    Help using MangoAPI to Set Point Values
    javascriptmangoapiangular
    3 Posts 2 Posters 2.5k Views 2 Watching
      avilla
      [0_1509407012389_home.html](Uploading 100%) [0_1509406989995_app.js](Uploading 100%)
      Code attached.
      I'm trying to use the MangoAPI to set and read points. I looked at the setPointValue tutorial in the mangoAPI docs and essentially copied the javascript and html into my app.js and home.html respectively. Learning JS as I go so there could be an issue with how I included the javascript code, and how I imported the libraries. The resource mango/api is failing to load for instance. The javascript code is now inside my controller so maybe that's the problem.
      I want to be able to use MangoAPI.defaultApi.getPoint(xid) and MangoAPI.defaultApi.putValue(xid, pvt) to set points in javascript instead of using the ma-set-point directive. So if anyone has a well detailed way of doing this I'd appreciate it. Also as you may have noticed I'm simply modifying the loginPageTemplate for my own GUI, is there a better way to create an angular app from scratch? I don't actually need the login template.
       * @author Jared Wiltshire
      define([
          'angular',
          './directives/login/login', // load directives from the directives folder
          'mango-3.3/maMaterialDashboards', // load mango-3.3 angular modules
          'angular-ui-router', // load external angular modules
          'angular-loading-bar',
          'mango-2.0/api',
      ], function(angular, login) {
      'use strict';
      // create an angular app with our desired dependencies
      var mySinglePageApp = angular
      .module('mySinglePageApp', ['ui.router','angular-loading-bar','maMaterialDashboards','ngMessages','ngMaterial'])
      .controller('MyCtrl', ['$scope', '$timeout', function($scope, $timeout) {
      $scope.stepTypes = ['soak', 'ramp rate', 'ramp time', 'instant change'];
      var tabs = [
                { title: 'Step 1', content: {}},
              selected = null,
              previous = null;
          $scope.isReady = false;
          $scope.tabs = tabs;
          $scope.stepArray = tabs;
          $scope.selectedIndex = 2;
          $scope.profile = { cycles: 1, steps: {tabs} };
          $scope.$watch('selectedIndex', function(current, old){
            previous = selected;
            selected = tabs[current];
            if ( old + 1 && (old != current)) $log.debug('Goodbye ' + previous.title + '!');
            if ( current + 1 )                $log.debug('Hello ' + selected.title + '!');
          $scope.addTab = function () {
              var titleStr = (tabs.length + 1).toString();
            tabs.push({ title: "Step " + titleStr, content: {}, disabled: false});
          $scope.removeTab = function (tab) {
            var index = tabs.indexOf(tab);
            tabs.splice(index, 1);
            for (var i = 0; i < tabs.length; i++) {
              tabs*.title = "Step " + (i + 1).toString();
           $scope.confirmReady = function() {
              var r = confirm("Press OK if Gate Valve is Open, Cancel otherwise.\n");
              if (r == true) {
                  r = confirm("Press OK if Chamber Door is closed, Cancel otherwise.\n");
                  if (r == true) {
                      $scope.isReady = true;
                      $timeout(function () { $scope.isReady = false; }, 4000);
                      var points = DataPointQuery.query();
                      alert(points);
                      submitProfile(profile)
          $scope.submitProfile = function(profile) {
              var tabs = profile.steps;
              var steps = [{}];
              for (var i = 0; i < tabs.length; i++){
                  steps* = tabs*.content.steps;
      require(['jquery', 'mango/api'],
                      function($, MangoAPI) {
                $('#updateValue').on('click', function(){
                  alert("hey");
                  //We need the data type for the point
                  var xid = $("#xid").val();
                  MangoAPI.defaultApi.getPoint(xid).then(function(point){
                      //Check to see if settable
                      if(point.pointLocator.settable === false){
                          var statusRow = [];
                          statusRow.push(xid + ' not settable.');
                          statusRow.push(new Date());
                          //Append a status row
                          $('#status').append(createRow(statusRow));
                          return;
                      var pvt = getPointValueTime(point);
                      MangoAPI.defaultApi.putValue(xid, pvt).then(function(response){
                              var statusRow = [];
                              statusRow.push('Set Value For ' + xid + ' to ' + pvt.value);
                      }).fail(MangoAPI.logError);
                function createRow(columns){
                  var tr = $('<tr>');
                  for(var i=0; i<columns.length; i++){
                       var td = $('<td>');
                        td.text(columns*);
                        tr.append(td);
                  return tr;
                function getPointValueTime(dataPoint){
                  var value = null;
                    //Set the value depending on the data point type
                    if((dataPoint.pointLocator.dataType == "MULTISTATE")||(dataPoint.pointLocator.dataType == "NUMERIC")){
                        //Since the input is text type we must convert
                        value = new Number($('#pointValueInput').val());
                    else if(dataPoint.pointLocator.dataType == "BINARY"){
                        pointValue.value = new Boolean();
                    else{
                        //For Alphanumeric
                        value = $('#pointValueInput').val();
                  return {
                          value: value,
                          timestamp: new Date().getTime(),
                          annotation: 'Set by custom dashboard',
                          dataType: dataPoint.pointLocator.dataType,
      // add our directives to the app
      mySinglePageApp
          .directive('login', login);
      mySinglePageApp.config([
          '$stateProvider',
          '$urlRouterProvider',
          '$compileProvider',
          '$locationProvider',
      function($stateProvider, $urlRouterProvider, $compileProvider, $locationProvider) {
          // disable angular debug info to speed up app
          $compileProvider.debugInfoEnabled(false);
          // enable html5 mode URLs (i.e. no /#/... urls)
          $locationProvider.html5Mode(true);
          // set the default state
          $urlRouterProvider.otherwise('/home');
          $stateProvider.state('dashboard', {
              templateUrl: 'views/dashboard/main.html',
              resolve: {
                  auth: ['$rootScope', 'User', function($rootScope, User) {
                      // retrieves the current user when we navigate to a dashboard page
                      // if an error occurs the $stateChangeError listener redirects to the login page
                      $rootScope.user = User.current();
                      return $rootScope.user.$promise;
          }).state('dashboard.home', {
              url: '/home',
              templateUrl: 'views/dashboard/home.html',
          }).state('dashboard.page1', {
              url: '/page1',
              templateUrl: 'views/dashboard/page1.html',
          }).state('login', {
              url: '/login',
              templateUrl: 'views/login.html',
              resolve: {
                  loginTranslations: ['Translate', function(Translate) {
                      return Translate.loadNamespaces(['login']);
      mySinglePageApp.run(['$rootScope', '$state', function($rootScope, $state) {
          // redirect to login page if we can't retrieve the current user when changing state
          $rootScope.$on("$stateChangeError", function(event, toState, toParams, fromState, fromParams, error) {
              if (error && (error.status === 401 || error.status === 403)) {
                  event.preventDefault();
                  // store the requested state so we can redirect there after login
                  $state.loginRedirect = toState;
                  $state.go('login');
      // bootstrap the angular application
      angular.element(document).ready(function() {
          angular.bootstrap(document.documentElement, ['mySinglePageApp']);
      }); // define
      <h1>Single Page App with Login</h1>
          <head>
              <title>Set Point Value</title>
              <!-- Add the Mango Favicon -->
              <link rel="icon" href="/images/favicon.ico">
              <!-- Page Style -->
              <style></style>
              <link href="/resources/bootstrap/css/bootstrap.min.css" rel="stylesheet">
              <link href="/modules/dashboards/web/private/css/dashboard.css" rel="stylesheet">
              <!-- Base Library -->
              <script type="text/javascript" src="/resources/loaderConfig.js"></script>
              <script type="text/javascript" src="/resources/require.js"></script>
              <script type="text/javascript" src="/resources/main.js"></script>
              </script>
      	<meta charset="utf-8">
      	<title>Angular Material Template</title>
      	<link rel="stylesheet" href="/resources/angular-csp.css"></link>
      	<link rel="stylesheet" href="../vendor/angular-material/angular-material.css">
      	<link rel="stylesheet" href="../vendor/material-design-icons/iconfont/material-icons.css">
      	<link rel="stylesheet" href="../vendor/mdPickers/mdPickers.css">
      	   <link rel="stylesheet" href="styles/main.css">
      	         <!-- Scripts from Module Directory -->
      	          <script src="/resources/require.js"></script>
          <script src="/resources/loaderConfig.js"></script>
          <script src="../../js/loaderConfig.js"></script>
          <script type='text/javascript' src='/resources/ng-infinite-scroll.min.js'></script>
                <script>require(['dashboards/loginPageTemplate/app']);</script>
      </head>
            <div id="main">
              <h1>Set Point Values</h1>
              <div class="row">
                <div class="col-md-12">
                  <label for="xid">Xid: </label><input type="text" id="xid" value="voltage"/>
                  <label id="pointValueLabel" class="formLabel" for="pointValue">Value:</label>
                  <input id="pointValueInput" type="number" value="100.01"></input>
                  <button type="button" id="updateValue">Update</button>
              <div class="row">
                  <table class="table">
                    <tr><th>Status</th><th>Time</th></tr>
                    <tbody id="status"></tbody>
                  </table>
      <div layout="column">
      	<div ng-if="appLoading" class="app-loading">
      		<i class="fa fa-cog fa-spin"></i>
      <div layout="column" flex class="step-card" ng-controller="MyCtrl">
      	<div flex="grow" layout="column" layout-gt-xs="row">
      		<md-card flex>
      			<md-card-content>
      				<h1> Profile Creator </h1>
      				<md-p> Add steps to your profile and hit submit when done. Unless you select a time, the profile will start immediately.
      				The program will ask you to confirm that the gate valve is open and the chamber door is closed. <md-p>
      				<div layout="column" layout-padding ng-cloak ng-init="stepTypes = ['soak', 'instant change', 'ramp time', 'ramp rate']; myObj
      				= {Type: '', Hours: 0 ,Minutes: 0, Seconds: 0, SoakEnable: true}">
      				<br/>
      				<md-content class="md-padding">
      					<md-tabs md-dynamic-height md-selected="selectedIndex" md-autoselect>
      						<md-tab ng-repeat="tab in tabs"
      							ng-disabled="tab.disabled"
      							label="{{tab.title}}">
      							<div class="demo-tab tab{{$index%4}}" style="padding: 25px; text-align: center;">
      								<md-input-container class="md-block" flex-gt-sm>
      									<label>Step Type</label>
      									<md-select ng-model="tabs[$index].content.type">
      										<md-option ng-value="stepType" ng-repeat="stepType in stepTypes">{{ stepType }}</md-option>
      									</md-select>
      								</md-input-container>
      								<!--Soak Step Input-->
      								<div ng-if="tabs[$index].content.type == 'soak'">
      									<md-input-container class="md-icon-float md-icon-right md-block">
      										<label>Hours</label>
      										<input ng-model="tabs[$index].content.parameters.hours" type="number" step="1" min="0">
      										<label>Minutes</label>
      										<input ng-model="tabs[$index].content.parameters.minutes" type="number" step="1" min="0">
      										<label>Seconds</label>
      										<input ng-model="tabs[$index].content.parameters.seconds" type="number" step="1" min="0">
      								<!--Ramp Rate Step Input-->
      								<div ng-if="tabs[$index].content.type == 'ramp rate'">
      										<label>Target Set Point</label>
      										<input ng-model="tabs[$index].content.parameters.targetSetPoint" type="number" step="0.1">
      										<label>Ramp Rate (Celsius Per Min)</label>
      										<input ng-model="tabs[$index].content.parameters.rampRate" type="number" step="1" min="0">
      								<!--Ramp Time Step Input-->
      								<div ng-if="tabs[$index].content.type == 'ramp time'">
      								<!--Instant Change Input-->
      								<div ng-if="tabs[$index].content.type == 'instant change'">
      										<input ng-model="tabs[$index].content.parameters.targetSetPoint" default="0" type="number" step="0.1">
      										<input ng-model="tabs[$index].content.parameters.hours" type="number" default="0" step="1" min="0">
      										<input ng-model="tabs[$index].content.parameters.minutes" type="number" default="0" step="1" min="0">
      							<form ng-submit="addTab()" layout="column" class="md-padding" style="padding-top: 0;">
      								<div layout="row" layout-sm="column">
      									<div flex style="position: relative;">
      										<h2 class="md-subhead" style="position: absolute; bottom: 0; left: 0; margin: 0; font-weight: 500; text-transform: uppercase; line-height: 35px; white-space: nowrap;">Add a new Tab:</h2>
      									<md-button class="md-primary md-raised" ng-disabled="tabs.length <= 1" ng-click="removeTab( tabs[$index] )">Remove Step</md-button>
      									<md-button class="add-tab md-primary md-raised" ng-disabled="!tabs" type="submit" style="margin-right: 0;">Add Step</md-button>
      							</form>
      						</md-tab>
      					</md-tabs>
      				</md-content>
      					<label>Number of Profile Cycles</label>
      					<input ng-model="profile.cycles" type="number" step="1" min="1">
      				<md-input-container>
              		<label>Choose a point</label>
              		<ma-point-list limit="200" ng-model="myPoint"></ma-point-list>
          			<p>You have chosen point "{{myPoint.name}}". It is {{myPoint.enabled ? 'enabled' : 'disabled'}} and belongs to device {{myPoint.deviceName}}</p>
          			<ma-get-point-value point="myPoint"></ma-get-point-value>
      				<div> <p> {{myPoint.pointLocator.settable}} </p></div>
      				<md-button ng-click="myPoint.setValue(1771)" class="md-raised">Set to 5</md-button>
      				<md-button class="md-primary md-raised" ng-disabled="!tabs" ng-click="confirmReady()">Submit</md-button>
      				<br/>
      				<div ng-show="isReady">
      				<md-p><br/>Profile Starting</md-p><br/><br/>
      				<md-progress-linear md-mode="indeterminate"></md-progress-linear></div>
      				<pre ng-bind="profile | json"></pre>
      			</md-card-content>
      		</md-card>
      <md-card flex>
      	<md-card-content>
      		<h1> Set Point Graphs </h1>
      			<md-input-container class="md-block">
      				<ma-point-list limit="200" ng-model="point1"></ma-point-list>
      				<ma-point-list limit="200" ng-model="point2"></ma-point-list>
      				<label>Values to display</label>
      				<input type="number" min="1" max="1000" ng-model="count" ng-init="count=25">
      		<ma-point-values point="point1" values="point1Values" latest="count">
      		</ma-point-values>
      		<ma-point-values point="point2" values="point1Values2" latest="count">
      		</ma-point-values>
      		<ma-serial-chart style="height: 300px; width: 100%" series-1-values="point1Values" series-1-point="point1" series-2-values="point1Values2" series-2-point="point2">
      		</ma-serial-chart>
      	</md-card-content>
      </md-card>
      <md-card flex>
      	<md-card-content>
      	<h1> Temperature Gauges </h1>
      		<div layout="row" ng-controller="MyCtrl">
      			<div flex>
      				<p>TC 1 module 3</p>
      				<ma-get-point-value point-xid="DP_949013" point="myPoint1"></ma-get-point-value>
      				<ma-gauge-chart point="myPoint1" interval="10" start="-20" end="120" style="width:100%; height:200px"></ma-gauge-chart>
      			<div flex>
      				<p>TC 2 module 3</p>
      				<ma-get-point-value point-xid="DP_809116" point="myPoint2"></ma-get-point-value>
      				<ma-gauge-chart point="myPoint2" interval="10" start="-20" end="120" style="width:100%; height:200px"></ma-gauge-chart>
      			<div flex>
      				<p>TC 3 module 3</p>
      			<div flex>
      				<p>TC 4 module 3</p>
      			<div flex>
      				<p>TC 5 module 3</p>
      			<div flex>
      				<p>TC 6 module 3</p>
      	</md-card-content>
      </md-card>
      <p><a ui-sref="dashboard.home">Back to home page</a></p>
      <p>You have reached the home page! You are logged in as {{user.username}}.</p>
      <p><a ui-sref="dashboard.page1">Go to page 1.</a></p>
      <p><a ui-sref="login">Go to the login page.</a></p>
      Jared WiltshireJ 2 Replies Last reply Reply Quote 0
        Jared Wiltshire @avilla
        @avilla said in Help using MangoAPI to Set Point Values:
        I do not recommend trying to use the old MangoAPI 1.x and 2.x libraries inside an AngularJS application. If the issue is that you do not like the look of <ma-set-point> you can create your own AngularJS component which uses the maPoint service to set the point values.
          Have you considered just using the Dashboard Designer or Custom Pages? Are you using Mango 3?
