    MangoESV3 refused to connect after upgrade 3.34
    10 Posts 2 Posters 4.2k Views 2 Watching
    • D Offline
      Desmond
      Hi Support,
      After upgrade to 3.3.4, the mangoES refused to connect. This error page "This site cant be reached" after restart. This is the first attempt to do upgrade as it is a new purchased unit.
      I have tried the IP address in the URL and do a restart again but no success. What could be wrong during the upgrade process?
      Any suggestion or help is appreciated.
      Thank you in advanced
        Might you have manually upgraded it and done some step as the root user, while ls -l /opt/mango reveals files owned by 'mango'? Fix by chown -R mango:mango /opt/mango
        Have you tried to see what happens if you attempt to launch Mango at the command line with
        cd /opt/mango/bin; ./ma.sh start
        • D Offline
          Desmond
          @phildunlap
          I have managed to see the directory of mango now. For your information running the command cd /opt/mango/bin; ./ma.sh start give the result as per photo.
          I tried to login locally via the url give the result as per photo.
          0_1524467450565_error2.jpg.
          The IP address 192.168.1.12 response with the ping command and I can login the wed server.
          This is the new purchased unit on feb2018 and I have not done nothing else other than upgrading the web admin and mangoES. It used to be login without issue before upgrade.
          Pls help as I am not familiar with administering the web server. I cant figure out what need to be done.
          Thank you in advance.
            Hi Desmond,
            It looks like something is wrong in the advanced components module that you have installed. Consider removing it,
            rm -r /opt/mango/web/modules/advancedComponents
            And trying to start again. You can reinstall it on the module page.
            • D Offline
              Desmond
              @phildunlap
              I have removed the advancedComponents module as per your comment. Then I run ma-start command or url://IP address, it does not launch the login page in chrome as per expected.
              Below i have attached the ma and ma-script file for your action.
              [shareable link](https://drive.google.com/file/d/12T4HlRaWmeiX5cFB7JBxGrYm47GODaiu/view?usp=sharing
              https://drive.google.com/file/d/166ladCzcLizSWdM57FTOBXjA37mF2dhF/view?usp=sharing)
              Hope you can look into it and give me guidance to resolve it.
                Something is amiss. Did you update / install Java?
                I would try downloading the enterprise bundle of 3.3.4 from https://store.infiniteautomation.com/core, renaming it to m2m2-core-3.3.4.zip, place it in /opt/mango/ and attempt to start it again. This will let the scripts perform the upgrade and ensure there are no duplicate jars.
                • D Offline
                  Desmond
                  @phildunlap
                  I have followed your instruction steps to perform the upload enterprise bundle and restart but it does not resolve the startup issue.
                  part of console screen terminal:
                  [mango@mangoES3508 ~]# cd /opt/mango/bin; ./ma.sh start
                  MA_HOME is /opt/mango
                  Archive: /opt/mango/m2m2-core-3.4.4.zip
                  Total output of 1.03 MB was truncated at 97.66 kB.
                  [mango@mangoES3508 bin]# cd /opt/mango/bin; ./ma.sh start
                  MA already running with Process ID: 1015
                  ma-start: MA done
                  Below is the console screen terminal for the java version :
                  ma-start: MA done
                  [mango@mangoES3508 bin]# java -version
                  java version "1.8.0_131"
                  Java(TM) SE Runtime Environment (build 1.8.0_131-b11)
                  Java HotSpot(TM) Client VM (build 25.131-b11, mixed mode)
                  Pls note that I have been troubled with this issue since the purchased on the feb2018. Currently I am using trial version to do the application development.
                  I need your support to look into it as I am about to due for a presentation with the new MangoES.
                    Hmm. It sounds like one or more modules has a module.properties file that is most likely 0 bytes long. I saw this on someone's system after an update. Perhaps try removing all your modules, and then using the /modules.shtm page to install the modules you need.
                    • D Offline
                      Desmond
                      @phildunlap
                      After several unsuccessful attempts, may I request that Mango to investigate into the root cause? I am willing to send you the details to access into the web server remotely.
                      My main concern is that I do not wish to make it worse by doing something wrongly to the system or if other errors occurred, it is difficult to isolate the problem. Besides, I am under pressure to start setting up of this MangoES unit for a demo presentation.
                      Let me know your comments.
                        Upon investigation, I found Mango online and accessible. I updated it from 3.4.1 to 3.4.3
