    78 Posts 3 Posters 96.9k Views 2 Watching
      Hi Jose,
      I wouldn't expect the issue you're describing to be resolved by upgrading. But, you probably have an error in startup that we could see if you attempted to start Mango manually on the command line.
      So navigate to Mango/bin and run either ./ma.sh start or ma-start.bat
      Actually figuring out what's going on in your situation may be too difficult through the forum. I understand the issue to be something like...
      1. Mango 1 polls a data source
      2. Many points links set a point on Mango 1 many times.
      3. The values of that point are published through an HTTP publisher
      4. The receiving end is not ending up with the same set of data as the sending end, but no errors are being recorded on either Mango
      There's a lot to explore there.
        jmatos
        here is the result
        mango@mangoES3249:/opt/mango/bin$sudo ./ma.sh start
        sudo: unable to resolve host mangoES3249
        [sudo] password for mango:
        sudo: ./ma.sh: command not found
        mango@mangoES3249:/opt/mango/bin$ma.sh start
        -bash: ma.sh: command not found
        mango@mangoES3249:/opt/mango/bin$dir
        ext-available  ext-enabled  h2-web-console.bat  h2-web-console.sh  ma-init.sh  ma.pid  ma-restart.sh  ma.sh  ma-start.bat  ma-start.sh  ma-stop.sh  upgrade.bat  upgrade.sh
          Try...
          sudo /opt/mango/bin/ma.sh start
          sudo su; ./ma.sh start
            It's possible ma.sh isn't executable, do sudo chmod +x /opt/mango/bin/ma.sh
              jmatos
              to all I get the same result:
              unless for
              where I get the PuTTY screen again - with the calendar, cpu info, etc. - as when I entered
                You would do the ./ma.sh start after the sudo su scrolls by the login screen again. When you're root@mangoES3249:~
                Hmm. That message suggests something is amiss in your /etc/hosts or /etc/hostname file. I bet you've got a line like 127.0.1.1 mangoes in your /etc/hosts file, where you'd want to change it to 127.0.1.1 mangoES3249 then log out and in again. The unable to resolve host message should be gone.
                  jmatos @phildunlap
                  @phildunlap
                  you have right with the issue 127.0.1.1 mangoes. I fix it but then I get
                  root@mangoES3249:/opt/mango/bin$./ma.sh start
                  MA_HOME is /opt/mango
                  ./ma.sh: line 31: /opt/mango/bin/ma-start.sh: Permission denied
                    sudo chmod +x /opt/mango/bin/*.sh
                      jmatos
                      It works!!!
                      What could be wrong?
                      Thank you very much. I can sleep better this night :)
                        Well, the upgrade could have failed during the unzip, then it probably wouldn't have chmod'ed the bin directory properly. I would wonder if anything else did occur properly in the upgrade process.
                          jmatos
                          After the upgrade I get
                          ???systemSettings.noSqlDatabaseSize(i18n_pt_PT)???
                          in the System settings > System Information section when refreshing the database size.
                          Should I worry about or is only a none translated item?
                            It is just a missing translations key. it was missing from the base translation file even, which is why you saw that instead of English.
                              jmatos
                              please answer to the issue about the license that I sent you to support.
                              Thank you
                                I have answered your email.
                                  jmatos
                                  Now within MANGO v3 UI, once in awhile I see the following messages in the bottom screen:
                                  connectivity lost... ok
                                  (after 2 sec)
                                  connectivity to MANGO API as been restored
                                  My mangoApi module is 3.1.1
                                  Once mangoNoSqlDatabase is depending on it, could this be in any way related to the problem that we have? (please see bellow reminder text). Is there any log where I can see more info? I search in the ma-log and found nothing.
                                  (reminder)
                                  let me remind you: when more than two simultaneous BACnet devices have it value switched only aleatory two reach's the http publisher. This is the only issue that holding us down to close the project... :-(
                                  Thank you,
                                  Jose
                                    Hi Jose,
                                    I probably can't solve the simultaneous alarms issue through the forum, since I don't really have a clear idea of what's going on and would have to investigate. You could contact us about direct support on that issue.
                                    You can probably get more information about why it's displaying that connectivity message if you watch the browser developer tools' network tab. My guess is some requests are timing out or erroring. You could also consider enabling debug logging by switching the log4j2.xml files in Mango/classes/ and reloading your logging settings, either in the Log4J Reset section of /system_settings.shtm or by restarting Mango.
                                    I would not expect it to be related to the dependency of the NoSQL database on the API. It just provided a new set of endpoints for saving point-time-jsonObject information, shouldn't affect existing things as I'm not aware of any built in features using that database yet.
                                      jmatos
                                      I will come back to the simultaneous alarm issue after I collect some more info.
                                      meanwhile, after upgrade to MANGO v 3...
                                      A) In Home I can not see the number of datasources, datapoints, etc. in the up right corner of the square. Also, Active Sessions, Event Detectors and Mailing Lists are not clickable.
                                      B) !!systemSettings.lastUpgrade!! in Administration > System settings > System information, with 1500555481 as date.
                                      and this one, last two from ma.log?
                                      WARN  2017-07-24T14:50:10,495 (com.serotonin.m2m2.util.timeout.TaskRejectionHandler.rejectedTask:77) - Rejected task: User event cache cleaner because Task Queue Full
                                      ERROR 2017-07-24T14:50:10,497 (com.infiniteautomation.nosql.MangoNoSqlBatchWriteBehindManager$StatusProvider.scheduleTimeout:726) - 7 BWB Task Failures, first is: Task Queue Full
                                      thank you very much,
                                      Jose
                                        A) The numbers will only appear if you have a configured internal data source. You can reinstall the internal data source and it should create it for you.
                                        B) This has been fixed.
                                        I wouldn't expect either of those log messages to cause you problems, but you can probably make them go away by changing...
                                        runtime.realTimeTimer.defaultTaskQueueSize=0 to runtime.realTimeTimer.defaultTaskQueueSize=2
                                        in your env.properties file and restarting Mango.
                                          jmatos
                                          Hi Phil,
                                          I send you a message to support.
                                          Thank you,
                                          Jose
                                            I sent you a reply.
