    Run Hours
    8 Posts 3 Posters 4.6k Views 3 Watching
    • G Offline
      georgestefan
      Hi, I am using a binary point for a compressor, and I want to know if is any possibility to extract this data and to trigger an alarm after 1000h of running:
        @georgestefan you can add an event detector to detect if it stays in the same state for x hours but that wont work if the compressor turns off and on obviously. I'm sure there is a way to do what you are asking via scripting. @phildunlap should be able to help you.
          Hi George,
          There is! Runtime information is available in the StartsAndRuntimes object returned from the past() and previous() functions on data points in scripts.
          So, i could have a meta point like,
          var stats = p.past(DAY); //p is the variable name of the binary point in the context
          for(var k = 0; k < stats.data.length; k+=1) {
              if(stats.data[k].value === true)
                  return my.value + stats.data[k].runtime/3600000; //runtime given in milliseconds
          return my.value;
          running on a cron like 59 59 23 * * ? and it'll totalize once a day the hours run that day. Then you can put a limit detector on the meta point.
          G 1 Reply Last reply Reply Quote 1
          • G Offline
            georgestefan
            Thanks, I'll try this.
            • G Offline
              georgestefan @phildunlap
              @phildunlap I've created a meta point like this and when I run the script it shows me the right value, but the limit detector didn't worked
              This is the meta point:
              And I've noticed this in my data base:
              Comp_Run_H it's the meta point from above.
              Can you tel me why I don't have any value returned?
                This post is deleted!
                  Have you let this run over night? With that cron pattern it should only run on the last second of the day to produce a value.
                  • G Offline
                    georgestefan
                    Yes, that's right, at the last second of the day produce that value, I'm starting to see how this is working.
                    Thanks again!
