    Bug in DoJo rendering
    5 Posts 3 Posters 2.5k Views 2 Watching
      mlavelle42
      Mango shutsdown within 1 to 36 hours because of bug:
      WARN  2018-07-16T07:02:28,751 (com.serotonin.m2m2.web.dwr.MiscDwr.jsError:176) - Javascript error
         Description: Error: Tried to register widget with id==chartRendererSelect but that id is already registered
         Page: http://10.144.1.204:8080/resources/dojo/dojo.js?v=1530110639 line 345 > Function line 3 > eval
         Line: 2
         Browser name: Firefox
         Browser version: 60
         osName: Mac
      I've found this same bug mentioned for DoJo and a possible solution:
      https://stackoverflow.com/questions/15357879/dojo-1-8-unable-to-update-combobox-every-time-there-ia-a-change-in-select
      I'm trying for a fix by removing and re-implementing widgets on one page (for now) which appears to be at fault.
      Any suggestions?
      The full log follows:
      pi@pi-9822-carney-main:/opt/mango/logs $ cat 07-16-2018-1.ma.log
      INFO  2018-07-16T00:05:00,177 (com.serotonin.m2m2.rt.maint.work.BackupWorkItem.execute:101) - Starting backup WorkItem.
      INFO  2018-07-16T00:05:00,177 (com.serotonin.m2m2.rt.maint.work.DatabaseBackupWorkItem.execute:109) - Starting database backup WorkItem.
      INFO  2018-07-16T00:05:00,189 (com.serotonin.m2m2.rt.maint.work.DatabaseBackupWorkItem.createLogOutputStream:224) - Writing backup log to /opt/mango/logs/com.serotonin.m2m2.rt.maint.work.DatabaseBackupWorkItem.log
      INFO  2018-07-16T00:05:14,098 (com.serotonin.m2m2.rt.maint.work.BackupWorkItem.execute:181) - Finished backup WorkItem.
      INFO  2018-07-16T03:05:00,013 (com.serotonin.m2m2.rt.maint.DataPurge.executeImpl:68) - Data purge started
      INFO  2018-07-16T03:05:04,001 (com.serotonin.m2m2.rt.maint.DataPurge.executeImpl:91) - Data purge ended, 0 point samples deleted
      WARN  2018-07-16T07:00:51,288 (com.serotonin.m2m2.web.dwr.MiscDwr.jsError:176) - Javascript error
         Line: 2
         Browser version: 60
         osName: Mac
      WARN  2018-07-16T07:01:10,453 (com.serotonin.m2m2.web.dwr.MiscDwr.jsError:176) - Javascript error
         Line: 2
         Browser version: 60
         osName: Mac
      WARN  2018-07-16T07:01:38,932 (com.serotonin.m2m2.web.dwr.MiscDwr.jsError:176) - Javascript error
         Line: 2
         Browser version: 60
         osName: Mac
      WARN  2018-07-16T07:01:59,140 (com.serotonin.m2m2.web.dwr.MiscDwr.jsError:176) - Javascript error
         Line: 2
         Browser version: 60
         osName: Mac
         Line: 2
         Browser version: 60
         osName: Mac
      INFO  2018-07-16T07:12:42,142 (com.serotonin.m2m2.Lifecycle.terminate:387) - Mango Lifecycle terminating...
      INFO  2018-07-16T07:12:43,604 (com.serotonin.m2m2.rt.DataSourceGroupTerminator.terminate:72) - Terminating 1 LAST priority data sources in 8 threads.
      INFO  2018-07-16T07:12:43,612 (com.serotonin.m2m2.rt.RuntimeManagerImpl.stopDataSourceShutdown:451) - Data source 'SolarTempDifferential' stopped
      INFO  2018-07-16T07:12:43,708 (com.serotonin.m2m2.rt.DataSourceGroupTerminator.terminate:102) - Termination of 1 LAST priority data sources took 105ms
      INFO  2018-07-16T07:12:43,709 (com.serotonin.m2m2.rt.DataSourceGroupTerminator.terminate:72) - Terminating 3 NORMAL priority data sources in 8 threads.
      INFO  2018-07-16T07:12:43,718 (com.serotonin.m2m2.rt.RuntimeManagerImpl.stopDataSourceShutdown:451) - Data source 'Indianapolis Weather' stopped
      INFO  2018-07-16T07:12:43,754 (com.serotonin.m2m2.rt.RuntimeManagerImpl.stopDataSourceShutdown:451) - Data source 'BACnet' stopped
      INFO  2018-07-16T07:12:43,759 (com.serotonin.m2m2.rt.RuntimeManagerImpl.stopDataSourceShutdown:451) - Data source 'Mango Internal' stopped
      INFO  2018-07-16T07:12:43,812 (com.serotonin.m2m2.rt.DataSourceGroupTerminator.terminate:102) - Termination of 3 NORMAL priority data sources took 103ms
      INFO  2018-07-16T07:12:43,869 (com.serotonin.m2m2.rt.maint.BackgroundProcessingImpl.joinTermination:550) - All high priority tasks exited gracefully.
      INFO  2018-07-16T07:12:43,873 (com.serotonin.m2m2.rt.maint.BackgroundProcessingImpl.joinTermination:556) - All medium priority tasks exited gracefully.
      INFO  2018-07-16T07:12:43,876 (com.serotonin.m2m2.rt.maint.BackgroundProcessingImpl.joinTermination:561) - All low priority tasks exited gracefully.
      INFO  2018-07-16T07:12:45,963 (com.serotonin.m2m2.Lifecycle.terminate:496) - Mango Lifecycle terminated.
        What version of Mango are you using? You'll probably need to share your full ma.log file.
          @mlavelle42 The dojo JavaScript error will not cause mango to shutdown. Its most likely caused by an unlicensed module (MangoNoSQL or Brewer's Dashboard), you will see a message at the start of your log file when Mango first starts up if this is the case.
            mlavelle42
            I found the JVM memory to be too low and the graphics rendering gradually came to a halt. That's when this error occurred. I'm not using NoSQL, only H2. I'm running 3.4.4. I've increased JVM memory per a previous post. That may have been the problem. Plus I'm changing my rollups to reduce the number of data points in a query. Thanks for the help.
              Are you using the new Dashboard Designer or the old Graphic Views? The new UI and Dashboard Designer performs much better. I would strongly recommend learning the new Dashboard Designer rather than Graphic views.
