<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[SMA Cluster Controller]]></title><description><![CDATA[<p dir="auto">I am trying to communicate via the SMA cluster controller to additional inverters in the network.</p>
<p dir="auto">I can communicate with the cluster controller directly no problem.<br />
My issue is with ascertaining the unit ID's of the other inverters. I am unsure if this a Mango query or a query for SMA.<br />
I have strangely enough found one of the inverters @ slave ID 255. I thought the range was 0-240!!</p>
<p dir="auto">Are there any trick to polling the slaves to find them?</p>
<p dir="auto">Any insight into this would be greatly appreciated.</p>
<p dir="auto">Thanks in advance</p>
]]></description><link>https://forum.mango-os.com/topic/1816/sma-cluster-controller</link><generator>RSS for Node</generator><lastBuildDate>Wed, 07 Oct 2026 04:21:49 GMT</lastBuildDate><atom:link href="https://forum.mango-os.com/topic/1816.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 24 Feb 2015 22:19:13 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to SMA Cluster Controller on Tue, 10 Mar 2015 13:17:50 GMT]]></title><description><![CDATA[<p dir="auto">No problem, thanks for following up. Glad you had a win.</p>
]]></description><link>https://forum.mango-os.com/post/9761</link><guid isPermaLink="true">https://forum.mango-os.com/post/9761</guid><dc:creator><![CDATA[jeremyh]]></dc:creator><pubDate>Tue, 10 Mar 2015 13:17:50 GMT</pubDate></item><item><title><![CDATA[Reply to SMA Cluster Controller on Tue, 10 Mar 2015 12:36:12 GMT]]></title><description><![CDATA[<p dir="auto">Hi Jeremy,</p>
<p dir="auto">You are a star!!<br />
You are right, it is poorly explained in the SMA manual - regardless you saved the day!</p>
<p dir="auto">Thanks,</p>
<p dir="auto">D</p>
]]></description><link>https://forum.mango-os.com/post/9760</link><guid isPermaLink="true">https://forum.mango-os.com/post/9760</guid><dc:creator><![CDATA[Dominic.Irl]]></dc:creator><pubDate>Tue, 10 Mar 2015 12:36:12 GMT</pubDate></item><item><title><![CDATA[Reply to SMA Cluster Controller on Wed, 25 Feb 2015 13:03:54 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/dominic.irl" aria-label="Profile: Dominic.Irl">@<bdi>Dominic.Irl</bdi></a> said:</p>
<p dir="auto">My issue is with ascertaining the unit ID's of the other inverters. I am unsure if this a Mango query or a query for SMA.</p>
<p dir="auto">Hello,</p>
<p dir="auto">This is a SMA query, but I will save you some time.</p>
<p dir="auto">The basic steps are that you must go into the Cluster Controller &gt; 'Update and Save' page &gt; Modbus &gt; 'Save automatically generated plant configuration'. This will download a XML file which you can open in a text editor and set the modbus address of each inverter. Then upload it via the 'Update user-defined plant configuration (*.xml)' button.</p>
<p dir="auto">You can find all this information in the SMA Cluster Controller user manual, but it is quite poorly explained. It took me a little while to work out too.</p>
<p dir="auto">Cheers<br />
Jeremy</p>
]]></description><link>https://forum.mango-os.com/post/9738</link><guid isPermaLink="true">https://forum.mango-os.com/post/9738</guid><dc:creator><![CDATA[jeremyh]]></dc:creator><pubDate>Wed, 25 Feb 2015 13:03:54 GMT</pubDate></item></channel></rss>
