    Make default datebar rollup type Simplify?
    8 Posts 4 Posters 2.8k Views 3 Watching
      mrlucretius
      How can I have new users / logins always default to simplify for rollup type?
      Alex
        Hi Alex,
        Unfortunately this is not currently possible. The state of the user's selections isn't actually stored on the Mango server, it's stored in the browser's local storage. It could be a nice to have, though (to be able to preload a user's UI state), so thanks for the suggestion!
          mrlucretius
          So knowing this, I should just set all of my numeric data points to have rollup type simplify? Is this safe?
          The remote mango server is feeding the cloud server through persistent tcp publishing.
          Are there any repercussions I should be aware of? Or can I blindly set the rollup type? The rollup only affects the visualization correct? It does not modify the logging properties right?
          Alex
            It does not effect the logging. But doing that would have a global effect on any page that uses the datebar. You could also set the roll up in your
            <ma-point-values point-xid="BDP_EERST_WTW_TOTFL" values="point1Values" from="dateBar.from"
               to="dateBar.to" rollup="SIMPLIFY" simplifyTolerance="500">
               </ma-point-values>
              mrlucretius
              Awesome, that does the trick! Duh. I didn't even look there.
              Alex
                Also, the date bar should default to "Point Default" for the roll-up for a new user. The idea of this is on the Data Point setting you can specify a roll-up or simplify option for each Data Point. If you do this you should get the behavior you want.
                  mrlucretius
                  Yes, I have yet to set rollups on data points.
                  I think simplify is safe to apply to all numeric datapoints? I can't think of a reason why not.
                  Alex
                    As CraigWeb noted it does not affect logging. It is likely more overhead than the other rollup types, but I wouldn't expect that to be too big a deal. You can use the internal data source to watch if you see significant changes over time.
