Mango Commercial Licence, but NoSQL DB Unlicensed?
I purchased a lite commercial license and installed the "Mango Automation 3.2.2 Enterprise" linux package over the top of a "Mango Automation 3.2.2 Free" installation. When I go to the modules page from the home page it shows "mangoNoSqlDatabase" and "advancedComponents" modules as "Unlicensed". My understanding the Commercial license included the NoSqlDatabase.
Hi thutchis,
You are correct! You should be able to click 'update my license' on the modules page, then you'll be presented with a list of options for licensing your core and modules. Don't change your core license, and you should see any applicable modules you don't already have licensed have a cost of $0.00. If you whole order costs $0, the license will be granted to you immediately and you can license those modules. So after selecting them and making the 'purchase' you can hit 'download license' from Mango.
It should also be said the license restrictions in the modules shouldn't be active if your core is properly licensed, but it will appear as you've said on the modules page.
Thanks Phil, I followed your instructions and will assume then the modules are active and have no restrictions despite saying they are "unlicensed" on the modules page.
After getting the $0 cost license and hitting 'download license' they should not show as unlicensed any more (if you selected the 'included' license type).
If
@phildunlap said in Mango Commercial Licence, but NoSQL DB Unlicensed?:
You are correct! You should be able to click 'update my license' on the modules page, then you'll be presented with a list of options for licensing your core and modules. Don't change your core license, and you should see any applicable modules you don't already have licensed have a cost of $0.00. If you whole order costs $0, the license will be granted to you immediately and you can license those modules. So after selecting them and >making the 'purchase' you can hit 'download license' from Mango.
If I try "making the purchase" I get an error popup that says "Error confirming core license type: no-change"
Huh. I will have to look into that more. For now, I've granted you the license to those two modules, so you should be able to download it using the 'download now' button.
Thanks. Downloaded license and both modules now show as licensed. Thanks.
@phildunlap I am curious, now that I have the NoSQL DB showing as licensed on the Modules Page. If I look at "Administration>System Status>Server Info" it shows:
Database Type: H2"
SQL Database size: 9.9 MiB
NoSQL point value database size: 785.0 KiBSince the Database Type is H2, does this mean Mango isn't using the NoSQL DB?
Just want to make sure I have everything configured right.
Tom
Hi Tom,
It is using both. The H2 database is being used for everything other than point values (also the old HTML reports' data goes into the NoSQL, if installed).
