    md-card affecting Chart render??
    6 Posts 2 Posters 1.9k Views 2 Watching
      Pikey4
      I used some of Joels example page here https://forum.infiniteautomation.com/topic/2972/help-understanding-the-use-of-md-card/6 to help with a small dashboard and I like it alot however...
      The md-card that contains the md-list seems to be causing the charts to disappear when changing changing the dates. When refreshing the browser the page loads all ok with chats working good. Only once changing the date will it cause them to disappear.
      I think it can possibly be something to do with the layout I have??/ If I delete the card that contains the list completely It works as desired, but I really like the layout with a list of the values on the left there.
      Any Suggestions??
      Thanks In advance.
      Cheers!
      code is:
      <div layout="column" layout-gt-sm="row" layout-align="space-between">
          <md-card flex="" style="margin-top: 170px;">
              <md-toolbar class="md-whiteframe-1dp md-hue-1">
          		<div class="md-toolbar-tools">
          			<h2 flex="" style="text-align: center; font-size: 26px">
          				<span>PH</span>
          			</h2>
          	</md-toolbar>
              <ma-gauge-chart point-xid="Albany_Day_HospDP_6da534b8-0df3-4964-8541-e907f0defc5e" interval="2" start="0" band-1-end="6.8" band-2-end="7.8" band-3-end="14" band-1-color="yellow" band-2-color="green" band-3-color="red" style="width:100%; height:200px;" axis-thickness="5" axis-alpha="0.2" axis-label-font-size="14" value-offset="1" value-font-size="12" tick-interval="0.25" arrow-inner-radius="15" arrow-alpha="0.8">
          </ma-gauge-chart></md-card>
          				<span>Pressure</span>
          			</h2>
          	</md-toolbar>
             <ma-gauge-chart point-xid="Albany_Day_HospDP_33855fed-e4a9-4992-85b0-cd2e575b107b" interval="" start="0" end="1000" style="width:100%; height:200px;" axis-thickness="5" axis-alpha="0.2" axis-label-font-size="14" value-offset="1" value-font-size="12" tick-interval="25" arrow-inner-radius="15" arrow-alpha="0.8">
          				<span>Free Chlorine</span>
          			</h2>
          	</md-toolbar>
              <ma-gauge-chart point-xid="Albany_Day_HospDP_a4d57eaa-c2ee-4cf6-bf1b-cd10494e8587" interval="0.1" start="0" end="1" style="width:100%; height:200px;" axis-thickness="5" axis-alpha="0.2" axis-label-font-size="14" value-offset="1" value-font-size="12" tick-interval="0.25" arrow-inner-radius="15" arrow-alpha="0.8">
          				<span>Turbidity</span>
          			</h2>
          	</md-toolbar>
          <ma-gauge-chart point-xid="Albany_Day_HospDP_06539764-88ab-48f1-94b6-4883efdc0de1" interval="0.1" start="0" end="1" style="width:100%; height:200px;" axis-thickness="5" axis-alpha="0.2" axis-label-font-size="14" value-offset="1" value-font-size="12" tick-interval="0.25" arrow-inner-radius="15" arrow-alpha="0.8">
           <!--Something wrong here??-->
      <div layout="column" layout-gt-sm="row">
          <md-card flex="100" flex-gt-sm="25">
          			<h2 flex="">
          				<span>Current Values</span>
          			</h2>
          	</md-toolbar>
              <md-list class="md-dense">
                  <md-list-item layout="">
                      <h3>Cold Pressure</h3>
                  </md-list-item>
                      Mains Incoming
                      <span flex=""></span>
                      <ma-point-value point-xid="Albany_Day_HospDP_1941e55d-4880-4f25-ab15-a9b46b5ebd2f" enable-popup="left" data-data-point-details="false"></ma-point-value>
                  </md-list-item>
                      Pressure US Pre-Treat Filter
                      <ma-point-value point-xid="Albany_Day_HospDP_ad81b12e-81c2-4d6f-900d-fa09d4bbe847" enable-popup="left" data-data-point-details="false"></ma-point-value>
                  </md-list-item>
                      Pressure DS Pre-Treat Filter
                      <ma-point-value point-xid="Albany_Day_HospDP_33855fed-e4a9-4992-85b0-cd2e575b107b" enable-popup="left" data-data-point-details="false"></ma-point-value>
                  </md-list-item>
                  <md-divider></md-divider>
                      <h3>Hot Water Pressure</h3>
                  </md-list-item>
                      PHWS Supply Pressure
                      <ma-point-value point-xid="Albany_Day_HospDP_a62a0f6d-139a-4c22-b910-48f33c22a1d1" enable-popup="left" data-data-point-details="false"></ma-point-value>
                  </md-list-item>
                      PHWS Outlet Pressure
                      <ma-point-value point-xid="Albany_Day_HospDP_2610803d-5b33-4bec-8cdf-25922890c54d" enable-popup="left" data-data-point-details="false"></ma-point-value>
                  </md-list-item>
                      NPHWS Supply Pressure
                      <ma-point-value point-xid="Albany_Day_HospDP_cd3c6e38-18ad-4a74-9449-c593f39470b6" enable-popup="left" data-data-point-details="false"></ma-point-value>
                  </md-list-item>
                      NPHWS Outlet Pressure
                      <ma-point-value point-xid="Albany_Day_HospDP_273356ac-0928-4c78-ade4-8c6d77c2aa28" enable-popup="left" data-data-point-details="false"></ma-point-value>
                  </md-list-item>
                      <h3>Temperature</h3>
                  </md-list-item>
                      PHW Outlet Temperature
                      <ma-point-value point-xid="Albany_Day_HospDP_9b37bd5b-e8e6-4d25-829d-1e7ac3205082" enable-popup="left" data-data-point-details="false"></ma-point-value>
                  </md-list-item>
                      PHW Return Temperature
                       <!-- PHW Return Pump 1 Status -->
                      <ma-point-value point-xid="Albany_Day_HospDP_1363f426-8e2d-49c6-bd5c-7f1438758910" enable-popup="left" data-data-point-details="false"></ma-point-value>
                      <!-- PHW Return Pump 2 Status -->
                      <ma-point-value point-xid="Albany_Day_HospDP_946ea23b-257f-4337-8cf1-221123bc42b1" enable-popup="left" data-data-point-details="false"></ma-point-value>
                  </md-list-item>
                      NPHW Outlet Temperature
                      <ma-point-value point-xid="Albany_Day_HospDP_054db421-f7a5-4890-a6d3-da70ca3101d6" enable-popup="left" data-data-point-details="false"></ma-point-value>
                  </md-list-item>
                      NPHW Return Temperature
                       <!-- NPHW Return Pump 1 Status -->
                      <ma-point-value point-xid="Albany_Day_HospDP_7d6edee2-b2ae-4c55-8b1e-59bc42a15b99" enable-popup="left" data-data-point-details="false"></ma-point-value>
                      <!-- NPHW Return Pump 2 Status -->
                      <ma-point-value  point-xid="Albany_Day_HospDP_c31f9a60-48eb-413e-8c50-456c9a59f25e" enable-popup="left" data-data-point-details="false"></ma-point-value>
                  </md-list-item>
              </md-list>
          </md-card>
      <md-card flex="100" flex-gt-md="75">
          			<h2 flex="">
          				<span>Charts</span>
          			</h2>
          	</md-toolbar>
              <md-card-content layout="column">
                  <div layout="row" layout-xs="column">
                      <md-input-container flex>
                      <label>Quick Dates</label>
                      <ma-date-range-picker from="from" to="to" preset="LAST_1_WEEKS" update-interval="1 minutes"></ma-date-range-picker>
                      </md-input-container>
                      <label>From date</label>
                      <ma-date-picker ng-model="from"></ma-date-picker>
                      <label>To date</label>
                      <ma-date-picker ng-model="to"></ma-date-picker>
          <!-- Fix the dodgy axis shaping when using the 3D effect -->
      <style>
          .amcharts-axis-grid {
              fill-opacity:0
      </style>
                  <h2 style="text-align: center">Water Meters</h2>
                  <ma-point-values point-xid="Albany_Day_HospDP_ID-1_CH8_Value" values="PotableHwsMeterValues" from="from" to="to" rollup="DELTA" rollup-interval="4 hours"></ma-point-values>
                  <ma-point-values point-xid="Albany_Day_HospDP_ID-1_CH7_Value" values="NonPotableHwsMeterValues" from="from" to="to" rollup="DELTA" rollup-interval="4 hours"></ma-point-values>
                  <ma-serial-chart flex="" style="height: 300px; width: 100%;" series-1-title="Potable HWS Meter" series-2-title="Non-Potable HWS Meter" series-1-values="PotableHwsMeterValues" series-2-values="NonPotableHwsMeterValues" series-1-color="rgb(18,143,35)" series-2-color="rgb(149,12,245)" series-1-type="column" series-2-type="column" series-2-axis="left-2" legend="true" balloon="true" options="{strictMinMax: true, synchronizeGrid: false,depth3D:10, angle:45, plotAreaFillAlphas:0, valueAxes:[{minimum:0, title:'Non-Pot (Kl)', axis:left}, {minimum:0, axis:right}, {minimum:0, title: 'Potable (Kl)', axis:left-2}, {minimum:0, axis:right-2}]}" graph-options="[{clustered: true},{clustered: true}]" export="true" stack-type="none">
      			</ma-serial-chart>
      			<h2 style="text-align: center">Temperatures</h2>
      			<ma-point-values point-xid="Albany_Day_HospDP_9b37bd5b-e8e6-4d25-829d-1e7ac3205082" values="PotableHwsTempValues" from="from" to="to" rollup="SIMPLIFY" auto-rollup-interval="true"></ma-point-values>
                  <ma-point-values point-xid="Albany_Day_HospDP_054db421-f7a5-4890-a6d3-da70ca3101d6" values="NonPotableHwsTempValues" from="from" to="to" rollup="SIMPLIFY" auto-rollup-interval="true"></ma-point-values>
                  <ma-serial-chart flex="" style="height: 300px; width: 100%; fill-opacity:1" series-1-title="Potable HWS Temperature" series-2-title="Non-Potable HWS Temperature" series-1-values="PotableHwsTempValues" series-2-values="NonPotableHwsTempValues" series-1-color="#ed2323" series-2-color="#e3f20e" series-1-type="smoothedLine" series-2-type="smoothedLine" series-2-axis="left" legend="true" balloon="true" options="{strictMinMax: true, synchronizeGrid: false, depth3D:20, angle:45, plotAreaFillAlphas:0,  valueAxes:[]}" graph-options="[{clustered: true},{clustered: true}]" export="true" stack-type="none">
      			</ma-serial-chart>
      			<h2 style="text-align: center">Cold Water Pressure</h2>
      			<ma-point-values point-xid="Albany_Day_HospDP_ad81b12e-81c2-4d6f-900d-fa09d4bbe847" values="CWS_US_Filtration" from="from" to="to" rollup="SIMPLIFY" auto-rollup-interval="true"></ma-point-values>
                  <ma-point-values point-xid="Albany_Day_HospDP_33855fed-e4a9-4992-85b0-cd2e575b107b" values="CWS_DS_Filtration" from="from" to="to" rollup="SIMPLIFY" auto-rollup-interval="true"></ma-point-values>
                  <ma-serial-chart flex="" style="height: 300px; width: 100%; fill-opacity:1" series-1-title="Up-Stream Pre-Filter" series-2-title="Down-Stream Pre-Filter" series-1-values="CWS_US_Filtration" series-2-values="CWS_DS_Filtration" series-1-color="#1414e0" series-2-color="#0eefb3" series-1-type="smoothedLine" series-2-type="smoothedLine" series-2-axis="left" legend="true" balloon="true" options="{strictMinMax: true, synchronizeGrid: false, depth3D:20, angle:45, valueAxes:[]}" graph-options="[{clustered: true},{clustered: true}]" export="true" stack-type="none">
      			</ma-serial-chart>
      			<h2 style="text-align: center">Hot Water Pressure</h2>
      			<ma-point-values point-xid="Albany_Day_HospDP_2610803d-5b33-4bec-8cdf-25922890c54d" values="PHWSoutPressure" from="from" to="to" rollup="SIMPLIFY" auto-rollup-interval="true"></ma-point-values>
                  <ma-point-values point-xid="Albany_Day_HospDP_273356ac-0928-4c78-ade4-8c6d77c2aa28" values="NPHWSoutPressure" from="from" to="to" rollup="SIMPLIFY" auto-rollup-interval="true"></ma-point-values>
                  <ma-serial-chart flex="" style="height: 300px; width: 100%; fill-opacity:1" series-1-title="Potable Hot Water" series-2-title="Non-Potable Hot Water" series-1-values="PHWSoutPressure" series-2-values="NPHWSoutPressure" series-1-color="#40e50d" series-2-color="#efbe0e" series-1-type="step" series-2-type="step" series-2-axis="left" legend="true" balloon="true" options="{strictMinMax: true, synchronizeGrid: false, depth3D:20, angle:45, valueAxes:[{minimum:0, maximum:1000, title:'Pressure (kPa)', axis:left}, {minimum:0, axis:right}, {minimum:0, axis:left-2}, {minimum:0, axis:right-2}]}" graph-options="[{clustered: true},{clustered: true}]" export="true" stack-type="none">
      			</ma-serial-chart>
              </md-card-content>
          </md-card>
      Mango Core version: 3.5.6
      Mango API module version: 3.5.2
      MangoUi module version: 3.5.5
      Platform: 10.14 MacOS Mojave
      Chrome: Version 70.0.3538.110 (64-bit)
        Pikey4
        Ok, so I've just discovered that grabbing the browser window and making it smaller and larger a few times brings the charts back up until I change the dates again??
        Video if required.
        https://youtu.be/01-R0y8eUhk
          I copied your code and changed all the xids to a mango internal xid and could not replicate the issue. Can you give the page some time to render and see what happens after 30 seconds? I think your point queries might be taking some time.
            Pikey4
            Thanks Craig,
            Yeah it's a bit strange, I did try leaving the page to load for over 30minutes just as a test but the only thing that gets the charts up is refresh the browser or adjusting the size of the window, both of which work instantly.
            I'll keep looking.
            Cheers!
              Try removing the flex="" from the charts and see what happens. ??
                Pikey4
                Thanks Craig, That looks like the problem, Didn't even see that there .
                Cheers!
