    SMA Cluster Controller
    5 Posts 2 Posters 5.2k Views 1 Watching
    • D Offline
      Dominic.Irl
      I am trying to communicate via the SMA cluster controller to additional inverters in the network.
      I can communicate with the cluster controller directly no problem.
      My issue is with ascertaining the unit ID's of the other inverters. I am unsure if this a Mango query or a query for SMA.
      I have strangely enough found one of the inverters @ slave ID 255. I thought the range was 0-240!!
      Are there any trick to polling the slaves to find them?
      Any insight into this would be greatly appreciated.
      Thanks in advance
      • jeremyhJ Offline
        jeremyh
        This is a SMA query, but I will save you some time.
        The basic steps are that you must go into the Cluster Controller > 'Update and Save' page > Modbus > 'Save automatically generated plant configuration'. This will download a XML file which you can open in a text editor and set the modbus address of each inverter. Then upload it via the 'Update user-defined plant configuration (*.xml)' button.
        You can find all this information in the SMA Cluster Controller user manual, but it is quite poorly explained. It took me a little while to work out too.
        Jeremy
        • D Offline
          Dominic.Irl
          Hi Jeremy,
          You are a star!!
          You are right, it is poorly explained in the SMA manual - regardless you saved the day!
          D
          • jeremyhJ Offline
            jeremyh
            No problem, thanks for following up. Glad you had a win.
