    MangoEs V3 Ip address Change
    8 Posts 2 Posters 5.3k Views 1 Watching
      arvand.owji
      I have a mango version 3 box that has a static ip set previously and i want to change this ip address. When i login to the box interface, I dont see any options under the settings to change ip addresses/host name, etc. Can you please tell me where to look? Thanks.
        Here is a help article that should help : https://help.infiniteautomation.com/network-configuration/
          arvand.owji @JoelHaggar
          @joelhaggar Thanks but is this for version 3? my UI looks pretty different and there is no "MangoES configuration" under the settings.
            MangoES v2 & v3 supports the Configuration Modules on the system setting page and only MangoES v3 supports the USB utility.
            If you don't see it on the system setting page you can check to see if the module is installed and if not install it. You can do this on the new UI under Administration > Modules
            The MangoES comes default with this module installed but it's possible it was removed.
              arvand.owji
              So here is the screenshots from my admin UI. I see the config module but i dont see where to access it. 1_1502799850983_MANGO3_2.jpg 0_1502799850983_MANGO3_1.jpg
                Sorry about the confusion here. These settings are on the legacy UI system settings page and haven't been moved over to the new UI yet.
                  @joelhaggar So how can i change the IP address? IS there anyway to access the old UI on this box? Thanks.
                    The easiest way is to click on Data Sources under Adminitration. This will open up the legacy UI and then you can select System Settings from the top menu.
