    Strange SMTP errors
    10 Posts 2 Posters 4.2k Views 2 Watching
    • danD Offline
      dan
      Hey Guys, I've had a production system in place for a few years now with no issues. Lately the system hasn't been sending email reports / notifications etc.
      I've checked the log and found the following...
      WARN  2018-04-09 11:45:43,852 (com.serotonin.m2m2.rt.maint.work.EmailWorkItem.execute:86) - Error sending email
      org.springframework.mail.MailSendException: Mail server connection failed; nested exception is javax.mail.MessagingException: Could not connect to SMTP host: in-v3.mailjet.com, port: 465, response: -1. Failed messages: javax.mail.MessagingException: Could not connect to SMTP host: in-v3.mailjet.com, port: 465, response: -1; message exception details (1) are:
      Failed message 1:
      I've tried the other ports such as 25, 587 TLS on/off etc, and all the same errors.
      I can ping the hosts, I've also tried just IP Address.
      Maybe something is not working with the way Java connects to these hosts?
      Dan
        Jared Wiltshire @dan
        @dan Definitely just looks like it can't connect, pinging just means the host is up, it doesn't indicate that port 465 is open. Check your SMTP provider hasn't changed their hostname, ports, configuration options etc.
        • danD Offline
          dan
          I've tried multiple SMTP providers.
          Is the SMTP client using a Java library or something you guys wrote?
          • danD Offline
            dan
            the other thing I wondered was, is there a timeout for connection? This connection is now on a satellite link, so latency is <> 800ms
            root@water:~# ping in-v3.mailjet.com
            PING in.mailjet.com (104.199.96.85) 56(84) bytes of data.
            64 bytes from 85.96.199.104.bc.googleusercontent.com (104.199.96.85): icmp_seq=1 ttl=41 time=900 ms
            64 bytes from 85.96.199.104.bc.googleusercontent.com (104.199.96.85): icmp_seq=2 ttl=41 time=871 ms
            64 bytes from 85.96.199.104.bc.googleusercontent.com (104.199.96.85): icmp_seq=3 ttl=41 time=862 ms
            ^C
            --- in.mailjet.com ping statistics ---
            4 packets transmitted, 3 received, 25% packet loss, time 2998ms
            rtt min/avg/max/mdev = 862.077/878.014/900.703/16.511 ms
            root@water:~# telnet in-v3.mailjet.com 465
            Trying 104.199.96.85...
            Connected to in.mailjet.com.
            Escape character is '^]'.
            it appears to connect from shell.
            • danD Offline
              dan
              one more thing, the SMTP server mailjet uses quite a long password (hash)
              Do you know if there is a limit on length of password in the java client?
                @dan said in Strange SMTP errors:
                We use the Spring class org.springframework.mail.javamail.JavaMailSenderImpl to send the emails, it is a simple wrapper around the Java javax.mail.* interfaces.
                We do not set a timeout, it would be the default (according to https://javaee.github.io/javamail/docs/api/com/sun/mail/smtp/package-summary.html that means its infinite).
                On the same machine that Mango is running on? Have you checked the firewalls etc?
                There is no limit.
                Are you using TLS? Maybe its now required or something? What JRE are you using?
                • danD Offline
                  dan
                  This is running on one of those MangoES solid state bad boys. It's been super reliable.
                  root@water:~# java -version
                  java version "1.8.0-ea"
                  Java(TM) SE Runtime Environment (build 1.8.0-ea-b111)
                  Java HotSpot(TM) Client VM (build 25.0-b53, mixed mode)
                  • danD Offline
                    dan
                    I've even tried using localhost as the mail server and tailed the log...
                    Apr 11 09:36:04 water postfix/smtpd[9329]: connect from localhost[127.0.0.1]
                    Apr 11 09:36:11 water postfix/smtpd[9329]: lost connection after HELO from localhost[127.0.0.1]
                    Apr 11 09:36:11 water postfix/smtpd[9329]: disconnect from localhost[127.0.0.1]
                    It appears that the HELO part is failing. This seems to be related to the hostname, I haven't changed this that I'm aware of however :-/
                    WARN  2018-04-11 09:36:04,555 (com.serotonin.m2m2.rt.maint.work.EmailWorkItem.execute:86) - Error sending email
                    org.springframework.mail.MailSendException: Mail server connection failed; nested exception is javax.mail.MessagingException: 501 Syntax: HELO hostname
                    . Failed messages: javax.mail.MessagingException: 501 Syntax: HELO hostname
                    Failed message 1:
                    • danD Offline
                      dan
                      OK, I think I've resolved it, managed to remove all the settings, add them all in again using port 587, TLS with mailjet and it's working.
                      Thanks for your assistance :)
                      Dan
                        Dan
                        Great, glad you got it working.
