    Process Event handler to fire external script
    56 Posts 3 Posters 58.3k Views 3 Watching
      Actually yes, the JSON would be better there is still a lot of information missing.
      • K Offline
        khuang
        Yes, here is the JSON of the event handler:
           "eventHandlers":[
                 "xid":"EH_caaac4a3-6ff5-4046-8eaa-0ff5be6a6370",
                 "alias":"",
                 "handlerType":"EMAIL",
                 "eventTypes":[
                       "sourceType":"DATA_SOURCE",
                       "XID":"DS_2b8b5316-3bd1-4b4e-82d2-c5f00dbd4ba4",
                       "dataSourceEventType":"SCRIPT_ERROR"
                 "activeRecipients":[
                       "recipientType":"ADDRESS",
                       "address":"khuang@cityliftparking.com"
                 "sendEscalation":false,
                 "sendInactive":false,
                 "includeSystemInformation":true,
                 "includePointValueCount":10,
                 "includeLogfile":true,
                 "customTemplate":"",
                 "additionalContext":[
                 "script":"",
                 "scriptPermissions":{
                    "scriptDataPointReadPermission":"superadmin, user",
                    "scriptDataPointSetPermission":"superadmin, user",
                    "scriptDataSourcePermission":"superadmin, user"
                 "disabled":false
                 "xid":"EH_2d361442-9b2e-40ff-82bd-3f85c42d3480",
                 "alias":"",
                 "handlerType":"SET_POINT",
                 "eventTypes":[
                       "sourceType":"DATA_POINT",
                       "dataPointXID":"DP_d8a89826-e771-4760-ac46-9064a5e3b3d0",
                       "detectorXID":"ED_80c9adf7-f1ad-4058-a60a-05a58f53ecf6"
                 "targetPointId":"DP_41011e72-6228-4ae6-a4e3-6fdce7c45ec7",
                 "activeAction":"SCRIPT_VALUE",
                 "activeScript":"return true;",
                 "inactiveAction":"NONE",
                    "scriptDataPointReadPermission":"superadmin",
                    "scriptDataPointSetPermission":"superadmin",
                    "scriptDataSourcePermission":"superadmin"
                 "disabled":false
        @phildunlap You said that the script could get retriggered if I restarted the data source and data point, which is what I was doing. So maybe that was the cause. I was restarting the source and point because I was unable to set the ssh data point in the watch list.
        EDIT: I think I see what the problem might have been (with the lagging). When I restart the SSH data source/point, the event handler fires again and launches my script in another session and it does for each time I restart the source/point. And eventually it hoses up my entire system.
          @phildunlap said in Process Event handler to fire external script:
          Can you post the JSON for the event detector / source point?
          But no matter, the restarting of the point or source was likely the cause of resending. So, now the issue is that even using SSH you're experiencing those issues with python modules being undefined? What was that post about the Hello World text and the SSH invoking the script about? Or, is everything working now and it was melting from the multiple runs of the script?
          • K Offline
            khuang @phildunlap
            @phildunlap It was the melting from the multiple runs of the script which made it appear that the script was not working. Right now everything is working. The command in the 'set command' of my ssh datapoint is firing when the state changes to true for my source whereas it the same command was giving errors in the process event handler so the lesson learned for me is to use a set point event handler when my script uses relative paths and environmental variables.
            Only problem now is I need to be careful because each time the source goes to 1, it starts up another run of my script and with 3 of those, my system crashes. Now I just need a way to kill the process when the state changes to false.
              It's going to be related to event detector and point settings. Export the JSON for the point, we cannot see how you've got the event detector configured and point settings configured
                You can add another virtual point into the context for the set point handler, and set a value to it in the script before returning. Then in the script you do something like this,
                if( lastSet.time >= CONTEXT.getRuntime() - 15000 ) //15 seconds
                  return UNCHANGED;
                lastSet.set(!lastSet.value); //we care about times, not values, so alternate a binary
                return true;
                • K Offline
                  khuang
                  @MattFox This is the SSH data point:
                          "xid":"DP_41011e72-6228-4ae6-a4e3-6fdce7c45ec7",
                          "name":"Trigger",
                          "enabled":true,
                          "loggingType":"ON_CHANGE",
                          "purgeType":"YEARS",
                          "pointLocator":{
                             "dataType":"ALPHANUMERIC",
                             "setCommand":"\/home\/mango\/detect-start.sh",
                             "queryable":false,
                             "settable":true
                          "eventDetectors":[
                          "plotType":"STEP",
                          "rollup":"NONE",
                          "unit":"",
                          "templateXid":"Alphanumeric_Default",
                          "simplifyType":"NONE",
                          "chartColour":"red",
                          "chartRenderer":{
                             "type":"TABLE",
                             "limit":10
                          "dataSourceXid":"DS_40cb68b0-350f-4b16-b54b-5bc359cf8241",
                          "defaultCacheSize":1,
                          "deviceName":"MangoES",
                          "discardExtremeValues":false,
                          "intervalLoggingPeriod":15,
                          "purgeOverride":false,
                          "purgePeriod":1,
                          "readPermission":"",
                          "setPermission":"",
                          "tags":{
                          "textRenderer":{
                             "type":"PLAIN",
                             "useUnitAsSuffix":true,
                             "unit":"",
                             "renderedUnit":"",
                             "suffix":""
                          "tolerance":0.0
                  And here's the virtual data point that I use to trigger:
                           "xid":"DP_d8a89826-e771-4760-ac46-9064a5e3b3d0",
                           "name":"doorIsOpen",
                           "enabled":true,
                           "pointLocator":{
                              "dataType":"BINARY",
                              "changeType":{
                                 "type":"NO_CHANGE",
                                 "startValue":"True"
                              "settable":true
                           "eventDetectors":[
                                 "type":"BINARY_STATE",
                                 "xid":"ED_80c9adf7-f1ad-4058-a60a-05a58f53ecf6",
                                 "name":"",
                                 "alarmLevel":"NONE",
                                 "durationType":"SECONDS",
                                 "duration":0,
                                 "state":true
                                 "xid":"ED_915a14f9-17da-4885-9c22-a53648617c04",
                                 "name":"",
                                 "duration":0,
                                 "state":false
                           "plotType":"STEP",
                           "rollup":"NONE",
                           "unit":"",
                           "templateXid":"Binary_Default",
                           "chartColour":"blue",
                           "chartRenderer":{
                              "type":"TABLE",
                              "limit":10
                           "dataSourceXid":"DS_5d06b8ba-c91b-4c93-b594-92c5009ec67e",
                           "deviceName":"Virtual Data Source",
                           "purgePeriod":1,
                           "setPermission":"",
                           "tags":{
                           "textRenderer":{
                              "type":"BINARY",
                              "oneColour":"#ff0000",
                              "oneLabel":"one",
                              "zeroColour":"blue",
                              "zeroLabel":"zero"
                           "tolerance":0.0
                  @phildunlap What is lastSet in this case? It says lastSet is undeclared.
                    That's the variable name I gave to a binary virtual point that would be in the Set point handler's "Additional Context."
                    I guess you could in theory have issues then where you wanted the script to be invoked more than once in a fifteen second interval, but at that point you're really on the hook for specifying the logic you need very clearly. It may be easier for your script to use a lock file or some such.
                    • K Offline
                      khuang @phildunlap
                      @phildunlap Ok, I see what you mean. So if my source point has not changed for 15 seconds, I can treat it as unchanged and do something off of that.
                      For now, I just created another data point event detector for the source point to detect a state of 0. And when the state is 0, I run a process command that kills the python script. It seems to get the job done, and now when I run "top" I can see the python process going away and back as I toggle the source point.
                      Thanks for the help guys!
                        MattFox @khuang
                        @khuang said in Process Event handler to fire external script:
                        If you're having to kill the script I suggest you establish some more parameters and make it return/exit after it fires. You don't want errant scripts causing havoc in your system. Scripts should be one shots only.
                          Glad you got it figured out! Thanks Fox!
                          UNCHANGED is a special return value for email handlers, set point handlers, meta points, and point links to cancel whatever would normally occur. So no email, no value set to the target point, no value to the meta point, and no value to the target of the point link.
                            MattFox @phildunlap
                            @phildunlap Thanks to you too my man. We got to the bottom in the end. Not easy trying to work out scenarios without being there.
                            • K Offline
                              khuang @MattFox
                              @mattfox Yes, that is a good idea. I will work on thinking of a safe way to exit. My exact use case is that the script will detect people in real time and the only reason why I would want to stop this detection is if a bit flips to zero in the PLC. I was thinking that a safe way to exit could be to continuously poll the data point I want to trigger on to see if it is zero, and if it is zero I exit. However, I would have to make an API call every second. If you have any ideas, please let me know.
                                Why poll? use a datapoint that is amended via the PLC. Make it reflect the state of the PLC and use that to control your script status. It should be able to trigger the other way, not with you polling it.
                                If needs be contact me via chat and we can discuss in detail.
