    Meta Point Help
    5 Posts 4 Posters 3.0k Views 4 Watching
      Pikey4
      Trying to monitor cyclic fatigue on a small project, and can manually do it in excel but it's messy and ideally would like it data logged.
      I though the easiest way would be a meta point such as:
      if (p445.lastValue(101) > (p445.lastValue(102), (p445.lastValue(100))));
      // means the value has hit peak ??
      	return 1;
      if (p445.lastValue(101) > (p445.lastValue(102), and < (p445.lastValue(100))));
      // means the value is still climbing ??
          return 2;
      if (p445.lastValue(101) < (p445.lastValue(102), (p445.lastValue(100))));
      // means the value has hit trough ??
      	return 3;
      if (p445.lastValue(101) < (p445.lastValue(102), and > (p445.lastValue(100))));
      // means the value is still falling ??
          return 4;
      However this only returns a "1" no matter what, so I obviously have done something wrong.
      I was using "lastValue(101)", "lastValue(100)" & "lastValue(102)" only because the point is Persistent TCP (with Live updating) and I didn't want to be looking at the un-updated value. (if that makes sense). So perhaps this is part of the problem??
      Or I have gone completely the wrong way around this and I need to be looking at an alternative solution.
      Any assistance is as always greatly appreciated,
      A picture paints 1000 words:
      Cheers!
      Mango Core version: 3.5.6
      Mango API module version: 3.5.2
      MangoUi module version: 3.5.5
      Platform: 10.14 MacOS Mojave
      Chrome: Version 70.0.3538.110 (64-bit)
        Hi @Pikey4
        I believe your first if statement is short-circuiting. Your logical operators are not correct.
        eg:
        should be
        if (p445.lastValue(101) > (p445.lastValue(102) && p445.lastValue(101)>(p445.lastValue(100));
        Might help to read through this site.
        https://developer.mozilla.org/en-US/docs/Web/JavaScript/Reference/Operators/Logical_Operators
          @pikey4 said in Meta Point Help:
          I didn't understand that. Using lastValue(100) will give you the hundredth value ago. That seems strange to do, and I'm not sure what this explanation is saying. I think I may go about doing something like this by having the meta point activate on a cron and check to see if the point has been updated / sync'ed and it can loop over the values in the next time period, based off the time of the source point and the last time of the meta point.
            @Pikey4 as @CraigWeb said you have incorrect expressions inside your if statements. Try this -
            var targetIndex = 100;
            var prevVal = p445.lastValue(targetIndex - 1);
            var thisVal = p445.lastValue(targetIndex);
            var nextVal = p445.lastValue(targetIndex + 1);
            if (thisVal > prevVal) {
                if (thisVal > nextVal) {
                    // peak
                    return 1;
                } else {
                    // still climbing
                    return 2;
            } else {
                if (thisVal < nextVal) {
                    // trough
                    return 3;
                } else {
                    // still falling
                    return 4;
            or a slight variation which you may prefer
            if (thisVal >= prevVal && thisVal >= nextVal) {
                // peak
                return 1;
            } else if (thisVal >= prevVal && thisVal < nextVal) {
                // still climbing
                return 2;
            } else if (thisVal < prevVal && thisVal < nextVal) {
                // trough
                return 3;
            } else {
                // still falling
                return 4;
              Pikey4
              Thanks for helping out @CraigWeb @phildunlap @Jared-Wiltshire ,
              I couldn't get it to work with a Persistent TCP data on central server, so set up on an ES on Site and it seems to be tracking good. All the 4's and 1's are lining up where I expect them.
              Thanks Again.
              I got this to work:
              var prevVal = p709.lastValue(2);
              var thisVal = p709.lastValue(1);
              var nextVal = p709.lastValue();
                  // peak
                  return 4;
                  // still climbing
                  return 3;
                  // trough
                  return 1;
              } else {
                  // falling
                  return 2;
