    Can you relativise an Excel Report? Driven by WatchList Possibly?
    4 Posts 2 Posters 2.0k Views 2 Watching
    • W Offline
      Wingnut2.0
      If I have many like devices with consistent data point naming, is there a way to apply a single excel reporting template to them? Possibly the report could be driven by DataSource/DeviceName?
      I am just thinking of the functionality of the Dynamic Watch List and how this could be applied to reporting.
      Thank you.
        Hi Wingnut,
        It's a great suggestion but not very easy at the moment. Possible, but not easy.
        Here's a scripting data source that's my off-the-cuff attempt to hack it....
        var dynamicTemplateXid="XLT_12345";
        var foundTemplate = this.foundTemplate;
        if(!foundTemplate) {
            var templates = JSON.parse(JsonEmport.getConfiguration("excel-report-templates"))["excel-report-templates"];
            for(var k = 0; k < templates.length; k+=1)
                if(templates[k].xid === dynamicTemplateXid) {
                    foundTemplate = this.foundTemplate = templates[k];
        //For simplicity, I am going to run the report on every watchlist
        // somewhat carelessly. Presumably you would want to filter down to just certain
        // watchlists. You could encode an array of XIDs here, or track an index in the
        // list if you need to break up executing the reports to multiple executions of
        // the script in a data point on the script....
        var watchLists = JSON.parse(JsonEmport.getConfiguration("watchLists")).watchLists; //You may also need to check "watchlists"
        for(var k = 0; k < watchLists.length; k+=1) {
            var watchList = watchLists[k];
            if(watchList.dataPoints.length < 2)
                continue;
            //Note that this is presuming static watchlists, but we could use the hierarchy instead
            // or try to construct queries. You could do extra work to identify points based
            // on foundTemplate.timeSeries[0].points[k].namedRange
            foundTemplate.timeSeries[0].points[0].pointXid = watchList.dataPoints[0];
            foundTemplate.timeSeries[0].points[1].pointXid = watchList.dataPoints[1];
            foundTemplate.name = "Report - " + watchList.name;
            var importText = JSON.stringify({"excel-report-templates":[foundTemplate]});
            JsonEmport.doImport(importText);
            //print(importText); print("\n\n");
            var reportTemplateVO = com.infiniteautomation.mango.excelreports.dao.ExcelReportTemplateDao.instance.getByXid(dynamicTemplateXid);
            com.infiniteautomation.mango.excelreports.rt.ExcelReportWorkItem.queueReport(reportTemplateVO, null, null, "report-script");
            RuntimeManager.sleep(3000);
        Tested and working
        • W Offline
          Wingnut2.0
          Thank you, Phil. I will try this out shortly.
          Your //notes make me think of possibly using json store to build the array. Maybe a simple page displaying watchlists or point hierarchies that the report could be applied to along with a checkbox. The array is then created by adding any checked device?
            Yeah there are definitely a lot of ways it could work. If they XIDs are programmatic or your fingers have too much sensation left, you can just have a big constant object you loop over....
            var configured = {"reportName": ["Xid-for-excelReports.timeSeries[0].points-position-0", "...-position-1"],
            } //JSON.parse(someAlphanumericPointForStorage.value); //Or yeah, use the JSON store
            for(var report in configured) {
              var points = configured[report];
              foundTeplate.name = report;
              for(var k = 0; k < points.length; k+=1)
                foundTemplate.timeSeries[0].points[k].pointXid = points[k];
              /* Do import, launch report, take a break, continue */
