    Import javascript library
    sciptingjavascript
    98 Posts 3 Posters 209.0k Views 3 Watching
      arvand.owji @phildunlap
      Hi Arvand,
      Off hand I'm not quite sure. Can you possibly share the JSON for the HTTP Retriever data source that you are experiencing this with? Export it from the row in the table of data sources on /data_sources.shtm so that it also exports its points.
      Maybe im not using the right tool. I wrote a webpage that uses mango api to retrieve bunch of DPs and and then set some DPs. What i'm trying to do is to use the HTTP retriever to act like a cron job and simply send a request to that url every X minutes. I dont really care whats being oasses ot that url or what that url returns. Here is the datasrouce export. I removed the website name from the url but i have validated that the mango box has access to the url (i can ping the host from command prompt.
      "dataSources":[
      "xid":"DS_608664",
      "name":"CoolPropRet",
      "enabled":true,
      "type":"HTTP_RETRIEVER",
      "alarmLevels":{
      "DATA_RETRIEVAL_FAILURE":"URGENT",
      "POLL_ABORTED":"URGENT",
      "SET_POINT_FAILURE":"URGENT",
      "PARSE_EXCEPTION":"URGENT"
      "purgeType":"YEARS",
      "updatePeriodType":"MINUTES",
      "quantize":false,
      "retries":2,
      "setPointUrl":"",
      "timeoutSeconds":30,
      "updatePeriods":2,
      "url":"http://www.MYWEBSITE.COM:85/coolprop4.html",
      "editPermission":"",
      "purgeOverride":false,
      "purgePeriod":1
      "dataPoints":[
        arvand.owji @arvand.owji
        I also just tried http://192.168.1.125/coolprop4.html as the url and i got the same error.
          Hmm. Can you try clearing your browser cache (ctrl + shift + delete in Chrome) and deleting your Mango/work/jsp directory, then trying again?
            ia have bunch of stuff in /opt/mango/work/jsp. is it ok to delete them?
              Yeah those are compiled JSPs. It will recompile them when the pages are loaded if you delete that.
                @phildunlap my permission doesnt let me to delete them. I dont have the SU password. I tried to go another route and see if ican just invoke this from linux command prompt. "curl -ls http://xxxxxxxx". It didnt work and prompt me to try the url in another browser and there i realzied that im getting error "MANGO XHR access failed". It seems im not login and doesnt let me to make any changes (which is a good thing). How can i easily login without going through the REST API. is there anyway to login from MangoAPI jquery?
                  I think you're looking for this page: https://help.infiniteautomation.com/mango-rest-api-authentication/
                  If this is an ES you can sudo using the regular user's password to sudo su, you don't need to su root.
                  A 2 Replies Last reply Reply Quote 0
                    @phildunlap Thanks. Assuming we get the http get working, do we still need to implement the login or because mango is doignthe request, the authentication is not needed
                      arvand.owji
                      btw, i delete the folder and i still get the same error. Thanks
                        @phildunlap
                        What will be the request url? I tried to replace the localhost:8080 with my mango box url and im getting page not found error inside mango website when i try it in the browser
                        http://xxxxxx.com/rest/v2/login
                          It should be a POST to /rest/v2/login
                          What version of Mango and the API do you have installed?
                            mangoES3273
                              arvand.owji
                              [0_1500407785003_coolprop4.html](Uploading 100%)
                              Here is the file file im experimenting with. Its pretty simple. All im doing is setting the xid = 'DP_274226';
                                <!DOCTYPE html>
                                <html>
                                <head>
                                <title>Set Point Value</title>
                                <!-- Add the Mango Favicon -->
                                <link rel="icon" href="/images/favicon.ico">
                                    <!-- Page Style -->
                                    <style></style>
                                    <link href="/resources/bootstrap/css/bootstrap.min.css" rel="stylesheet">
                                    <link href="/modules/dashboards/web/private/css/dashboard.css" rel="stylesheet">
                                    <!-- Base Library -->
                                    <script type="text/javascript" src="/resources/loaderConfig.js"></script>
                                    <script type="text/javascript" src="/resources/require.js"></script>
                                    <script type="text/javascript" src="/resources/main.js"></script>
                                    <script type="text/javascript" src="coolprop.js"></script>
                                    require(['jquery', 'mango/api'],
                                            function($, MangoAPI) {
                                      $('#document').ready(function(){
                                      	//We need the data type for the point
                                      	var xid = 'DP_274226';
                                      	MangoAPI.defaultApi.getPoint(xid).then(function(point){
                                      		//Check to see if settable
                                      		if(point.pointLocator.settable === false){
                                      			var statusRow = [];
                                              	statusRow.push(xid + ' not settable.');
                                              	statusRow.push(new Date());
                                              	//Append a status row
                                              	$('#status').append(createRow(statusRow));
                                              	return;
                                          	var pvt = getPointValueTime(point);
                                          	MangoAPI.defaultApi.putValue(xid, pvt).then(function(response){
                                                	var statusRow = [];
                                                	statusRow.push('Set Value For ' + xid + ' to ' + pvt.value);
                                          	}).fail(MangoAPI.logError);
                                      function createRow(columns){
                                      	var tr = $('<tr>');
                                      	for(var i=0; i<columns.length; i++){
                                      		 var td = $('<td>');
                                   			  td.text(columns*);
                                   			  tr.append(td);
                                      	return tr;
                                      function getPointValueTime(dataPoint){
                                      	var value = null;
                                		value= Module.PropsSI('S', 'P', 55, 'T', 400, 'Nitrogen');
                                      	return {
                                          		value: value,
                                          		timestamp: new Date().getTime(),
                                          		annotation: 'Set by custom dashboard',
                                          		dataType: dataPoint.pointLocator.dataType,
                                    </script>
                                </head>
                                <body>
                                  <div id="main">
                                    <div class="row">
                                      <div class="col-md-12">
                                        <table class="table">
                                          <tr><th>Status</th><th>Time</th></tr>
                                          <tbody id="status"></tbody>
                                        </table>
                                </body>
                                </html>
                                  @arvand.owji said in Import javascript library:
                                  mangoES3273
                                  Try going to the /modules.shtm page and checking for updates. That page is also the right place to get version information. I can assume that you haven't modified it since it was shipped, but then I have to make an assumption and look up your system. It's easier for me if you report the current reality. You haven't really done anything with your data source from the json, so it doesn't make any sense it wouldn't be working.
                                  There was no stack trace for the timer already cancelled message, was there?
                                  My impression is that something is misconfigured. Otherwise, something is overridden. Can you share the output of find /opt/mango/overrides?
                                  If there are no upgrades, I would try starting Mango on a clean database (move your existing Mango/databases directory to Mango/databases-bck while Mango is off) and setting up a new HTTP Retriever data source in the clean environment. If that works, you could consider restoring your system from a json export or database restore if something has gone awry somehow in the database.
                                  Edit: If you haven't restarted Mango since those memory errors, maybe that's related? Give it a restart from the /modules.shtm page
                                  A 3 Replies Last reply Reply Quote 0
                                    /modules.shtm
                                    So my version is core 2.8.8 build 635 - paid. Obviosuly this is an older version compare to 3.1.1 and when i go to upgrades, i see a LOT of upgrades. Here is the stack trace:
                                    DWR invocation exception
                                    java.lang.IllegalStateException: Timer already cancelled.
                                    	at com.serotonin.timer.RealTimeTimer.scheduleImpl(RealTimeTimer.java:129)
                                    	at com.serotonin.timer.AbstractTimer.schedule(AbstractTimer.java:35)
                                    	at com.serotonin.m2m2.util.timeout.TimeoutTask.<init>(TimeoutTask.java:63)
                                    	at
                                    com.serotonin.m2m2.rt.dataSource.PollingDataSource.beginPolling(PollingDataSource.java:220)
                                    	at com.serotonin.m2m2.rt.RuntimeManager.startDataSourcePolling(RuntimeManager.java:363)
                                    	at com.serotonin.m2m2.rt.RuntimeManager.saveDataSource(RuntimeManager.java:277)
                                    	at com.serotonin.m2m2.rt.dataSource.DataSourceRTM.save(DataSourceRTM.java:54)
                                    	at com.serotonin.m2m2.rt.dataSource.DataSourceRTM.save(DataSourceRTM.java:23)
                                    	at com.serotonin.m2m2.web.dwr.AbstractRTDwr.toggle(AbstractRTDwr.java:53)
                                    	at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
                                    	at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
                                    	at java.lang.reflect.Method.invoke(Method.java:498)
                                    	at org.directwebremoting.impl.ExecuteAjaxFilter.doFilter(ExecuteAjaxFilter.java:34)
                                    	at org.directwebremoting.impl.DefaultRemoter$1.doFilter(DefaultRemoter.java:428)
                                    	at com.serotonin.m2m2.web.dwr.util.TranslationsFilter.doFilter(TranslationsFilter.java:37)
                                    	at com.serotonin.m2m2.web.dwr.util.ExceptionDetectionFilter.doFilter(ExceptionDetectionFilter.java:26)
                                    	at com.serotonin.m2m2.web.dwr.util.DwrPermissionFilter.doFilter(DwrPermissionFilter.java:45)
                                    	at org.directwebremoting.impl.DefaultRemoter.execute(DefaultRemoter.java:431)
                                    	at org.directwebremoting.impl.DefaultRemoter.execute(DefaultRemoter.java:283)
                                    	at org.directwebremoting.servlet.PlainCallHandler.handle(PlainCallHandler.java:52)
                                    	at org.directwebremoting.servlet.UrlProcessor.handle(UrlProcessor.java:101)
                                    	at org.directwebremoting.servlet.DwrServlet.doPost(DwrServlet.java:146)
                                    	at javax.servlet.http.HttpServlet.service(HttpServlet.java:707)
                                    	at javax.servlet.http.HttpServlet.service(HttpServlet.java:790)
                                    	at org.eclipse.jetty.servlet.ServletHolder.handle(ServletHolder.java:808)
                                    	at org.eclipse.jetty.servlet.ServletHandler$CachedChain.doFilter(ServletHandler.java:1669)
                                    	at org.eclipse.jetty.servlets.UserAgentFilter.doFilter(UserAgentFilter.java:83)
                                    	at org.eclipse.jetty.servlets.GzipFilter.doFilter(GzipFilter.java:300)
                                    	at org.eclipse.jetty.servlet.ServletHandler$CachedChain.doFilter(ServletHandler.java:1652)
                                    	at org.springframework.web.filter.ShallowEtagHeaderFilter.doFilterInternal(ShallowEtagHeaderFilter.java:87)
                                    	at com.serotonin.m2m2.web.filter.MangoShallowEtagHeaderFilter.doFilterInternal(MangoShallowEtagHeaderFilter.java:47)
                                    	at org.springframework.web.filter.OncePerRequestFilter.doFilter(OncePerRequestFilter.java:107)
                                    	at org.eclipse.jetty.servlet.ServletHandler.doHandle(ServletHandler.java:585)
                                    	at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:143)
                                    	at org.eclipse.jetty.security.SecurityHandler.handle(SecurityHandler.java:577)
                                    	at org.eclipse.jetty.server.session.SessionHandler.doHandle(SessionHandler.java:223)
                                    	at org.eclipse.jetty.server.handler.ContextHandler.doHandle(ContextHandler.java:1127)
                                    	at org.eclipse.jetty.servlet.ServletHandler.doScope(ServletHandler.java:515)
                                    	at org.eclipse.jetty.server.session.SessionHandler.doScope(SessionHandler.java:185)
                                    	at org.eclipse.jetty.server.handler.ContextHandler.doScope(ContextHandler.java:1061)
                                    	at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:141)
                                    	at org.eclipse.jetty.server.handler.ContextHandlerCollection.handle(ContextHandlerCollection.java:215)
                                    	at org.eclipse.jetty.server.handler.HandlerWrapper.handle(HandlerWrapper.java:97)
                                    	at org.eclipse.jetty.server.Server.handle(Server.java:499)
                                    	at org.eclipse.jetty.server.HttpChannel.handle(HttpChannel.java:310)
                                    	at org.eclipse.jetty.server.HttpConnection.onFillable(HttpConnection.java:257)
                                    	at org.eclipse.jetty.io.AbstractConnection$2.run(AbstractConnection.java:540)
                                    	at org.eclipse.jetty.util.thread.QueuedThreadPool.runJob(QueuedThreadPool.java:635)
                                    	at org.eclipse.jetty.util.thread.QueuedThreadPool$3.run(QueuedThreadPool.java:555)
                                      /opt/mango/overrides/properties
                                      /opt/mango/overrides/properties/env.properties
                                      /opt/mango/overrides/classes
                                        funny enough i tried to restart it from there and im getting the same timer already canceled error.
                                        ERROR 2017-07-19 09:01:36,436 (com.serotonin.m2m2.web.dwr.util.ExceptionDetectionFilter.doFilter:38) - DWR invocation exception
                                        	at com.serotonin.m2m2.util.timeout.TimeoutTask.<init>(TimeoutTask.java:43)
                                        	at com.serotonin.m2m2.util.timeout.TimeoutTask.<init>(TimeoutTask.java:32)
                                        	at com.serotonin.m2m2.Lifecycle.scheduleShutdown(Lifecycle.java:1321)
                                        	at com.serotonin.m2m2.web.dwr.ModulesDwr.scheduleRestart(ModulesDwr.java:70)
                                          Yeah, almost certainly restarting is all that is required. Command line restarting options on a MangoES...
                                          sudo service mango reload #tell the Mango service to restart
                                          sudo /opt/mango/bin/ma.sh restart #more or less what restarting the service is going to do
                                          sudo /opt/mango/bin/ma.sh restart; sleep 120; if [ ! -z $(pidof java) ] && [ -e /opt/mango/RESTART ]; then sudo kill -9 $(pidof java); fi #tell Mango to restart, kill it in two minutes if it hasn't restarted
                                          sudo reboot #reboot the ES
                                            This post is deleted!
