    Import javascript library
    sciptingjavascript
    98 Posts 3 Posters 161.0k Views 2 Watching
      arvand.owji @phildunlap
      @phildunlap
      I think you're looking for this page: https://help.infiniteautomation.com/mango-rest-api-authentication/
      If this is an ES you can sudo using the regular user's password to sudo su, you don't need to su root.
      What will be the request url? I tried to replace the localhost:8080 with my mango box url and im getting page not found error inside mango website when i try it in the browser
      http://xxxxxx.com/rest/v2/login
        It should be a POST to /rest/v2/login
        What version of Mango and the API do you have installed?
          mangoES3273
            arvand.owji
            [0_1500407785003_coolprop4.html](Uploading 100%)
            Here is the file file im experimenting with. Its pretty simple. All im doing is setting the xid = 'DP_274226';
              arvand.owji @arvand.owji
              <!DOCTYPE html>
              <html>
              <head>
              <title>Set Point Value</title>
              <!-- Add the Mango Favicon -->
              <link rel="icon" href="/images/favicon.ico">
                  <!-- Page Style -->
                  <style></style>
                  <link href="/resources/bootstrap/css/bootstrap.min.css" rel="stylesheet">
                  <link href="/modules/dashboards/web/private/css/dashboard.css" rel="stylesheet">
                  <!-- Base Library -->
                  <script type="text/javascript" src="/resources/loaderConfig.js"></script>
                  <script type="text/javascript" src="/resources/require.js"></script>
                  <script type="text/javascript" src="/resources/main.js"></script>
                  <script type="text/javascript" src="coolprop.js"></script>
                  require(['jquery', 'mango/api'],
                          function($, MangoAPI) {
                    $('#document').ready(function(){
                    	//We need the data type for the point
                    	var xid = 'DP_274226';
                    	MangoAPI.defaultApi.getPoint(xid).then(function(point){
                    		//Check to see if settable
                    		if(point.pointLocator.settable === false){
                    			var statusRow = [];
                            	statusRow.push(xid + ' not settable.');
                            	statusRow.push(new Date());
                            	//Append a status row
                            	$('#status').append(createRow(statusRow));
                            	return;
                        	var pvt = getPointValueTime(point);
                        	MangoAPI.defaultApi.putValue(xid, pvt).then(function(response){
                              	var statusRow = [];
                              	statusRow.push('Set Value For ' + xid + ' to ' + pvt.value);
                        	}).fail(MangoAPI.logError);
                    function createRow(columns){
                    	var tr = $('<tr>');
                    	for(var i=0; i<columns.length; i++){
                    		 var td = $('<td>');
                 			  td.text(columns*);
                 			  tr.append(td);
                    	return tr;
                    function getPointValueTime(dataPoint){
                    	var value = null;
              		value= Module.PropsSI('S', 'P', 55, 'T', 400, 'Nitrogen');
                    	return {
                        		value: value,
                        		timestamp: new Date().getTime(),
                        		annotation: 'Set by custom dashboard',
                        		dataType: dataPoint.pointLocator.dataType,
                  </script>
              </head>
              <body>
                <div id="main">
                  <div class="row">
                    <div class="col-md-12">
                      <table class="table">
                        <tr><th>Status</th><th>Time</th></tr>
                        <tbody id="status"></tbody>
                      </table>
              </body>
              </html>
                @arvand.owji said in Import javascript library:
                mangoES3273
                Try going to the /modules.shtm page and checking for updates. That page is also the right place to get version information. I can assume that you haven't modified it since it was shipped, but then I have to make an assumption and look up your system. It's easier for me if you report the current reality. You haven't really done anything with your data source from the json, so it doesn't make any sense it wouldn't be working.
                There was no stack trace for the timer already cancelled message, was there?
                My impression is that something is misconfigured. Otherwise, something is overridden. Can you share the output of find /opt/mango/overrides?
                If there are no upgrades, I would try starting Mango on a clean database (move your existing Mango/databases directory to Mango/databases-bck while Mango is off) and setting up a new HTTP Retriever data source in the clean environment. If that works, you could consider restoring your system from a json export or database restore if something has gone awry somehow in the database.
                Edit: If you haven't restarted Mango since those memory errors, maybe that's related? Give it a restart from the /modules.shtm page
                A 3 Replies Last reply Reply Quote 0
                  /modules.shtm
                  So my version is core 2.8.8 build 635 - paid. Obviosuly this is an older version compare to 3.1.1 and when i go to upgrades, i see a LOT of upgrades. Here is the stack trace:
                  DWR invocation exception
                  java.lang.IllegalStateException: Timer already cancelled.
                  	at com.serotonin.timer.RealTimeTimer.scheduleImpl(RealTimeTimer.java:129)
                  	at com.serotonin.timer.AbstractTimer.schedule(AbstractTimer.java:35)
                  	at com.serotonin.m2m2.util.timeout.TimeoutTask.<init>(TimeoutTask.java:63)
                  	at
                  com.serotonin.m2m2.rt.dataSource.PollingDataSource.beginPolling(PollingDataSource.java:220)
                  	at com.serotonin.m2m2.rt.RuntimeManager.startDataSourcePolling(RuntimeManager.java:363)
                  	at com.serotonin.m2m2.rt.RuntimeManager.saveDataSource(RuntimeManager.java:277)
                  	at com.serotonin.m2m2.rt.dataSource.DataSourceRTM.save(DataSourceRTM.java:54)
                  	at com.serotonin.m2m2.rt.dataSource.DataSourceRTM.save(DataSourceRTM.java:23)
                  	at com.serotonin.m2m2.web.dwr.AbstractRTDwr.toggle(AbstractRTDwr.java:53)
                  	at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
                  	at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
                  	at java.lang.reflect.Method.invoke(Method.java:498)
                  	at org.directwebremoting.impl.ExecuteAjaxFilter.doFilter(ExecuteAjaxFilter.java:34)
                  	at org.directwebremoting.impl.DefaultRemoter$1.doFilter(DefaultRemoter.java:428)
                  	at com.serotonin.m2m2.web.dwr.util.TranslationsFilter.doFilter(TranslationsFilter.java:37)
                  	at com.serotonin.m2m2.web.dwr.util.ExceptionDetectionFilter.doFilter(ExceptionDetectionFilter.java:26)
                  	at com.serotonin.m2m2.web.dwr.util.DwrPermissionFilter.doFilter(DwrPermissionFilter.java:45)
                  	at org.directwebremoting.impl.DefaultRemoter.execute(DefaultRemoter.java:431)
                  	at org.directwebremoting.impl.DefaultRemoter.execute(DefaultRemoter.java:283)
                  	at org.directwebremoting.servlet.PlainCallHandler.handle(PlainCallHandler.java:52)
                  	at org.directwebremoting.servlet.UrlProcessor.handle(UrlProcessor.java:101)
                  	at org.directwebremoting.servlet.DwrServlet.doPost(DwrServlet.java:146)
                  	at javax.servlet.http.HttpServlet.service(HttpServlet.java:707)
                  	at javax.servlet.http.HttpServlet.service(HttpServlet.java:790)
                  	at org.eclipse.jetty.servlet.ServletHolder.handle(ServletHolder.java:808)
                  	at org.eclipse.jetty.servlet.ServletHandler$CachedChain.doFilter(ServletHandler.java:1669)
                  	at org.eclipse.jetty.servlets.UserAgentFilter.doFilter(UserAgentFilter.java:83)
                  	at org.eclipse.jetty.servlets.GzipFilter.doFilter(GzipFilter.java:300)
                  	at org.eclipse.jetty.servlet.ServletHandler$CachedChain.doFilter(ServletHandler.java:1652)
                  	at org.springframework.web.filter.ShallowEtagHeaderFilter.doFilterInternal(ShallowEtagHeaderFilter.java:87)
                  	at com.serotonin.m2m2.web.filter.MangoShallowEtagHeaderFilter.doFilterInternal(MangoShallowEtagHeaderFilter.java:47)
                  	at org.springframework.web.filter.OncePerRequestFilter.doFilter(OncePerRequestFilter.java:107)
                  	at org.eclipse.jetty.servlet.ServletHandler.doHandle(ServletHandler.java:585)
                  	at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:143)
                  	at org.eclipse.jetty.security.SecurityHandler.handle(SecurityHandler.java:577)
                  	at org.eclipse.jetty.server.session.SessionHandler.doHandle(SessionHandler.java:223)
                  	at org.eclipse.jetty.server.handler.ContextHandler.doHandle(ContextHandler.java:1127)
                  	at org.eclipse.jetty.servlet.ServletHandler.doScope(ServletHandler.java:515)
                  	at org.eclipse.jetty.server.session.SessionHandler.doScope(SessionHandler.java:185)
                  	at org.eclipse.jetty.server.handler.ContextHandler.doScope(ContextHandler.java:1061)
                  	at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:141)
                  	at org.eclipse.jetty.server.handler.ContextHandlerCollection.handle(ContextHandlerCollection.java:215)
                  	at org.eclipse.jetty.server.handler.HandlerWrapper.handle(HandlerWrapper.java:97)
                  	at org.eclipse.jetty.server.Server.handle(Server.java:499)
                  	at org.eclipse.jetty.server.HttpChannel.handle(HttpChannel.java:310)
                  	at org.eclipse.jetty.server.HttpConnection.onFillable(HttpConnection.java:257)
                  	at org.eclipse.jetty.io.AbstractConnection$2.run(AbstractConnection.java:540)
                  	at org.eclipse.jetty.util.thread.QueuedThreadPool.runJob(QueuedThreadPool.java:635)
                  	at org.eclipse.jetty.util.thread.QueuedThreadPool$3.run(QueuedThreadPool.java:555)
                    /opt/mango/overrides/properties
                    /opt/mango/overrides/properties/env.properties
                    /opt/mango/overrides/classes
                      funny enough i tried to restart it from there and im getting the same timer already canceled error.
                      ERROR 2017-07-19 09:01:36,436 (com.serotonin.m2m2.web.dwr.util.ExceptionDetectionFilter.doFilter:38) - DWR invocation exception
                      	at com.serotonin.m2m2.util.timeout.TimeoutTask.<init>(TimeoutTask.java:43)
                      	at com.serotonin.m2m2.util.timeout.TimeoutTask.<init>(TimeoutTask.java:32)
                      	at com.serotonin.m2m2.Lifecycle.scheduleShutdown(Lifecycle.java:1321)
                      	at com.serotonin.m2m2.web.dwr.ModulesDwr.scheduleRestart(ModulesDwr.java:70)
                        Yeah, almost certainly restarting is all that is required. Command line restarting options on a MangoES...
                        sudo service mango reload #tell the Mango service to restart
                        sudo /opt/mango/bin/ma.sh restart #more or less what restarting the service is going to do
                        sudo /opt/mango/bin/ma.sh restart; sleep 120; if [ ! -z $(pidof java) ] && [ -e /opt/mango/RESTART ]; then sudo kill -9 $(pidof java); fi #tell Mango to restart, kill it in two minutes if it hasn't restarted
                        sudo reboot #reboot the ES
                        A 2 Replies Last reply Reply Quote 0
                          This post is deleted!
                            so after this, the site completely went down and i cant even login anymore. The Mango ES is up and in the process lists i see Mango but the web is not working. Cant even login
                              Which did you do? You probably would have to have had done one of the last two, I doubt the first two work in this case.
                              tail -n 30 /opt/mango/logs/ma.log
                              This will always kill Mango (and any other Java processes running): kill -9 $(pidof java); (edit: okay, it won't kill a process in D sleep)
                              This will start Mango with both stdout and stderr coming back to the command line, if you think Mango is having trouble starting: sudo /opt/mango/bin/ma.sh start
                                ok. that worked andi could login. I went to the htp get data source and disabled/enabled the data source and i got that timer already canceled error again :(
                                  Upload your entire ma.log file. I also provided steps for trying again on a clean setup.
                                    @phildunlap [0_1500562677214_ma.log](Uploading 100%)
                                    Thanks. Are you able to see this file that i just uploaded? Thanks.
                                      Hi Arvand,
                                      No but I just changed something that might fix it. Can you try again?
                                        @phildunlap [0_1500564092507_ma.log](Uploading 100%)
                                          Hi Arvand,
                                          i odnt think its working. i can share it on google drive an send it to you privately.
                                            Hi Arvand,
                                            Should i attempt to upgrade before trying clean?
