    Charts not working with any of our data points.
    11 Posts 2 Posters 3.7k Views 2 Watching
      Hi balanceBryce,
      I gave you a good tip for a more friendly way to post your logs last time (really just some formatting to do, put three backticks above and below portions of the log file) and you went the opposite direction and posted eight topics. Please put some thought into whether the portion of the log you are providing seems useful, but definitely do not post your question splayed across eight topics. As it was, that was a regular boot up and you have one warning there, not a lot to go on. Here's the thread last time: https://forum.infiniteautomation.com/topic/3703/runtimemanager-initialization-failure
      There are two ways to seek further information, you can launch Mango at the command line and see if anything makes it to stderr, and you can have your browser's developer tools open when you experience the issue and check the console for errors.
      Is it charting small requests but exhibiting this behavior with larger requests?
      It sounds like you may be getting close to running out of memory. Java will start to consume a lot of CPU as it frantically looks for garbage to collect. What sort of memory settings do you have enabled? How much memory is on the machine running Mango? You could try to allocate more memory with an appropriate script those in the Mango/bin/ext-available directory (move it to the ext-enabled directory, use an amount appropriate to the machine, and stop, then start (not restart) Mango to apply the memory settings.
      • B Offline
        balanceBryce
        Hi Phil,
        Sorry about the formatting.
        We have not been able to get any charting. We have set roll-up to 10 mins and simplify with a 500 tolerance.
        We have 8GB of memory on the system and have used the medium memory extension (I changed it from 5G to 4G).
        I have just recreated the issue but nothing appeared in the command line for me to provide. I checked task manager while it was frozen and the memory used by java was ~3.2GB with ~75% of total memory being used. Disk speed was sitting at 80-95%.
        A similar issue happened again while trying to get the free java memory plot and this was in the command line:
        ERROR 2018-09-21T14:24:52,809 (com.serotonin.m2m2.web.mvc.websocket.MangoPingPongTracker.sendPing:53) - Error sending websocket ping
        java.io.IOException: Unable to obtain RemoteEndpoint in session 76ce53dc
                at org.springframework.web.socket.adapter.jetty.JettyWebSocketSession.getRemoteEndpoint(JettyWebSocketSession.java:296) ~[spring-websocket-4.3.17.RELEASE.jar:4.3.17.RELEASE]
                at org.springframework.web.socket.adapter.jetty.JettyWebSocketSession.sendPingMessage(JettyWebSocketSession.java:283) ~[spring-websocket-4.3.17.RELEASE.jar:4.3.17.RELEASE]
                at org.springframework.web.socket.adapter.AbstractWebSocketSession.sendMessage(AbstractWebSocketSession.java:107) ~[spring-websocket-4.3.17.RELEASE.jar:4.3.17.RELEASE]
                at com.serotonin.m2m2.web.mvc.websocket.MangoPingPongTracker.sendPing(MangoPingPongTracker.java:50) [mango-3.4.5.jar:?]
                at com.serotonin.m2m2.web.mvc.websocket.MangoPingPongTracker.scheduleTimeout(MangoPingPongTracker.java:82) [mango-3.4.5.jar:?]
                at com.serotonin.m2m2.util.timeout.TimeoutTask.run(TimeoutTask.java:59) [mango-3.4.5.jar:?]
                at com.serotonin.timer.Task.runTask(Task.java:179) [mango-3.4.5.jar:?]
                at com.serotonin.timer.TaskWrapper.run(TaskWrapper.java:23) [mango-3.4.5.jar:?]
                at com.serotonin.timer.OrderedThreadPoolExecutor$OrderedTaskCollection.run(OrderedThreadPoolExecutor.java:336) [mango-3.4.5.jar:?]
                at java.util.concurrent.ThreadPoolExecutor.runWorker(Unknown Source) [?:1.8.0_181]
                at java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source) [?:1.8.0_181]
                at java.lang.Thread.run(Unknown Source) [?:1.8.0_181]
        Caused by: org.eclipse.jetty.websocket.api.WebSocketException: RemoteEndpoint unavailable, current state [CLOSING], expecting [OPEN or CONNECTED]
                at org.eclipse.jetty.websocket.common.WebSocketSession.getRemote(WebSocketSession.java:308) ~[websocket-common-9.3.23.v20180228.jar:9.3.23.v20180228]
                at org.springframework.web.socket.adapter.jetty.JettyWebSocketSession.getRemoteEndpoint(JettyWebSocketSession.java:293) ~[spring-websocket-4.3.17.RELEASE.jar:4.3.17.RELEASE]
                ... 11 more
        ERROR 2018-09-21T14:25:26,561 (com.serotonin.m2m2.web.dwr.util.ExceptionDetectionFilter.doFilter:38) - DWR invocation exception
        com.serotonin.m2m2.vo.permission.PermissionException: Not authenticated
                at com.serotonin.m2m2.vo.permission.Permissions.ensureValidUser(Permissions.java:59) ~[mango-3.4.5.jar:?]
                at com.serotonin.m2m2.vo.permission.Permissions.hasAdmin(Permissions.java:77) ~[mango-3.4.5.jar:?]
                at com.serotonin.m2m2.reports.web.ReportsDwr.getReportInstances(ReportsDwr.java:409) ~[reports-3.4.2.jar:?]
                at com.serotonin.m2m2.reports.web.ReportsDwr.getReportInstances(ReportsDwr.java:398) ~[reports-3.4.2.jar:?]
                at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) ~[?:1.8.0_181]
                at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source) ~[?:1.8.0_181]
                at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source) ~[?:1.8.0_181]
                at java.lang.reflect.Method.invoke(Unknown Source) ~[?:1.8.0_181]
                at org.directwebremoting.impl.ExecuteAjaxFilter.doFilter(ExecuteAjaxFilter.java:34) ~[dwr-2.0.11.jar:?]
                at org.directwebremoting.impl.DefaultRemoter$1.doFilter(DefaultRemoter.java:428) ~[dwr-2.0.11.jar:?]
                at com.serotonin.m2m2.web.dwr.util.TranslationsFilter.doFilter(TranslationsFilter.java:37) ~[mango-3.4.5.jar:?]
                at com.serotonin.m2m2.web.dwr.util.ExceptionDetectionFilter.doFilter(ExceptionDetectionFilter.java:26) [mango-3.4.5.jar:?]
                at org.directwebremoting.impl.DefaultRemoter$1.doFilter(DefaultRemoter.java:428) [dwr-2.0.11.jar:?]
                at com.serotonin.m2m2.web.dwr.util.DwrPermissionFilter.doFilter(DwrPermissionFilter.java:46) [mango-3.4.5.jar:?]
                at org.directwebremoting.impl.DefaultRemoter.execute(DefaultRemoter.java:431) [dwr-2.0.11.jar:?]
                at org.directwebremoting.impl.DefaultRemoter.execute(DefaultRemoter.java:283) [dwr-2.0.11.jar:?]
                at org.directwebremoting.servlet.PlainCallHandler.handle(PlainCallHandler.java:52) [dwr-2.0.11.jar:?]
                at org.directwebremoting.servlet.UrlProcessor.handle(UrlProcessor.java:101) [dwr-2.0.11.jar:?]
                at org.directwebremoting.servlet.DwrServlet.doPost(DwrServlet.java:146) [dwr-2.0.11.jar:?]
                at javax.servlet.http.HttpServlet.service(HttpServlet.java:707) [javax.servlet-api-3.1.0.jar:3.1.0]
                at javax.servlet.http.HttpServlet.service(HttpServlet.java:790) [javax.servlet-api-3.1.0.jar:3.1.0]
                at org.eclipse.jetty.servlet.ServletHolder.handle(ServletHolder.java:848) [jetty-servlet-9.3.23.v20180228.jar:9.3.23.v20180228]
                at org.eclipse.jetty.servlet.ServletHandler$CachedChain.doFilter(ServletHandler.java:1772) [jetty-servlet-9.3.23.v20180228.jar:9.3.23.v20180228]
                at org.springframework.web.filter.ShallowEtagHeaderFilter.doFilterInternal(ShallowEtagHeaderFilter.java:110) [spring-web-4.3.17.RELEASE.jar:4.3.17.RELEASE]
                at com.serotonin.m2m2.web.filter.MangoShallowEtagHeaderFilter.doFilterInternal(MangoShallowEtagHeaderFilter.java:90) [mango-3.4.5.jar:?]
                at org.springframework.web.filter.OncePerRequestFilter.doFilter(OncePerRequestFilter.java:107) [spring-web-4.3.17.RELEASE.jar:4.3.17.RELEASE]
                at org.eclipse.jetty.servlet.ServletHandler$CachedChain.doFilter(ServletHandler.java:1759) [jetty-servlet-9.3.23.v20180228.jar:9.3.23.v20180228]
                at org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:317) [spring-security-web-4.2.6.RELEASE.jar:4.2.6.RELEASE]
                at org.springframework.security.web.access.intercept.FilterSecurityInterceptor.invoke(FilterSecurityInterceptor.java:127) [spring-security-web-4.2.6.RELEASE.jar:4.2.6.RELEASE]
                at org.springframework.security.web.access.intercept.FilterSecurityInterceptor.doFilter(FilterSecurityInterceptor.java:91) [spring-security-web-4.2.6.RELEASE.jar:4.2.6.RELEASE]
                at org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:331) [spring-security-web-4.2.6.RELEASE.jar:4.2.6.RELEASE]
                at com.serotonin.m2m2.web.mvc.spring.security.PermissionExceptionFilter.doFilter(PermissionExceptionFilter.java:32) [mango-3.4.5.jar:?]
                at org.springframework.security.web.access.ExceptionTranslationFilter.doFilter(ExceptionTranslationFilter.java:114) [spring-security-web-4.2.6.RELEASE.jar:4.2.6.RELEASE]
                at org.springframework.security.web.session.SessionManagementFilter.doFilter(SessionManagementFilter.java:137) [spring-security-web-4.2.6.RELEASE.jar:4.2.6.RELEASE]
                at org.springframework.security.web.authentication.AnonymousAuthenticationFilter.doFilter(AnonymousAuthenticationFilter.java:111) [spring-security-web-4.2.6.RELEASE.jar:4.2.6.RELEASE]
                at org.springframework.security.web.servletapi.SecurityContextHolderAwareRequestFilter.doFilter(SecurityContextHolderAwareRequestFilter.java:170) [spring-security-web-4.2.6.RELEASE.jar:4.2.6.RELEASE]
                at org.springframework.security.web.savedrequest.RequestCacheAwareFilter.doFilter(RequestCacheAwareFilter.java:63) [spring-security-web-4.2.6.RELEASE.jar:4.2.6.RELEASE]
                at org.springframework.security.web.session.ConcurrentSessionFilter.doFilter(ConcurrentSessionFilter.java:155) [spring-security-web-4.2.6.RELEASE.jar:4.2.6.RELEASE]
                at org.springframework.security.web.authentication.AbstractAuthenticationProcessingFilter.doFilter(AbstractAuthenticationProcessingFilter.java:200) [spring-security-web-4.2.6.RELEASE.jar:4.2.6.RELEASE]
                at org.springframework.security.web.authentication.logout.LogoutFilter.doFilter(LogoutFilter.java:116) [spring-security-web-4.2.6.RELEASE.jar:4.2.6.RELEASE]
                at org.springframework.security.web.csrf.CsrfFilter.doFilterInternal(CsrfFilter.java:100) [spring-security-web-4.2.6.RELEASE.jar:4.2.6.RELEASE]
                at org.springframework.security.web.header.HeaderWriterFilter.doFilterInternal(HeaderWriterFilter.java:66) [spring-security-web-4.2.6.RELEASE.jar:4.2.6.RELEASE]
                at org.springframework.security.web.context.SecurityContextPersistenceFilter.doFilter(SecurityContextPersistenceFilter.java:105) [spring-security-web-4.2.6.RELEASE.jar:4.2.6.RELEASE]
                at org.springframework.security.web.context.request.async.WebAsyncManagerIntegrationFilter.doFilterInternal(WebAsyncManagerIntegrationFilter.java:56) [spring-security-web-4.2.6.RELEASE.jar:4.2.6.RELEASE]
                at org.springframework.security.web.FilterChainProxy.doFilterInternal(FilterChainProxy.java:214) [spring-security-web-4.2.6.RELEASE.jar:4.2.6.RELEASE]
                at org.springframework.security.web.FilterChainProxy.doFilter(FilterChainProxy.java:177) [spring-security-web-4.2.6.RELEASE.jar:4.2.6.RELEASE]
                at org.springframework.web.filter.DelegatingFilterProxy.invokeDelegate(DelegatingFilterProxy.java:347) [spring-web-4.3.17.RELEASE.jar:4.3.17.RELEASE]
                at org.springframework.web.filter.DelegatingFilterProxy.doFilter(DelegatingFilterProxy.java:263) [spring-web-4.3.17.RELEASE.jar:4.3.17.RELEASE]
                at org.eclipse.jetty.servlet.ServletHandler$CachedChain.doFilter(ServletHandler.java:1751) [jetty-servlet-9.3.23.v20180228.jar:9.3.23.v20180228]
                at org.eclipse.jetty.servlet.ServletHandler.doHandle(ServletHandler.java:582) [jetty-servlet-9.3.23.v20180228.jar:9.3.23.v20180228]
                at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:143) [jetty-server-9.3.23.v20180228.jar:9.3.23.v20180228]
                at org.eclipse.jetty.security.SecurityHandler.handle(SecurityHandler.java:548) [jetty-security-9.3.23.v20180228.jar:9.3.23.v20180228]
                at org.eclipse.jetty.server.session.SessionHandler.doHandle(SessionHandler.java:226) [jetty-server-9.3.23.v20180228.jar:9.3.23.v20180228]
                at org.eclipse.jetty.server.handler.ContextHandler.doHandle(ContextHandler.java:1180) [jetty-server-9.3.23.v20180228.jar:9.3.23.v20180228]
                at org.eclipse.jetty.servlet.ServletHandler.doScope(ServletHandler.java:512) [jetty-servlet-9.3.23.v20180228.jar:9.3.23.v20180228]
                at org.eclipse.jetty.server.session.SessionHandler.doScope(SessionHandler.java:185) [jetty-server-9.3.23.v20180228.jar:9.3.23.v20180228]
                at org.eclipse.jetty.server.handler.ContextHandler.doScope(ContextHandler.java:1112) [jetty-server-9.3.23.v20180228.jar:9.3.23.v20180228]
                at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:141) [jetty-server-9.3.23.v20180228.jar:9.3.23.v20180228]
                at org.eclipse.jetty.server.handler.ContextHandlerCollection.handle(ContextHandlerCollection.java:213) [jetty-server-9.3.23.v20180228.jar:9.3.23.v20180228]
                at org.eclipse.jetty.server.handler.gzip.GzipHandler.handle(GzipHandler.java:493) [jetty-server-9.3.23.v20180228.jar:9.3.23.v20180228]
                at org.eclipse.jetty.server.handler.HandlerWrapper.handle(HandlerWrapper.java:134) [jetty-server-9.3.23.v20180228.jar:9.3.23.v20180228]
                at org.eclipse.jetty.server.Server.handle(Server.java:539) [jetty-server-9.3.23.v20180228.jar:9.3.23.v20180228]
                at org.eclipse.jetty.server.HttpChannel.handle(HttpChannel.java:333) [jetty-server-9.3.23.v20180228.jar:9.3.23.v20180228]
                at org.eclipse.jetty.server.HttpConnection.onFillable(HttpConnection.java:251) [jetty-server-9.3.23.v20180228.jar:9.3.23.v20180228]
                at org.eclipse.jetty.io.AbstractConnection$ReadCallback.succeeded(AbstractConnection.java:283) [jetty-io-9.3.23.v20180228.jar:9.3.23.v20180228]
                at org.eclipse.jetty.io.FillInterest.fillable(FillInterest.java:108) [jetty-io-9.3.23.v20180228.jar:9.3.23.v20180228]
                at org.eclipse.jetty.io.SelectChannelEndPoint$2.run(SelectChannelEndPoint.java:93) [jetty-io-9.3.23.v20180228.jar:9.3.23.v20180228]
                at org.eclipse.jetty.util.thread.strategy.ExecuteProduceConsume.executeProduceConsume(ExecuteProduceConsume.java:303) [jetty-util-9.3.23.v20180228.jar:9.3.23.v20180228]
                at org.eclipse.jetty.util.thread.strategy.ExecuteProduceConsume.produceConsume(ExecuteProduceConsume.java:148) [jetty-util-9.3.23.v20180228.jar:9.3.23.v20180228]
                at org.eclipse.jetty.util.thread.strategy.ExecuteProduceConsume.run(ExecuteProduceConsume.java:136) [jetty-util-9.3.23.v20180228.jar:9.3.23.v20180228]
                at org.eclipse.jetty.util.thread.QueuedThreadPool.runJob(QueuedThreadPool.java:671) [jetty-util-9.3.23.v20180228.jar:9.3.23.v20180228]
                at org.eclipse.jetty.util.thread.QueuedThreadPool$2.run(QueuedThreadPool.java:589) [jetty-util-9.3.23.v20180228.jar:9.3.23.v20180228]
        Bryce
        • B Offline
          balanceBryce
          WARN  2018-09-21T14:25:26,655 (com.serotonin.m2m2.web.mvc.spring.exception.ExceptionUtils.logWebException:56) -
          REQUEST URL
          http://hostname-removed.com:8080/reportChart.shtm
          REQUEST PARAMETERS
             instanceId=193
          REQUEST HEADERS
             Cookie=MANGO8080=something; XSRF-TOKEN=something-else
             Accept=text/html,application/xhtml+xml,application/xml;q=0.9,image/webp,image/apng,*/*;q=0.8
             Upgrade-Insecure-Requests=1
             Connection=keep-alive
             User-Agent=Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/69.0.3497.100 Safari/537.36
             Referer=http://hostname-removed.com:8080/reports.shtm
             Host=hostname-removed.com:8080
             Accept-Encoding=gzip, deflate
             Accept-Language=en-US,en;q=0.9
          REQUEST ATTRIBUTES
             org.springframework.web.context.request.async.WebAsyncManager.WEB_ASYNC_MANAGER=org.springframework.web.context.request.async.WebAsyncManager@2a8e4a94
             javax.servlet.error.status_code=500
             org.springframework.web.servlet.DispatcherServlet.CONTEXT=WebApplicationContext for namespace 'springDispatcher-servlet': startup date [Fri Sep 21 18:38:52 PONT 2018]; parent: Root WebApplicationContext
             org.springframework.web.servlet.HandlerMapping.introspectTypeLevelMapping=false
             __spring_security_session_mgmt_filter_applied=true
             org.springframework.web.servlet.DispatcherServlet.LOCALE_RESOLVER=org.springframework.web.servlet.i18n.SessionLocaleResolver@7a7a9f08
             org.eclipse.jetty.server.newSessionId=1b0n6x32vb9rn1e21pfril6sqx
             org.springframework.web.servlet.HandlerMapping.bestMatchingPattern=/reportChart.shtm
             org.springframework.web.servlet.DispatcherServlet.OUTPUT_FLASH_MAP=FlashMap [attributes={}, targetRequestPath=null, targetRequestParams={}]
             javax.servlet.error.exception_type=class org.springframework.web.util.NestedServletException
             org.springframework.web.servlet.DispatcherServlet.FLASH_MAP_MANAGER=org.springframework.web.servlet.support.SessionFlashMapManager@526fa0ca
             lang=en
             lastUpgrade=1536312911
             availableLanguages=[]
             javax.servlet.http.HttpServletResponse=org.springframework.security.web.header.HeaderWriterFilter$HeaderWriterResponse@73b6fa4c
             _csrf=org.springframework.security.web.csrf.DefaultCsrfToken@2b34c444
             __spring_security_filterSecurityInterceptor_filterApplied=true
             javax.servlet.error.servlet_name=springDispatcher
             javax.servlet.error.message=org.springframework.web.util.NestedServletException: Request processing failed; nested exception is java.lang.RuntimeException: User does not exist
             org.springframework.web.servlet.DispatcherServlet.THEME_SOURCE=WebApplicationContext for namespace 'springDispatcher-servlet': startup date [Fri Sep 21 18:38:52 PONT 2018]; parent: Root WebApplicationContext
             instanceDescription=Balance Group
             NEW_ID=-1
             org.springframework.web.servlet.HandlerMapping.pathWithinHandlerMapping=/reportChart.shtm
             org.springframework.security.web.csrf.CsrfToken=org.springframework.security.web.csrf.DefaultCsrfToken@2b34c444
             javax.servlet.error.request_uri=/reportChart.shtm
             org.springframework.web.servlet.DispatcherServlet.THEME_RESOLVER=org.springframework.web.servlet.theme.FixedThemeResolver@5989cf5
             javax.servlet.error.exception=org.springframework.web.util.NestedServletException: Request processing failed; nested exception is java.lang.RuntimeException: User does not exist
                  at com.serotonin.m2m2.reports.web.ReportCommon.ensureReportInstancePermission(ReportCommon.java:38) ~[reports-3.4.2.jar:?]
                  at com.serotonin.m2m2.reports.web.ReportChartHandler.handleRequest(ReportChartHandler.java:32) ~[reports-3.4.2.jar:?]
                  at com.serotonin.m2m2.web.mvc.UrlHandlerController.handleRequest(UrlHandlerController.java:36) ~[mango-3.4.5.jar:?]
                  at org.springframework.web.servlet.mvc.SimpleControllerHandlerAdapter.handle(SimpleControllerHandlerAdapter.java:50) ~[spring-webmvc-4.3.17.RELEASE.jar:4.3.17.RELEASE]
                  at org.springframework.web.servlet.DispatcherServlet.doDispatch(DispatcherServlet.java:967) ~[spring-webmvc-4.3.17.RELEASE.jar:4.3.17.RELEASE]
                  at org.springframework.web.servlet.DispatcherServlet.doService(DispatcherServlet.java:901) ~[spring-webmvc-4.3.17.RELEASE.jar:4.3.17.RELEASE]
                  at org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:970) ~[spring-webmvc-4.3.17.RELEASE.jar:4.3.17.RELEASE]
                  at org.springframework.web.servlet.FrameworkServlet.doGet(FrameworkServlet.java:861) ~[spring-webmvc-4.3.17.RELEASE.jar:4.3.17.RELEASE]
                  at javax.servlet.http.HttpServlet.service(HttpServlet.java:687) ~[javax.servlet-api-3.1.0.jar:3.1.0]
                  at org.springframework.web.servlet.FrameworkServlet.service(FrameworkServlet.java:846) ~[spring-webmvc-4.3.17.RELEASE.jar:4.3.17.RELEASE]
                  at javax.servlet.http.HttpServlet.service(HttpServlet.java:790) ~[javax.servlet-api-3.1.0.jar:3.1.0]
                  at org.eclipse.jetty.servlet.ServletHolder.handle(ServletHolder.java:848) ~[jetty-servlet-9.3.23.v20180228.jar:9.3.23.v20180228]
                  at org.eclipse.jetty.servlet.ServletHandler$CachedChain.doFilter(ServletHandler.java:1772) ~[jetty-servlet-9.3.23.v20180228.jar:9.3.23.v20180228]
                  at com.serotonin.m2m2.web.filter.WebContextFilter.doFilter(WebContextFilter.java:43) ~[mango-3.4.5.jar:?]
                  at org.eclipse.jetty.servlet.ServletHandler$CachedChain.doFilter(ServletHandler.java:1759) ~[jetty-servlet-9.3.23.v20180228.jar:9.3.23.v20180228]
                  at com.serotonin.m2m2.web.filter.UrlSecurityFilter.doFilter(UrlSecurityFilter.java:191) ~[mango-3.4.5.jar:?]
                  at com.serotonin.web.filter.CharacterSetFilter.doFilter(CharacterSetFilter.java:37) ~[mango-3.4.5.jar:?]
                  at org.springframework.web.filter.ShallowEtagHeaderFilter.doFilterInternal(ShallowEtagHeaderFilter.java:110) ~[spring-web-4.3.17.RELEASE.jar:4.3.17.RELEASE]
                  at com.serotonin.m2m2.web.filter.MangoShallowEtagHeaderFilter.doFilterInternal(MangoShallowEtagHeaderFilter.java:90) ~[mango-3.4.5.jar:?]
                  at org.springframework.web.filter.OncePerRequestFilter.doFilter(OncePerRequestFilter.java:107) ~[spring-web-4.3.17.RELEASE.jar:4.3.17.RELEASE]
                  at org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:317) ~[spring-security-web-4.2.6.RELEASE.jar:4.2.6.RELEASE]
                  at org.springframework.security.web.access.intercept.FilterSecurityInterceptor.invoke(FilterSecurityInterceptor.java:127) ~[spring-security-web-4.2.6.RELEASE.jar:4.2.6.RELEASE]
                  at org.springframework.security.web.access.intercept.FilterSecurityInterceptor.doFilter(FilterSecurityInterceptor.java:91) ~[spring-security-web-4.2.6.RELEASE.jar:4.2.6.RELEASE]
                  at org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:331) ~[spring-security-web-4.2.6.RELEASE.jar:4.2.6.RELEASE]
                  at com.serotonin.m2m2.web.mvc.spring.security.PermissionExceptionFilter.doFilter(PermissionExceptionFilter.java:32) ~[mango-3.4.5.jar:?]
                  at org.springframework.security.web.access.ExceptionTranslationFilter.doFilter(ExceptionTranslationFilter.java:114) ~[spring-security-web-4.2.6.RELEASE.jar:4.2.6.RELEASE]
                  at org.springframework.security.web.session.SessionManagementFilter.doFilter(SessionManagementFilter.java:137) ~[spring-security-web-4.2.6.RELEASE.jar:4.2.6.RELEASE]
                  at org.springframework.security.web.authentication.AnonymousAuthenticationFilter.doFilter(AnonymousAuthenticationFilter.java:111) ~[spring-security-web-4.2.6.RELEASE.jar:4.2.6.RELEASE]
                  at org.springframework.security.web.servletapi.SecurityContextHolderAwareRequestFilter.doFilter(SecurityContextHolderAwareRequestFilter.java:170) ~[spring-security-web-4.2.6.RELEASE.jar:4.2.6.RELEASE]
                  at org.springframework.security.web.savedrequest.RequestCacheAwareFilter.doFilter(RequestCacheAwareFilter.java:63) ~[spring-security-web-4.2.6.RELEASE.jar:4.2.6.RELEASE]
                  at org.springframework.security.web.session.ConcurrentSessionFilter.doFilter(ConcurrentSessionFilter.java:155) ~[spring-security-web-4.2.6.RELEASE.jar:4.2.6.RELEASE]
                  at org.springframework.security.web.authentication.AbstractAuthenticationProcessingFilter.doFilter(AbstractAuthenticationProcessingFilter.java:200) ~[spring-security-web-4.2.6.RELEASE.jar:4.2.6.RELEASE]
                  at org.springframework.security.web.authentication.logout.LogoutFilter.doFilter(LogoutFilter.java:116) ~[spring-security-web-4.2.6.RELEASE.jar:4.2.6.RELEASE]
                  at org.springframework.security.web.csrf.CsrfFilter.doFilterInternal(CsrfFilter.java:100) ~[spring-security-web-4.2.6.RELEASE.jar:4.2.6.RELEASE]
                  at org.springframework.security.web.header.HeaderWriterFilter.doFilterInternal(HeaderWriterFilter.java:66) ~[spring-security-web-4.2.6.RELEASE.jar:4.2.6.RELEASE]
                  at org.springframework.security.web.context.SecurityContextPersistenceFilter.doFilter(SecurityContextPersistenceFilter.java:105) ~[spring-security-web-4.2.6.RELEASE.jar:4.2.6.RELEASE]
                  at org.springframework.security.web.context.request.async.WebAsyncManagerIntegrationFilter.doFilterInternal(WebAsyncManagerIntegrationFilter.java:56) ~[spring-security-web-4.2.6.RELEASE.jar:4.2.6.RELEASE]
                  at org.springframework.security.web.FilterChainProxy.doFilterInternal(FilterChainProxy.java:214) ~[spring-security-web-4.2.6.RELEASE.jar:4.2.6.RELEASE]
                  at org.springframework.security.web.FilterChainProxy.doFilter(FilterChainProxy.java:177) ~[spring-security-web-4.2.6.RELEASE.jar:4.2.6.RELEASE]
                  at org.springframework.web.filter.DelegatingFilterProxy.invokeDelegate(DelegatingFilterProxy.java:347) ~[spring-web-4.3.17.RELEASE.jar:4.3.17.RELEASE]
                  at org.springframework.web.filter.DelegatingFilterProxy.doFilter(DelegatingFilterProxy.java:263) ~[spring-web-4.3.17.RELEASE.jar:4.3.17.RELEASE]
                  at org.eclipse.jetty.servlet.ServletHandler$CachedChain.doFilter(ServletHandler.java:1751) ~[jetty-servlet-9.3.23.v20180228.jar:9.3.23.v20180228]
          WARN  2018-09-21T14:30:45,958 (com.serotonin.m2m2.web.mvc.rest.v1.publisher.pointValue.PointValueWebSocketHandler$PointValueWebSocketListener.pointUpdated:241) - Error sending websocket message
          com.serotonin.m2m2.web.mvc.websocket.WebSocketSendException: org.eclipse.jetty.websocket.api.WebSocketException: RemoteEndpoint unavailable, current state [CLOSED], expecting [OPEN or CONNECTED]
                  at com.serotonin.m2m2.web.mvc.websocket.MangoWebSocketHandler.sendStringMessageAsync(MangoWebSocketHandler.java:135) ~[mango-3.4.5.jar:?]
                  at com.serotonin.m2m2.web.mvc.websocket.MangoWebSocketHandler.sendMessage(MangoWebSocketHandler.java:94) ~[mango-3.4.5.jar:?]
                  at com.serotonin.m2m2.web.mvc.rest.v1.publisher.pointValue.PointValueWebSocketHandler.sendMessage(PointValueWebSocketHandler.java:143) ~[mango-api-3.4.6.jar:?]
                  at com.serotonin.m2m2.web.mvc.rest.v1.publisher.pointValue.PointValueWebSocketHandler$PointValueWebSocketListener.sendNotification(PointValueWebSocketHandler.java:190) ~[mango-api-3.4.6.jar:?]
                  at com.serotonin.m2m2.web.mvc.rest.v1.publisher.pointValue.PointValueWebSocketHandler$PointValueWebSocketListener.pointUpdated(PointValueWebSocketHandler.java:238) [mango-api-3.4.6.jar:?]
                  at com.serotonin.m2m2.rt.dataImage.DataPointEventMulticaster.pointUpdated(DataPointEventMulticaster.java:151) [mango-3.4.5.jar:?]
                  at com.serotonin.m2m2.rt.dataImage.DataPointRT$EventNotifyWorkItem.execute(DataPointRT.java:741) [mango-3.4.5.jar:?]
                  at com.serotonin.m2m2.rt.maint.BackgroundProcessingImpl$RejectableWorkItemRunnable.run(BackgroundProcessingImpl.java:632) [mango-3.4.5.jar:?]
          Caused by: org.eclipse.jetty.websocket.api.WebSocketException: RemoteEndpoint unavailable, current state [CLOSED], expecting [OPEN or CONNECTED]
                  at com.serotonin.m2m2.web.mvc.websocket.MangoWebSocketHandler.sendStringMessageAsync(MangoWebSocketHandler.java:133) ~[mango-3.4.5.jar:?]
                  ... 13 more
          Below is the report chart of Free JVM, as you suggested it does reach zero, how should I combat this?
          Bryce
            Hmm. Over what kind of time period, and with what data density? Have you tried short time ranges? You could open your browser's developer tools and check the network tab for the actual request for the data. That would tell us if the request isn't returning (what I expecT) or if there's some other issue going on in the front end. You could also try charting a short time period without a rollup and share the results.
            That definitely seems like it would be enough for some charting. I wonder if there is anything else going on in the instance that would be draining memory?
            The second error in the first post is weird to me. Do you have a web.xml file in your Mango/overrides/web/ directory? Have you modified the web.xml file? For some reason, your requests are not properly being identified as coming from your logged in user. I think that's the source of the issues, but I can only imagine it happening if there were some issue like overridden classes or duplicate jars in the Mango/lib/ directory, or maybe some intervening server messing with the headers. Can you try starting up a newly downloaded Mango after copying your Mango/databases directory into the new Mango? Does that alleviate any of what you're seeing? Are you trying to chart anywhere other than in a report instance? The errors you posted are from using the legacy reports page, but it sounded to me like your charts were not working on the /ui/data-point-details page. Can you clarify which charts you're talking about (since obviously you can generate old JFree charts!)
            If it does continue happening, we can keep looking down the memory line of reasoning. That would probably next involve downloading a few thread dumps while the problem is occurring from the /rest/v1/threads?asFile=true&stackDepth-40 endpoint, which you could then email to support@infiniteautomation.com and I will try to see if there's any more information to be gleaned there.
            Just an aside, but you should be careful when posting error output! The post with the memory usage chart's error contained your session cookie information and your host, which is enough information to hijack your session.
            • B Offline
              balanceBryce
              Hi Phil,
              Even just opening the data point details page with one data point and no charting crashes, so I don't think the size matters.
              I have checked this and three elements time out almost in sync in the network tab ( I have exported one of these as a .har which I am happy to share with you if it is of interest), and in the console there are lots of events similar to the following:
              mangoUi~ngMango~ngMangoServices.js?v=f6d868035ceca7ed0360:230 TypeError: Cannot read property 'push' of undefined
                  at t.$applyAsync (mangoUi~ngMango.js?v=13b0f75f5f39034b19d2:84)
                  at c.$eval (mangoUi~ngMango~ngMangoServices.js?v=f6d868035ceca7ed0360:230)
                  at mangoUi~ngMango~ngMangoServices.js?v=f6d868035ceca7ed0360:230
                  at _ (mangoUi~ngMango~ngMangoServices.js?v=f6d868035ceca7ed0360:230)
                  at c.$apply (mangoUi~ngMango~ngMangoServices.js?v=f6d868035ceca7ed0360:230)
                  at p (mangoUi~ngMango~ngMangoServices.js?v=f6d868035ceca7ed0360:230)
              and I've saved the log which if you would like a closer look at I'm also happy to share.
              Note that for these I logged into the computer remotely and used localhost:8080 to ensure that there weren't any issues with headers getting tampered by the network.
              Our overrides folder is fairly meager, with only 2 files. One is env.properties which I've changed the timezone in, and the other is web\images\logo.png.
              Recently I performed an update from 3.3.4 (I think) to 3.4.4 which sounds very similar to the process you're describing and the issue happened both before and after the upgrade. I will test this soon.
              Currently anywhere other than a old style report chart crashes the system, so I'm using them to display data as an interim measure.
                The browser tab crashes? What's crashing when you say that? What browser are you using?
                That looks like the data is being returned but something else is awry in adding it to something. Probably not going to fix anything but I would try clearing your browser cache. You can email the .har file to support@infiniteautomation.com . That may reveal that the data is successfully being fetched and returned.
                If you went through the modules page to do the upgrade this should have happened for you (it would delete the old lib files, move in the new). But, I have had reports of clean installations helping people, so it's something to try. I can assure you that charting does in fact work, generally, It could also be good to know what version of Java you are running, as updating to the latest JDK 8 is also a good course of action.
                • B Offline
                  balanceBryce
                  Sorry, mango hangs and we have to stop and start it. I'm using Chrome.
                  Will give it a shot, so I just copy the database and over rides folders in to the new installation home (but hold on the over-rides until after I've checked whether charting works or not). I thought the same thing about JDK so I have tried updating with no change. We're at 8u181 at the moment.
                    I reviewed your .har file and saw the requests are hitting the 30s timeout for a response to a request in the Angular $http service. This means there was no response (not just that it was transferring data) within 30s, which coupled with having no error is a very strange circumstance, I would maybe try moving your Mango/databases/mangoTSDB directory while Mango was off, and checking if the requests are still timing out. I assumed you were using the NoSQL, but after taking a closer look at your initially posted log output it doesn't look like you are. I wonder, if you go to the /sqlConsole.shtm page, how large is your pointValues table? select count(*) from pointValues;
                    I would guess if you don't have NoSQL installed that it would resolve the issue to install it and migrate over your old data.
                    • B Offline
                      balanceBryce
                      Thanks Phil,
                      We performed a clean install and this resolved the issue of our Mango instance crashing and not restoring itself. Performance was still poor so we also created meta points that rolled-up our data and then purged the old data source back to only a couple of days and this has significantly improved performance.
                      Bryce
                        Thanks for sharing the resolution Bryce! Keeping the pointValues table in check is definitely a necessity for users who don't have the NoSQL module!
