    CSV with 1 minute rollup auto emailed via Meta Source
    21 Posts 3 Posters 12.4k Views 3 Watching
      MaP
      Thanks again Matt - I was hoping there was some trickery you could somehow put a escape character + concatenate time in report name input.
      Sorry if this is a little painful or covered elsewhere - I have little to no java script experience so this is all a little arcane to me. I would have expected you needed to point to the location on the file system to attach the file in an email?
        MattFox @MaP
        @map correct, but using Phil's code above:
        var emailAttachment = new com.serotonin.web.mail.EmailAttachment.ByteArrayAttachment(
          "attached.txt", "attached text".getBytes());
        Means we can be a bit more creative with the 'body' of our file. We just generate the data and turn it into a string and then apply the method above to convert it into binary.
        Want some help?
          MaP
          Help is always nice, its nice to struggle with progress but also a point where going in circles becomes painful.
          Ahh so the ByteArrayAttachment doesn't create a file on the filesystem but just creates the file on the fly in the meta source and names it "attached.txt, with "attatched text" being the content of that file?
            MattFox @MaP
            @map said in CSV with 1 minute rollup auto emailed via Meta Source:
            Cripes I know that all too well....
            Bingo! Have a cigar, or a scotch, or whatever you kick back with. I'd say you've got the right idea here.
            EDIT:
            My advice: Test with one row to start with your headers etc and ensure you're happy with the format before going full tilt rising with everything in a given date range.
              MaP
              So far so good. Query works, Email attachment works, and can seperate rows using /r/n. Not sure what variable type is returned by the query but its returned as number,number, so i presume its a string? will Need to transpose over the query to insert /r/n i believe and then construct a corresponding time array for every minute of previous 24 hours for second colomn.
              var endDate = CONTEXT.getTimestamp();
              var startDate = endDate - CONTEXT.millisInPast(MINUTE, 4); //handles DST shenanigans
              var results = [];
              var callback = function(idValueTime) {
                results.push(idValueTime);};
              var pointsToQuery = [ p341.getDataPointWrapper().getId() ];
              PointValueQuery.rollupQuery( [341], startDate, endDate, callback, AVERAGE, 1, MINUTE);
              print(results);
              var d = new Date();
              //ECMA function to convert date to locale string YYYY-MM-DD
              var datestring = d.toLocaleDateString();
              //Substr fX to make date DD-MM-YYYY time format
              var ddmmyyyy = datestring.substr(8,2)+datestring.substr(4,4)+datestring.substr(0,4);
              var CSVname = "Performance_"+ddmmyyyy+".csv";
              print(CSVname);
              var recipients = ["funtimes@live.com"];
              var emailContent = new com.serotonin.web.mail.EmailContent(null,
                "Email body content", com.serotonin.m2m2.Common.UTF8);
                "attached"+datestring+.csv", "Head1,Head2\r\n12,22".getBytes());
              emailContent.addAttachment(emailAttachment);
              com.serotonin.m2m2.rt.maint.work.EmailWorkItem.queueEmail(recipients, "Attachment test", emailContent, null);
                Note you'll want to fire the email after your callback returns so you'd be best to place it inside it otherwise you'll be firing an empty attachment.
                generateEmail(results);
                function generateEmail(res)
                var d = new Date();
                print(CSVname);
                I believe that the rolled up point value query just returns an array of all of the values only. I don't think it attached a timestamp. If you want timestamps, we'll have to go via the HTTP Request route and query the API directly to pull a rolled up point values query.
                  MaP
                  This post is deleted!
                    MaP
                    this seems to have worked i had trouble using arrays with a ,toString function where the "," was appearing in the final csv string - ie)
                    Head1,Head2
                    Val1,time1
                    ,Val2,time2
                    ,Val3,time3
                    Using Strings seems to ahve gotten the correct output but im worried a string variable might get angry when it contains 1440*7 Values/time
                    code so far --
                    //Query to Retrieve and rollup previous 24 Hours Data
                    var results = [];
                    print(results);
                    //Date and time Variables
                    var d = new Date();
                    var t = new Date().getTime();
                    var y = d.getYear()-70;
                    var m = d.getMonth();
                    var dayinmonth = d.getDate();
                    var hours = d.getHours();
                    //Creating DateTime For Array
                    // 31556926000 mS in Year
                    // 2629743000 ms in Month
                    // 86400000 ms in Day
                    //3600000 ms in an Hour
                    //print(results[0].toString()+d.toString()+"\r\n");
                    var coeff = 1000 * 60 * 1;
                    var date = new Date();
                    //var TimeAgo = new Date((Math.round((date.getTime()-(hours*3600000)) / coeff) * coeff)+index*60000);
                    //var csvData =[];
                    var csvData ="kW,Timestamp\r\n"
                    results.forEach(function(results,index){
                        //csvData[index]=results+","+TimeAgo+"\r\n";
                        csvData = csvData+results+","+TimeAgo+"\r\n";
                    //csvDataString = csvData.toString();
                    print(csvData)
                      Man you really have gone above and beyond, you're making it rather complex for what you need.
                      1. go into the user setting in the dashboard and use it to make yourself a token based bearer authentication key.
                        https://help.infiniteautomation.com/mango-rest-api-authentication
                      Next let's incorporate your timeframes into this:
                      if (!Date.prototype.toISOString) {
                        (function() {
                          function pad(number) {
                            if (number < 10) {
                              return '0' + number;
                            return number;
                          Date.prototype.toISOString = function() {
                            return this.getUTCFullYear() +
                              '-' + pad(this.getUTCMonth() + 1) +
                              '-' + pad(this.getUTCDate()) +
                              'T' + pad(this.getUTCHours()) +
                              ':' + pad(this.getUTCMinutes()) +
                              ':' + pad(this.getUTCSeconds()) +
                              '.' + (this.getUTCMilliseconds() / 1000).toFixed(3).slice(2, 5) +
                              'Z';
                      var xid = "internal_mango_uptime_hrs"; //for example this would be your context point XID
                      function GenerateEmail(data)
                          var csvStr = "kW,Timestamp\r\n";
                         for(var i=0;i<data.length; i++)
                            csvStr += data[ i ].value+","+data[ i ].timestamp+"\r\n";
                      var d = new Date();
                      var ddmmyyyy = d.getDate()+"-"+(d.getMonth()+1)+"-"+d.getFullYear();
                        "attached"+datestring+".csv", csvStr.getBytes());
                      var to = new Date( CONTEXT.getTimestamp() );
                      var from = new Date( to.valueOf() - CONTEXT.millisInPast(MINUTE, 4) );
                      var rollup="AVERAGE";
                      var rollupPeriod = "MINUTES";
                      var rollupPeriodTime = "1";
                      print(from.toISOString());
                      print(to.toISOString());
                      var _URL="http://localhost/rest/v1/point-values/"+xid+"?from="+from.toISOString()+
                      "&rollup="+rollup+"&timePeriodType="+rollupPeriod+"&timePeriods="+rollupPeriodTime+"&to="+to.toISOString();
                      //print(_URL);
                      HttpBuilder.get(_URL,
                      {"Accept":"*/*" ,
                      "Authorization":"Bearer \
                      [BEARER_TOKEN_HERE]"
                      ,{}).err(function(status, headers, content) { //setErrorCallback for linguistic completion
                      	 print(content); print(status);
                      	}).resp(function(status, headers, content) { //setResponseCallback
                      			print(status);	print(content);
                      if(content.length)
                             GenerateEmail(content); //don't generate if there are not any values
                      	}).excp(function(exception) { //setExceptionCallback
                      		//throw exception.getMessage();
                      		print(exception.getMessage() );
                      		}).execute();
                        MaP
                        updated code snippet with 3 points and a timestamp array concatenated then emailed
                        //your code here
                        var results = [];
                        //var pointsToQuery = [ p341.getDataPointWrapper().getId() ];
                        PointValueQuery.rollupQuery( [341,342,282], startDate, endDate, callback, AVERAGE, 1, MINUTE);
                        print(results);
                        var d = new Date();
                        //var csvData =[];
                        var csvData ="kW,Timestamp\r\n";
                        var TimeWatch = [];
                            TimeWatch[index]=TimeAgo;
                            if((index+1)%3<1){
                            TimeAgo = new Date((Math.round((date.getTime()-(hours*3600000)) / coeff) * coeff)+((index-2)/3)*60000);
                            else{
                                csvData = csvData+results+",";
                        print(csvData);
                        //print(TimeWatch);
                        var recipients = ["funtimes84@live.com"];
                          "PerformanceCSV"+datestring+".csv", csvDataString.getBytes());
                        com.serotonin.m2m2.rt.maint.work.EmailWorkItem.queueEmail(recipients, "NorthamCSV_"+ddmmyyyy, emailContent, null);
                          @mattfox said in CSV with 1 minute rollup auto emailed via Meta Source:
                          Not so! For the rollupQuery, while it is true that if you supply a particular rollup type the callback will be handed the simple value and the inference is left to you to add the number of rollup periods from the start time to get the nth timestamp (every period will get a callback). But, if you use a rollup of ALL the whole statistics object (AnalogStatistics object in a Numeric case) is passed to the callback: https://github.com/infiniteautomation/ma-core-public/blob/main/Core/src/com/infiniteautomation/mango/statistics/AnalogStatistics.java
                            Thanks Phil, I should have asked you about that months ago. Having no timestamp with the values turned me away from using it.
