    Create an Email Template for Event Handler
    8 Posts 2 Posters 4.0k Views 3 Watching
      Matias Saul
      Hi all,
      I'm trying to create a nice email template for event handler, but I really don't know hot to use it.
      I need to add additional context to an binary data point trigger, showing last data of two additional data point.
      Looking the documentation, I found this:
      butwhen I try to replicate to my template isn't working.
      Could someone help me this this? Thanks!!
        Hi Matias,
        isn't working
        Should always be accompanied by a description of the failure.
        Even though... that image has some issues, and I see you got it from the help.infiniteautomation.com page about custom email handlers. I will put something better there, since that image is riddled with problems.
        For now, try,
        <@subject>Hey - Stuff is happening with the automation system and I think you should know</@subject>
        <#if renderedHtmlPointValues??>
          <#list renderedHtmlPointValues as renderedPvt>
          ${additionalContext.temperature.deviceName} - ${additionalContext.temperature.name} - ${renderedPvt.value} - ${renderedPvt.time}<br/>
          </#list>
        </#if>
        And be sure to add a point into the context with the key 'temperature'
        Also it should be noted the renderedHtmlPointValues and renderedPointValues items are only added to the model if it's a point event and the point that generated the event is running.
        You could add recent values into the model yourself in the script by doing something like,
        model.put("temperatureValues", temperature.last(10));
        And then using the <#list> to iterate over that, instead.
          Matias Saul
          Thanks for your help Philip !
          Putting "additionalContext" to variables works! But I have some doubts about :
          If I use this code in the script windows, I have to call the "temperatureValues" variable into the code, like:
          ${temperatureValues.value}
          Works in that way? And I need to put this variable inside the <#list renderedHtmlPointValues as renderedPvt>
          or isn't necessary?
          Thanks in advance!
            You would loop over it, like,
            <#list temperatureValues as pvt>
            <#-- do stuff with pvt, pvt.value, pvt.time -->
            </#list>
            It's a List<PointValueTime> similar to renderedHtmlPointValues. It wouldn't have the rendering done to it, though.
              Matias Saul
              Nice!! It worked pretty well. Thanks!
                Matias Saul
                One more question.
                How can I work with the results?
                For example, when I use pvt.time, I get the timestamp only, and I need to show date and time format.
                  You may find this StackOverflow thread interesting: https://stackoverflow.com/questions/7846105/freemarker-model-convert-timestamp-in-milliseconds-to-date
                  TLDR
                  ${pvt.time?number_to_datetime?string("YYYY-MM-dd HH:mm:ss")}
                  Didn't test again just now, but the number_to_date, number_to_time, number_to_datetime functions are what you're looking for.
                    Matias Saul
                    Thanks !! That did the trick...
