate into the keystore.
                  3. Move the keystore onto your cloud server.
                  4. edit the env.properties folder to point to your keystore.
                  If any passwords were used on either the key or the certificate then add them to the env.properties file
                    Jimmy Kabuya @CraigWeb
                      @craigweb Thanks. Let me try that, will let you know how it goes.
                        JMbayo
                        Hi all; the SSL is now working on my cloud. I thought I would share the procedure and challenges encountered.
                        Step 0.
                        Buy a genuine SSL certificate
                        Step 1.
                        Generate a CSR to request a certificate from a recognised CA
                        Step 2
                        Generate a file.jks; on my case I used keystore explore to create a keystore.jks and load all my certificate in it.
                        Setp 3
                        I then imported it into my mango /opt/mango/overrides/properties
                        Challenges:
                        After all these steps, when I edited my env file to activate the SSL, my web page couldn’t be access. The issue was on my env file, I didn’t uncommented the ssl.key.password. I followed the instruction for using certbot which was not the right one for my case. The right is on support under configurationinstallation
                        1. ssl.on=true
                        2. ssl.port=443
                        3. ssl.keystore.location=[YOUR FULL MANGO PATH HERE]/overrides/keystore.jks
                        4. ssl.keystore.password=[leave empty if you didn’t use a password]
                        5. ssl.key.password=[leave empty if you didn’t use a password] (Note that this need to be uncommented as it is initially commented out)
                          Then I restarted mango, and that’s it
