    User login not working?
    22 Posts 5 Posters 12.7k Views 4 Watching
      Hi Rowen,
      There's a lot going on here! I have sent you an email with the IP the DNS record is pointing to. It sounds like there's a few questions getting jumbled here.
      1. Is your PC the PC at that IP?
      2. Is that instance of Mango the cloud connect server?
      3. Is that the instance of Mango that a password change attempt was made on, or a client connected to it via cloud connect?
      4. Have you installed it as a service on this PC (it definitely sounds like you have, which is why it is running when you start the computer)?
      Whatever the resolution to those questions, this thread has probably the simplest method given access to the computer running Mango to change the password: https://forum.infiniteautomation.com/topic/2926/forget-the-password-of-admin-how-to-get-it-back
        Rowen
        Hi Phil, I went to that link to reset password. Not sure how to stop Mango. Joel installed the cloud connect for me. I found a "mango" in services on my pc and I stopped it. When I go to Mango to get into h2-web part I get the following
          Rowen @Rowen
          Sorry to seem so helpless but I'm at a loss?
          R
            Navigate to localhost:8085 if your browser and you'll have the chance to login to the H2 web console, to change the password.
              Rowen
              Hey Phil, Just a refuse to connect message?
                Rowen
                I get a refuse to connect message
                  I enumerated questions for you that were to help me understand the situation better. They are relevant to why your would not be getting a connection at localhost and should be answered, preferably clearly and in the enumerated fashion.
                  You could also try the IP it shows in the console output. But, it sounds like multiple machines are getting confused to me.
                    Rowen
                    Hi Phil,
                    1. yes this is the pc at the IP address you saw
                      2.yes this is where the cloud connect server, I believe. I had Joel set it up.
                      3.yes the change to the password was for this instance on Mango
                    2. Joel set it up, but I see Mango as a service on this pc
                      Rowen
                      I get the same refused to connect messafe using the IP address
                        Did you close the console that was running the H2 web console batch file?
                        You say PC, do you mean Windows? You should be able to connect to your own machine regardless of firewalls. If you had set up your SMTP server, you could have tried using the password reset provided through Mango. On Windows both IPv4 and IPv6 address work with the H2 web console....
                        If you have a JSON backup in your Mango/backup you could throw away the existing data and database and reimport it into a fresh installation by moving the Mango/databases directory while Mango is not running.
                        If you have an SQL backup in your Mango/backup from before your changed the password you could move the databases directory while Mango is not running and then restore this backup into a fresh installation.
