    Using Persistent TCP points in script calculations
    41 Posts 2 Posters 62.9k Views 2 Watching
      Yes. As of Mango 3.2 set point event handler scripts, point link scripts, and meta point scripts can all
      return UNCHANGED;
      to indicate no value should be set forth.
        psysak
        @phildunlap said in Using Persistent TCP points in script calculations:
        return UNCHANGED;
        At some point I will find a question you cannot answer!
          Bring it on :P
            psysak
            Interesting, I'm still getting the same errors as before even though I tried changing the script so it doesn't rely on LOGGED or anything like that. I'm literally pulling the data right out of the database
            if(pulse.lastValue().time > my.lastValue().time + 15000) {
               var list = pulse.pointValuesSince(my.lastValue().time + 5000);
               for (var i=0; i < list.length; i++) {
                   my.set(list*.doubleValue * pfactor * tfactor, list*.time);
            return UNCHANGED;
            Now I get this error, which is the same as before
            'MORGUARD': Script error in point "MORGUARD - EO00026SW_BIERMARKTM3": TypeError: Cannot get property "time" of null in at line number 31 in at line number 31Add comment
            Oh well... That was my last attempt, I'll move it all to the edge devices now.
              The issue is that the meta point doesn't have any values, so my.lastValue() is null, and it cannot have a .time.
              One can initialize a meta point like this by either setting a value to it, or putting a little handling in the point, like,
              if(my.lastValue() === null) {
                //TIMESTAMP = new Date(2018, 1, 1).getTime(); //When does your point begin?
                //return 0; //What does it begin at?
                //Edit: I just remembered, you could also do,
                my.set(0, new Date(2018, 1, 1).getTime());
                //and then carry on with the script.
                //be sure your meta point is settable!
                psysak
                Noo way! If that's the issue I'm gonna have some kind of egg on my face haha. Classic rookie mistake not validating this.
                K I'm going to poke this into all my points and see how it feels about it.
                  psysak
                  I did that on purpose just to see how well you knew your product.......
                    And I wrote getPointValuesSince instead of pointValuesSince the first time to ensure you had something to correct... yes... :D
                      psysak
                      Huh, I'm getting odd results Phil.
                      And there's time ranges with no issues at all. No errors now though. The only thing I can think of is a timestamp that I'm not aware of which affects the number of data points I get back.
                      I was hopeful!
                      My code looks like this now, triggered every 15mins.
                      if(pulse.lastValue() === null) {
                         return UNCHANGED;
                         my.set(0, new Date(2017, 1, 1).getTime());
                      return UNCHANGED;
                      I've turned on TRACE logging for this script, hopefully I can see what's going on.
                      Saga continues, Empire Strikes Back episode.
                        My first thought, pardon the asking, is if your source point has values for that time period.
                        Also, my offhand new Date() was somewhat off, the month field is zero indexed, so,
                        new Date(2017, 0, 1).getTime(); //Jan 1 2017 server timezone
                          psysak
                          Hey, absolutely valid question and yes they do have data for those missing chunks. I also did notice that it was a month off but I'm okay with that I don't have any data prior to middle of last year anyway. Script runs every 15 minutes and I enabled the trace logging a while ago so hopefully when I go back and look at it this afternoon I'll see something useful. I forgot to mention as well that I trigger every 15 minutes starting at 2 minutes past the hour that way hopefully everything is synced properly but it shouldn't matter anyway cuz that scription catch any change. I believe you mentioned that the historical synchronisation through this mechanism starts with the oldest date of first is that correct?
                            Yes, values in the history sync are processed oldest to newest.
                            I wouldn't expect that cron to change anything.
                              psysak
                              Let me ask you this, are execution conditions additive or exclusive? So if I have context update logged, a point is set to update context AND a CRON is setup what happens? I just realized I left a point updating context in that script so am experimenting with that now.
                                Additive-ish; a meta point executing every 15 seconds with four point updates in a minute (to a point that is set to update context, with an update event that has occurred) will execute eight times, unless a point update is at the same millisecond as the cron commanded. Then whichever execution arrived second will not be performed.
                                  psysak
                                  LOL this is all I get from the TRACE logs for the meta point
                                  INFO 2018-01-16 11:15:46,365 - Data point started
                                  You think more logs might still be buffered and haven't purged to file yet? Or is this all I should get
                                    Do you call to LOG.debug("I'm here in my script, doing this."); at all? Or, any other log level?
                                      psysak
                                      Ooooohhhh I see, that logging is manually controlled. I thought it was system level logging where it would print stuff out itself. Got ya, I can add some stuff to see what results I get.
                                        psysak
                                        OK so it's 100% that context point.
                                        Here is how the log looks without the context point
                                        ubuntu@ip-172-31-5-12:~/mango/logs$ cat metaPoint-494.log
                                        INFO  2018-01-16 16:14:50,747 - Data point started
                                        TRACE 2018-01-16 16:17:00,035 - Time:1516137420000
                                        TRACE 2018-01-16 16:17:00,056 - Array size:15
                                        TRACE 2018-01-16 16:32:00,005 - Time:1516138320000
                                        TRACE 2018-01-16 16:32:00,009 - Array size:15
                                        Nice and clean. With the context point in the script I have this mess
                                        INFO  2018-01-16 16:14:35,911 - Data point started
                                        TRACE 2018-01-16 16:15:00,649 - Time:1516136400000
                                        TRACE 2018-01-16 16:15:00,672 - Array size:15
                                        TRACE 2018-01-16 16:15:00,700 - Time:1516136460000
                                        TRACE 2018-01-16 16:15:00,704 - Time:1516136520000
                                        TRACE 2018-01-16 16:15:00,704 - Time:1516136580000
                                        TRACE 2018-01-16 16:15:00,704 - Time:1516136640000
                                        TRACE 2018-01-16 16:15:00,705 - Time:1516136700000
                                        TRACE 2018-01-16 16:15:00,710 - Time:1516136760000
                                        TRACE 2018-01-16 16:15:00,710 - Time:1516136820000
                                        TRACE 2018-01-16 16:15:00,710 - Time:1516136880000
                                        TRACE 2018-01-16 16:15:00,710 - Time:1516136940000
                                        TRACE 2018-01-16 16:15:00,710 - Time:1516137000000
                                        TRACE 2018-01-16 16:15:00,710 - Time:1516137060000
                                        TRACE 2018-01-16 16:15:00,710 - Time:1516137120000
                                        TRACE 2018-01-16 16:15:00,710 - Time:1516137180000
                                        TRACE 2018-01-16 16:15:00,711 - Time:1516137240000
                                        TRACE 2018-01-16 16:17:00,003 - Time:1516137420000
                                        TRACE 2018-01-16 16:30:00,671 - Time:1516137300000
                                        TRACE 2018-01-16 16:30:00,686 - Array size:1
                                        TRACE 2018-01-16 16:30:00,688 - Time:1516137360000
                                        TRACE 2018-01-16 16:30:00,689 - Time:1516137420000
                                        TRACE 2018-01-16 16:30:00,689 - Time:1516137480000
                                        TRACE 2018-01-16 16:30:00,690 - Time:1516137540000
                                        TRACE 2018-01-16 16:30:00,690 - Time:1516137600000
                                        TRACE 2018-01-16 16:30:01,102 - Time:1516137660000
                                        TRACE 2018-01-16 16:30:01,102 - Time:1516137720000
                                        TRACE 2018-01-16 16:30:01,102 - Time:1516137780000
                                        TRACE 2018-01-16 16:30:01,103 - Time:1516137840000
                                        TRACE 2018-01-16 16:30:01,104 - Time:1516137900000
                                        TRACE 2018-01-16 16:30:01,105 - Time:1516137960000
                                        TRACE 2018-01-16 16:30:01,105 - Time:1516138020000
                                        TRACE 2018-01-16 16:30:01,105 - Time:1516138080000
                                        TRACE 2018-01-16 16:30:01,105 - Time:1516138140000
                                        TRACE 2018-01-16 16:32:00,000 - Time:1516138320000
                                        Thing just goes nuts...
                                        OK, on to Return of the Jedi
