<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[MangoESV3 refused to connect after upgrade 3.34]]></title><description><![CDATA[<p dir="auto">Hi Support,</p>
<p dir="auto">After upgrade to 3.3.4, the mangoES refused to connect. This error page "This site cant be reached" after restart. This is the first attempt to do upgrade as it is a new purchased unit.</p>
<p dir="auto">I have tried the IP address in the URL and do a restart again but no success. What could be wrong during the upgrade process?</p>
<p dir="auto">Any suggestion or help is appreciated.<br />
Thank you in advanced</p>
]]></description><link>https://forum.mango-os.com/topic/3418/mangoesv3-refused-to-connect-after-upgrade-3-34</link><generator>RSS for Node</generator><lastBuildDate>Mon, 20 Jul 2026 10:41:03 GMT</lastBuildDate><atom:link href="https://forum.mango-os.com/topic/3418.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 16 Apr 2018 11:19:22 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to MangoESV3 refused to connect after upgrade 3.34 on Wed, 06 Jun 2018 14:29:43 GMT]]></title><description><![CDATA[<p dir="auto">Upon investigation, I found Mango online and accessible. I updated it from 3.4.1 to 3.4.3</p>
]]></description><link>https://forum.mango-os.com/post/18742</link><guid isPermaLink="true">https://forum.mango-os.com/post/18742</guid><dc:creator><![CDATA[phildunlap]]></dc:creator><pubDate>Wed, 06 Jun 2018 14:29:43 GMT</pubDate></item><item><title><![CDATA[Reply to MangoESV3 refused to connect after upgrade 3.34 on Wed, 30 May 2018 04:54:39 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/phildunlap" aria-label="Profile: phildunlap">@<bdi>phildunlap</bdi></a><br />
After several unsuccessful attempts, may I request that Mango to investigate into the root cause? I am willing to send you the details to access into the web server remotely.</p>
<p dir="auto">My main concern is that I do not wish to make it worse by doing something wrongly to the system or if other errors occurred, it is difficult to isolate the problem. Besides, I am under pressure to start setting up of this MangoES unit for a demo presentation.</p>
<p dir="auto">Let me know your comments.</p>
<p dir="auto">Thanks</p>
]]></description><link>https://forum.mango-os.com/post/18661</link><guid isPermaLink="true">https://forum.mango-os.com/post/18661</guid><dc:creator><![CDATA[Desmond]]></dc:creator><pubDate>Wed, 30 May 2018 04:54:39 GMT</pubDate></item><item><title><![CDATA[Reply to MangoESV3 refused to connect after upgrade 3.34 on Mon, 21 May 2018 15:03:56 GMT]]></title><description><![CDATA[<p dir="auto">Hmm. It sounds like one or more modules has a module.properties file that is most likely 0 bytes long. I saw this on someone's system after an update. Perhaps try removing all your modules, and then using the /modules.shtm page to install the modules you need.</p>
]]></description><link>https://forum.mango-os.com/post/18521</link><guid isPermaLink="true">https://forum.mango-os.com/post/18521</guid><dc:creator><![CDATA[phildunlap]]></dc:creator><pubDate>Mon, 21 May 2018 15:03:56 GMT</pubDate></item><item><title><![CDATA[Reply to MangoESV3 refused to connect after upgrade 3.34 on Mon, 21 May 2018 07:55:29 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/phildunlap" aria-label="Profile: phildunlap">@<bdi>phildunlap</bdi></a><br />
I have followed your instruction steps to perform the upload enterprise bundle and restart but it does not resolve the startup issue.</p>
<p dir="auto">part of console screen terminal:<br />
[mango@mangoES3508 ~]# cd /opt/mango/bin; ./ma.sh start<br />
MA_HOME is /opt/mango<br />
Archive:  /opt/mango/m2m2-core-3.4.4.zip<br />
........<br />
Total output of 1.03 MB was truncated at 97.66 kB.<br />
[mango@mangoES3508 bin]# cd /opt/mango/bin; ./ma.sh start<br />
MA already running with Process ID:  1015<br />
ma-start: MA done</p>
<p dir="auto">Below is the console screen terminal for the java version :</p>
<p dir="auto">[mango@mangoES3508 bin]# cd /opt/mango/bin; ./ma.sh start<br />
ma-start: MA done<br />
[mango@mangoES3508 bin]# java -version<br />
java version "1.8.0_131"<br />
Java(TM) SE Runtime Environment (build 1.8.0_131-b11)<br />
Java HotSpot(TM) Client VM (build 25.131-b11, mixed mode)<br />
[mango@mangoES3508 bin]#</p>
<p dir="auto">Pls note that I have been troubled with this issue since the purchased on the feb2018. Currently I am using trial version to do the application development.<br />
I need your support to look into it as I am about to due for a presentation with the new MangoES.</p>
<p dir="auto">Thank you in advance.</p>
]]></description><link>https://forum.mango-os.com/post/18519</link><guid isPermaLink="true">https://forum.mango-os.com/post/18519</guid><dc:creator><![CDATA[Desmond]]></dc:creator><pubDate>Mon, 21 May 2018 07:55:29 GMT</pubDate></item><item><title><![CDATA[Reply to MangoESV3 refused to connect after upgrade 3.34 on Tue, 24 Apr 2018 17:00:50 GMT]]></title><description><![CDATA[<p dir="auto">Something is amiss. Did you update / install Java?</p>
<p dir="auto">I would try downloading the enterprise bundle of 3.3.4 from <a href="https://store.infiniteautomation.com/core" rel="nofollow ugc">https://store.infiniteautomation.com/core</a>, renaming it to m2m2-core-3.3.4.zip, place it in /opt/mango/ and attempt to start it again. This will let the scripts perform the upgrade and ensure there are no duplicate jars.</p>
]]></description><link>https://forum.mango-os.com/post/18150</link><guid isPermaLink="true">https://forum.mango-os.com/post/18150</guid><dc:creator><![CDATA[phildunlap]]></dc:creator><pubDate>Tue, 24 Apr 2018 17:00:50 GMT</pubDate></item><item><title><![CDATA[Reply to MangoESV3 refused to connect after upgrade 3.34 on Tue, 24 Apr 2018 03:46:54 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/phildunlap" aria-label="Profile: phildunlap">@<bdi>phildunlap</bdi></a></p>
<p dir="auto">I have removed the advancedComponents module as per your comment. Then I run ma-start command or url://IP address, it does not launch the login page in chrome as per expected.</p>
<p dir="auto">Below i have attached the ma and ma-script file for your action.</p>
<p dir="auto">[shareable link](<a href="https://drive.google.com/file/d/12T4HlRaWmeiX5cFB7JBxGrYm47GODaiu/view?usp=sharing" rel="nofollow ugc">https://drive.google.com/file/d/12T4HlRaWmeiX5cFB7JBxGrYm47GODaiu/view?usp=sharing</a><br />
<a href="https://drive.google.com/file/d/166ladCzcLizSWdM57FTOBXjA37mF2dhF/view?usp=sharing" rel="nofollow ugc">https://drive.google.com/file/d/166ladCzcLizSWdM57FTOBXjA37mF2dhF/view?usp=sharing</a>)</p>
<p dir="auto">Hope you can look into it and give me guidance to resolve it.</p>
]]></description><link>https://forum.mango-os.com/post/18142</link><guid isPermaLink="true">https://forum.mango-os.com/post/18142</guid><dc:creator><![CDATA[Desmond]]></dc:creator><pubDate>Tue, 24 Apr 2018 03:46:54 GMT</pubDate></item><item><title><![CDATA[Reply to MangoESV3 refused to connect after upgrade 3.34 on Mon, 23 Apr 2018 14:08:09 GMT]]></title><description><![CDATA[<p dir="auto">Hi Desmond,</p>
<p dir="auto">It looks like something is wrong in the advanced components module that you have installed. Consider removing it,</p>
<pre><code>rm -r /opt/mango/web/modules/advancedComponents
<p dir="auto">And trying to start again. You can reinstall it on the module page.</p>
]]></description><link>https://forum.mango-os.com/post/18121</link><guid isPermaLink="true">https://forum.mango-os.com/post/18121</guid><dc:creator><![CDATA[phildunlap]]></dc:creator><pubDate>Mon, 23 Apr 2018 14:08:09 GMT</pubDate></item><item><title><![CDATA[Reply to MangoESV3 refused to connect after upgrade 3.34 on Mon, 23 Apr 2018 07:22:45 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/phildunlap" aria-label="Profile: phildunlap">@<bdi>phildunlap</bdi></a><br />
I have managed to see the directory of mango now.  For your information running the command cd /opt/mango/bin; ./ma.sh start give the result as per photo.<br />
<img src="https://camo.nodebb.org/7254fbf7599012922c7d5b71255f4ac179bd3f8b?url=https%3A%2F%2Fi.imgur.com%2FpsAdYbp.jpg" alt="0_1524467011328_error1.jpg" class=" img-fluid img-markdown" /></p>
<p dir="auto">I tried to login locally via the url give the result as per photo.<br />
<img src="https://camo.nodebb.org/6ff1e70a385a19a02dc6c4c8ff987d9f45fbb40f?url=https%3A%2F%2Fi.imgur.com%2FAKg9rkX.jpg" alt="0_1524467450565_error2.jpg" class=" img-fluid img-markdown" />.<br />
The IP address 192.168.1.12 response with the ping command and I can login the wed server.</p>
<p dir="auto">This is the new purchased unit on feb2018 and I have not done nothing else other than upgrading the web admin and mangoES. It used to be login without issue before upgrade.</p>
<p dir="auto">Pls help as I am not familiar with administering the web server. I cant figure out what need to be done.</p>
]]></description><link>https://forum.mango-os.com/post/18120</link><guid isPermaLink="true">https://forum.mango-os.com/post/18120</guid><dc:creator><![CDATA[Desmond]]></dc:creator><pubDate>Mon, 23 Apr 2018 07:22:45 GMT</pubDate></item><item><title><![CDATA[Reply to MangoESV3 refused to connect after upgrade 3.34 on Mon, 16 Apr 2018 15:46:55 GMT]]></title><description><![CDATA[<p dir="auto">Might you have manually upgraded it and done some step as the root user, while <code>ls -l /opt/mango</code> reveals files owned by 'mango'? Fix by <code>chown -R mango:mango /opt/mango</code></p>
<p dir="auto">Have you tried to see what happens if you attempt to launch Mango at the command line with</p>
<p dir="auto"><code>cd /opt/mango/bin; ./ma.sh start</code></p>
<p dir="auto">?</p>
]]></description><link>https://forum.mango-os.com/post/18035</link><guid isPermaLink="true">https://forum.mango-os.com/post/18035</guid><dc:creator><![CDATA[phildunlap]]></dc:creator><pubDate>Mon, 16 Apr 2018 15:46:55 GMT</pubDate></item></channel></rss>
