<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[MangoEs V3 Ip address Change]]></title><description><![CDATA[<p dir="auto">Hi,<br />
I have a mango version 3 box that has a static ip set previously and i want to change this ip address. When i login to the box interface, I dont see any options under the settings to change ip addresses/host name, etc. Can you please tell me where to look? Thanks.</p>
]]></description><link>https://forum.mango-os.com/topic/2894/mangoes-v3-ip-address-change</link><generator>RSS for Node</generator><lastBuildDate>Wed, 20 May 2026 13:54:52 GMT</lastBuildDate><atom:link href="https://forum.mango-os.com/topic/2894.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 14 Aug 2017 14:58:54 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to MangoEs V3 Ip address Change on Tue, 15 Aug 2017 13:08:22 GMT]]></title><description><![CDATA[<p dir="auto">The easiest way is to click on Data Sources under Adminitration. This will open up the legacy UI and then you can select System Settings from the top menu.</p>
]]></description><link>https://forum.mango-os.com/post/15207</link><guid isPermaLink="true">https://forum.mango-os.com/post/15207</guid><dc:creator><![CDATA[JoelHaggar]]></dc:creator><pubDate>Tue, 15 Aug 2017 13:08:22 GMT</pubDate></item><item><title><![CDATA[Reply to MangoEs V3 Ip address Change on Tue, 15 Aug 2017 13:05:45 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/joelhaggar" aria-label="Profile: joelhaggar">@<bdi>joelhaggar</bdi></a> So how can i change the IP address? IS there anyway to access the old UI on this box? Thanks.</p>
]]></description><link>https://forum.mango-os.com/post/15206</link><guid isPermaLink="true">https://forum.mango-os.com/post/15206</guid><dc:creator><![CDATA[arvand.owji]]></dc:creator><pubDate>Tue, 15 Aug 2017 13:05:45 GMT</pubDate></item><item><title><![CDATA[Reply to MangoEs V3 Ip address Change on Tue, 15 Aug 2017 12:55:58 GMT]]></title><description><![CDATA[<p dir="auto">Sorry about the confusion here. These settings are on the legacy UI system settings page and haven't been moved over to the new UI yet.</p>
]]></description><link>https://forum.mango-os.com/post/15205</link><guid isPermaLink="true">https://forum.mango-os.com/post/15205</guid><dc:creator><![CDATA[JoelHaggar]]></dc:creator><pubDate>Tue, 15 Aug 2017 12:55:58 GMT</pubDate></item><item><title><![CDATA[Reply to MangoEs V3 Ip address Change on Tue, 15 Aug 2017 12:23:58 GMT]]></title><description><![CDATA[<p dir="auto">So here is the screenshots from my admin UI. I see the config module but i dont see where to access it. <img src="https://camo.nodebb.org/e941534a5903c56ea2c0dcefed0893364c0f1efd?url=https%3A%2F%2Fi.imgur.com%2FkxWNR0k.jpg" alt="1_1502799850983_MANGO3_2.jpg" class=" img-fluid img-markdown" /> <img src="https://camo.nodebb.org/d824c8214ceaa55b804c943863aa531e7cfb26bc?url=https%3A%2F%2Fi.imgur.com%2FAoEDIaI.jpg" alt="0_1502799850983_MANGO3_1.jpg" class=" img-fluid img-markdown" /></p>
]]></description><link>https://forum.mango-os.com/post/15204</link><guid isPermaLink="true">https://forum.mango-os.com/post/15204</guid><dc:creator><![CDATA[arvand.owji]]></dc:creator><pubDate>Tue, 15 Aug 2017 12:23:58 GMT</pubDate></item><item><title><![CDATA[Reply to MangoEs V3 Ip address Change on Mon, 14 Aug 2017 15:40:15 GMT]]></title><description><![CDATA[<p dir="auto">MangoES v2 &amp; v3 supports the Configuration Modules on the system setting page and only MangoES v3 supports the USB utility.</p>
<p dir="auto">If you don't see it on the system setting page you can check to see if the module is installed and if not install it.  You can do this on the new UI under Administration &gt; Modules</p>
<p dir="auto">The MangoES comes default with this module installed but it's possible it was removed.</p>
]]></description><link>https://forum.mango-os.com/post/15184</link><guid isPermaLink="true">https://forum.mango-os.com/post/15184</guid><dc:creator><![CDATA[JoelHaggar]]></dc:creator><pubDate>Mon, 14 Aug 2017 15:40:15 GMT</pubDate></item><item><title><![CDATA[Reply to MangoEs V3 Ip address Change on Mon, 14 Aug 2017 15:34:22 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/joelhaggar" aria-label="Profile: joelhaggar">@<bdi>joelhaggar</bdi></a> Thanks but is this for version 3? my UI looks pretty different and there is no "MangoES configuration" under the settings.</p>
]]></description><link>https://forum.mango-os.com/post/15183</link><guid isPermaLink="true">https://forum.mango-os.com/post/15183</guid><dc:creator><![CDATA[arvand.owji]]></dc:creator><pubDate>Mon, 14 Aug 2017 15:34:22 GMT</pubDate></item><item><title><![CDATA[Reply to MangoEs V3 Ip address Change on Mon, 14 Aug 2017 15:24:04 GMT]]></title><description><![CDATA[<p dir="auto">Here is a help article that should help : <a href="https://help.infiniteautomation.com/network-configuration/" rel="nofollow ugc">https://help.infiniteautomation.com/network-configuration/</a></p>
]]></description><link>https://forum.mango-os.com/post/15182</link><guid isPermaLink="true">https://forum.mango-os.com/post/15182</guid><dc:creator><![CDATA[JoelHaggar]]></dc:creator><pubDate>Mon, 14 Aug 2017 15:24:04 GMT</pubDate></item></channel></rss>
