    Import javascript library
    sciptingjavascript
    98 Posts 3 Posters 212.2k Views 3 Watching
      arvand.owji @phildunlap
      This post is deleted!
        Yeah, almost certainly restarting is all that is required. Command line restarting options on a MangoES...
        sudo service mango reload #tell the Mango service to restart
        sudo /opt/mango/bin/ma.sh restart #more or less what restarting the service is going to do
        sudo /opt/mango/bin/ma.sh restart; sleep 120; if [ ! -z $(pidof java) ] && [ -e /opt/mango/RESTART ]; then sudo kill -9 $(pidof java); fi #tell Mango to restart, kill it in two minutes if it hasn't restarted
        sudo reboot #reboot the ES
        so after this, the site completely went down and i cant even login anymore. The Mango ES is up and in the process lists i see Mango but the web is not working. Cant even login
          Which did you do? You probably would have to have had done one of the last two, I doubt the first two work in this case.
          tail -n 30 /opt/mango/logs/ma.log
          This will always kill Mango (and any other Java processes running): kill -9 $(pidof java); (edit: okay, it won't kill a process in D sleep)
          This will start Mango with both stdout and stderr coming back to the command line, if you think Mango is having trouble starting: sudo /opt/mango/bin/ma.sh start
            ok. that worked andi could login. I went to the htp get data source and disabled/enabled the data source and i got that timer already canceled error again :(
              Upload your entire ma.log file. I also provided steps for trying again on a clean setup.
                @phildunlap [0_1500562677214_ma.log](Uploading 100%)
                Thanks. Are you able to see this file that i just uploaded? Thanks.
                  Hi Arvand,
                  No but I just changed something that might fix it. Can you try again?
                  A 3 Replies Last reply Reply Quote 0
                    @phildunlap [0_1500564092507_ma.log](Uploading 100%)
                      Hi Arvand,
                      i odnt think its working. i can share it on google drive an send it to you privately.
                        Hi Arvand,
                        Should i attempt to upgrade before trying clean?
                          I do not see Timer Already Cancelled errors in your log after you restarted Mango.
                            my bad. that was an old log. i sent you a newer one.
                              You ran out of memory using a large excel report. Are you using rollups? You should probably be watching the console output while you're developing your solution.
                                i dont understand. what i was developing is that simple httpget, unless that javascript load issue is causing issues up again.
                                  ERROR 2017-07-19 13:31:23,974 (com.serotonin.m2m2.rt.maint.BackgroundProcessing$1.run:76) - Error in work item
                                  java.lang.OutOfMemoryError: Java heap space
                                  	at org.apache.xmlbeans.impl.store.Xobj$AttrXobj.newNode(Xobj.java:2780)
                                  	at org.apache.xmlbeans.impl.store.Xobj.copyNode(Xobj.java:1112)
                                  	at org.apache.xmlbeans.impl.store.Xobj.copy_contents_from(Xobj.java:2337)
                                  	at org.apache.xmlbeans.impl.store.Xobj.copy(Xobj.java:2411)
                                  	at org.apache.xmlbeans.impl.values.XmlObjectBase._copy(XmlObjectBase.java:169)
                                  	at org.apache.xmlbeans.impl.values.XmlObjectBase._copy(XmlObjectBase.java:152)
                                  	at org.apache.xmlbeans.impl.values.XmlObjectBase.copy(XmlObjectBase.java:122)
                                  	at org.apache.poi.xssf.usermodel.XSSFRow.onDocumentWrite(XSSFRow.java:501)
                                  	at org.apache.poi.xssf.usermodel.XSSFSheet.write(XSSFSheet.java:3357)
                                  	at org.apache.poi.xssf.usermodel.XSSFSheet.commit(XSSFSheet.java:3321)
                                  	at org.apache.poi.POIXMLDocumentPart.onSave(POIXMLDocumentPart.java:464)
                                  	at org.apache.poi.POIXMLDocumentPart.onSave(POIXMLDocumentPart.java:469)
                                  	at org.apache.poi.POIXMLDocument.write(POIXMLDocument.java:211)
                                  	at com.infiniteautomation.mango.excelreports.rt.ExcelReportWorkItem.execute(ExcelReportWorkItem.java:527)
                                  	at com.serotonin.m2m2.rt.maint.BackgroundProcessing$1.run(BackgroundProcessing.java:73)
                                  if you are not using Excel Reports then delete whatever report this is and restart Mango.
                                    thanks. i deleted it and it worked. Now i see the httpget running. but the issue is that it runs only the first time (when i enable the datasource). My update period is set to 2 min but i dont see the time stamp for the virtual DP to be ever updated after that initial enable toggle button clicked, Thanks.
                                      arvand.owji @arvand.owji
                                      @arvand.owji said in Import javascript library:
                                      ok, just to be exact, it does seem that it actualy updates the DP but it doesnt do it every 2 minutes. I left it since the last post and I see the value time stamp is 13:50.
                                        ok, so the problem was that the virtual data point was set to update every 10 min and the httpget was 2 minutes. I changed virtual dp to 2 min and now its working as expected. Thanks for the help :)
                                          Nice, glad you got it figured out!
                                            arvand.owji
                                            Its been a while but i'm encountering a new issue that is very related to what we discussed here before. I developed the code and everything was working fine in the test box and i left it for few months. Didn't pay much attention until now.
                                            I have an HTTP Retriever that calls a local url (my file is in /opt/mango/web). This url, reads bunch of XIDs and then does some calculations and then sets bunch of other XIDs.
                                            My HTTP Retriever runs fine with no error (set on update every 2 minutes and I see it under Polls) but my values dont get updated. Its as if the code is not running. I dont see any errors in ma.log and so far i coudln't see any indication of an issue. Even when i enable/disable the data source, i still dont see the data being updated (in ma.log, i see the data source being disabled/enabled with no issue).
                                            To test the url for the http retriever, i manually ran it in a browser and it actually updated the values but if i do "curl" from the mango command prompt, i dont see the values being updated.
                                            Where can i see the actual result from HTTP Retriever, is there a log for it? Thanks.
