    Excel export feature
    20 Posts 3 Posters 12.5k Views 3 Watching
      You can get this format by using the watchlist download button (in the new UI). Assuming you are using Mango 3.x
      • G Offline
        georgestefan
        Yes, in Mango V3.x works if I select download as CSV (Separate Value Columns), but also I have some issue with this.
        The time stamp it is a number which I cannot format into date in excel (in Mango V2.x I was able to format the timestamp into date). Below is an image with the time stamp, first line I tried to format the cell type to date and the result was that:
        Some of the values are displayed in line, but other are displayed on separate lines, all should have the same timestamp.
        Also, in Mango V2.x it is possible to export .csv file like Separate Value Columns file from Mango V3.x?
          You can select a different date format when downloading the data, such as Excel compliant formats.
          • G Offline
            georgestefan
            Hmm, do you have any idea way I don't see Time format line and Time zone line?
            Thanks!
              What versions of Core, Mango API, Watchlists, and Mango UI do you have installed?
              • G Offline
                georgestefan
                Core: 3.1.1+20170620163725
                MangoApi: 3.1.3
                Watchlist: 3.1.0
                MangoUI: 3.1.5
                  That's why then, it must have been added in a later version. You could update...
                  G 1 Reply Last reply Reply Quote 1
                  • G Offline
                    georgestefan @phildunlap
                    @phildunlap It give's me this error when I check for upgrades:
                      Yeah, that module was discontinued in favor of the UI module and its dashboarding tools. You will have to remove it (which you can do from the legacy modules page in that version) and restart before you can update through the UI.
                      • G Offline
                        @phildunlap I've upgraded and now I have Time Format. But if I use this feature, from the picture from bellow, to download, in the .csv file I have only 2 values.
                        But if i use this feature, from the picture from bellow, to download, I get all the data for respective time period.
                        I should get to identical files, no? Any idea why is that difference?
                        Thanks!
                          It appears to be caused by a bug in the Download button with an improper limit being imposed on the download. We'll have this fixed soon.
                            Jared Wiltshire @georgestefan
                            @georgestefan said in Excel export feature:
                            They will not be identical, they will probably be formatted a little different but they should contain the same timestamps and values. The bug you were seeing has been fixed the the mangoUI module v.3.4.2 that I just released. Sorry about that.
                            • G Offline
                              georgestefan
                              I've updated mangoUI to V.3.4.2 and now the download feature works. But I still have a problem with the timestamp, some points are note displayed correctly. Below is an example with the problem.
                              First 18 lines are ok, I want all the line to be like those lines.
                                The two rows you highlighted have different timestamps. Are they from the same data source?
                                • G Offline
                                  georgestefan @Jared Wiltshire
                                  @jared-wiltshire Yes, they are from the same data source.
                                    What kind of data source?
                                    You could use a rollup. That would ensure all the timestamps are the same.
                                    • G Offline
                                      georgestefan
                                      When you say to use a rollup, at this settings are you referring?
                                      If yes, still not working, the points are on separate lines.
                                        The rollup interval set in the date bar (that image ^^) is the rollup used in the data download, but only if the rollup type in the download menu is selected.
                                        • G Offline
                                          georgestefan
                                          Worked with Rollup Type, the file is ok now.
                                          Thank you!
