    Open graphical representation when you click a Script for the server
    12 Posts 3 Posters 5.8k Views 3 Watching
      Hi Prayol,
      It's been quite a while since I wrote a server-side scripting component for the graphical views!
      You can add the point on the component through the dropdown. You cannot create a point value dao as you tried (the proper way would be com.serotonin.m2m2.Common.databaseProxy.newPointValueDao();), nor is there a method that takes a string ID like that. Instead, use the value that's already been added to the script context for the point added to the component, something like,
      if (value === true) //assuming it's a binary point
      return "<img style='cursor:pointer;' src='graphics/Leds48/led48_green_1.png' onclick='mango.view.setPoint("+ point.id +", "+ pointComponent.id +", false);return false;'/>";
      else
      return "<img style='cursor:pointer;' src='graphics/Leds48/led48_white_0.png' onclick='mango.view.setPoint("+ point.id +", "+ pointComponent.id +", true);return false;'/>";
      I didn't test the HTML, but using 'value' and adding the point to the compoent like so:
        This post is deleted!
          Prayol @phildunlap
          @phildunlap Hello phildunlap, thanks for the help.
          See, I use a variation of Mango here in Brazil called ScadaBR. As for DAO, it is working correctly in this variation. My problem is that I'm not sure how to insert the redirect after a click into the server script. I have to direct the user to this representation: views.shtm? ViewId = 8, how do I? I can not do it alone. Thank you
            Have you tried a <script> tag that changes the window.location ?
              Prayol @phildunlap
              @phildunlap said in Open graphical representation when you click a Script for the server:
              I tried this way: onclick = 'javascript: window.location.href =' http: // localhost: 8080 / ScadaBR / views.shtm? ViewId = 5 ";
              The problem, that is JavaScript is not my native language, so it is not a will and I do not know if it is correct what I did.
                This was my test, worked to get my from the view page to the edit page.
                var s = "<button onclick=\"window.location.href = 'http://localhost:8080/view_edit.shtm?viewId=1';\">";
                if( value < 50 )
                  return s+"<b>HELLO WORLD</b></button>";
                else
                  return s+"<b>GOODBYE WORLD</b></button>";
                  Prayol @phildunlap
                  var s = "<button onclick="window.location.href = 'http://localhost:8080/view_edit.shtm?viewId=1';">";
                  Thank you my friend. It worked! Now I'm just taking the button shape that was created around the chart to look perfect! It's possible ?
                    Certainly welcome (although consider using Mango :P). You can use a <div> tag, and a closing </div> instead of the <button></button>
                      Prayol @phildunlap
                      @phildunlap
                      Your help, I have already been very helpful. I do not want to be inopportune, but by putting it this way: (var s = "<div> <onclick = " window.location.href = 'http: // localhost: 8080 / ScadaBR / views.shtm? ViewId = 8' ; \ "> <\ div>";) - I lose the click and redirect function. thankful
                        var s = "<div onclick=\"window.location.href = 'http://localhost:8080/view_edit.shtm?viewId=1';\">";
                        if( value < 50 )
                          return s+"<b>HELLO WORLD</b></div>";
                        else
                          return s+"<b>GOODBYE WORLD</b></div>";
                          Prayol @phildunlap
                          @phildunlap
                          SHOW !!!! Thank you, Thank you, Thank you.
