    CRUD for data sources
    10 Posts 4 Posters 3.7k Views 3 Watching
    • H Offline
      hrivers
      I'm having issues with the cURL call to create a data source. This is the code I'm using-- the authentication part has worked in other areas, but now. while I'm getting TRUE for the second curl_execl, I'm getting an HTTP status of 403. If I set CURLOPT_POST to 0 I get data returned correctly for a GET, so I seem to be authenticated just fine. It seems that the POST is the part I'm having problems with. I've used the swagger page with no issue and have created my $devices array directly from data that worked there (changing the xid). I'm not sure what's wrong with the POST that it doesn't work.
      $curl = curl_init();
      $headers = array(
      'Accept: application/json',
      'Accept-Encoding: gzip',
      'Accept-Language: en-US,en;q=0.5',
      'Connection: keep-alive',
      'Cache-Control: no-cache',
      'password: admin',
      'logout: true'
      curl_setopt_array($curl, array(
      CURLOPT_RETURNTRANSFER => TRUE,
      CURLOPT_HEADER => TRUE,
      CURLOPT_VERBOSE => TRUE,
      CURLOPT_HTTPHEADER => $headers,
      CURLOPT_URL => 'http://<url>:8080/rest/v1/login/admin'
      $response = curl_exec($curl);
      $tmp = explode('XSRF-TOKEN=', $response);
      $tmp = explode(';',$tmp[1]);
      $xsrf_token = $tmp[0];
      $tmp = explode('MANGO8080=', $response);
      $mango8080 = $tmp[0];
      curl_close($curl);
      $headers = array(
      'Content-Type: application/json', //multipart/form-data
      'Cookie: XSRF-TOKEN='.$xsrf_token.';MANGO8080='.$mango8080
      //CURLOPT_RETURNTRANSFER => TRUE,
      CURLOPT_POST => TRUE,
      CURLOPT_POSTFIELDS => $device, //HERE either $device or http_build_query($device) which yields 'xid=DS_HR_POST&name=HR_TEST_MIN_VARS_POST&modelType=SNMP&host=<url>'
      CURLOPT_URL => 'http://<url>:8080/rest/v1/data-sources'
      error_log(json_encode(curl_getinfo($curl)));
      error_log($response);
      curl_close($curl);
      curl_getinfo printout:
      {"url":"http://<url>.:8080/rest/v1/data-sources","content_type":null,"http_code":403,"header_size":291,"request_size":359,"filetime":-1,"ssl_verify_result":0,"redirect_count":0,"total_time":0.004956,"namelookup_time":7.7e-5,"connect_time":0.000631,"pretransfer_time":0.000642,"size_upload":0,"size_download":0,"speed_download":0,"speed_upload":0,"download_content_length":0,"upload_content_length":473,"starttransfer_time":0.00491,"redirect_time":0,"certinfo":[]}
      $response printout: 1 this way, blank if CURLOPT_RETURNTRANSFER = TRUE
      • G Offline
        gary @hrivers
        @hrivers In my experience with the Mango API, sometimes you need to include the header 'x-xsrf-token' as well as the cookies.
        Try this modification:
        $headers = array(
        'Cookie: XSRF-TOKEN='.$xsrf_token.';MANGO8080='.$mango8080,
        'x-xsrf-token: ' . $xsrf_token             //ADDED
        Gary
        • H Offline
          hrivers @gary
          @gary said in CRUD for data sources:
          That gives me a status 400 with the following message:
          {"message":"Unexpected character ('-' (code 45)) in numeric value: expected digit (0-9) to follow minus sign, for valid numeric value\n at [Source: java.io.PushbackInputStream@2f3c2d0; line: 1, column: 3]","stackTrace":"com.fasterxml.jackson.core.JsonParser._constructError(JsonParser.java:1419)\ncom.fasterxml.jackson.core.base.ParserMinimalBase._reportError(ParserMinimalBase.java:508)\ncom.fasterxml.jackson.core.base.ParserBase.reportUnexpectedNumberChar(ParserBase.java:939)\ncom.fasterxml.jackson.core.json.UTF8StreamJsonParser._handleInvalidNumberStart(UTF8StreamJsonParser.java:2487)\ncom.fasterxml.jackson.core.json.UTF8StreamJsonParser._parseNegNumber(UTF8StreamJsonParser.java:1245)\ncom.fasterxml.jackson.core.json.UTF8StreamJsonParser._nextTokenNotInObject(UTF8StreamJsonParser.java:777)\ncom.fasterxml.jackson.core.json.UTF8StreamJsonParser.nextToken(UTF8StreamJsonParser.java:690)\ncom.fasterxml.jackson.databind.ObjectMapper._initForReading(ObjectMapper.java:3090)\ncom.fasterxml.jackson.databind.ObjectMapper._readMapAndClose(ObjectMapper.java:3036)\ncom.fasterxml.jackson.databind.ObjectMapper.readValue(ObjectMapper.java:2206)\norg.springframework.http.converter.json.AbstractJackson2HttpMessageConverter.readJavaType(AbstractJackson2HttpMessageConverter.java:221)\norg.springframework.http.converter.json.AbstractJackson2HttpMessageConverter.read(AbstractJackson2HttpMessageConverter.java:208)\norg.springframework.web.servlet.mvc.method.annotation.AbstractMessageConverterMethodArgumentResolver.readWithMessageConverters(AbstractMessageConverterMethodArgumentResolver.java:197)\norg.springframework.web.servlet.mvc.method.annotation.RequestResponseBodyMethodProcessor.readWithMessageConverters(RequestResponseBodyMethodProcessor.java:147)\norg.springframework.web.servlet.mvc.method.annotation.RequestResponseBodyMethodProcessor.resolveArgument(RequestResponseBodyMethodProcessor.java:125)\norg.springframework.web.method.support.HandlerMethodArgumentResolverComposite.resolveArgument(HandlerMethodArgumentResolverComposite.java:78)\norg.springframework.web.method.support.InvocableHandlerMethod.getMethodArgumentValues(InvocableHandlerMethod.java:162)\norg.springframework.web.method.support.InvocableHandlerMethod.invokeForRequest(InvocableHandlerMethod.java:129)\norg.springframework.web.servlet.mvc.method.annotation.ServletInvocableHandlerMethod.invokeAndHandle(ServletInvocableHandlerMethod.java:110)\norg.springframework.web.servlet.mvc.method.annotation.RequestMappingHandlerAdapter.invokeHandlerMethod(RequestMappingHandlerAdapter.java:806)\norg.springframework.web.servlet.mvc.method.annotation.RequestMappingHandlerAdapter.handleInternal(RequestMappingHandlerAdapter.java:729)\norg.springframework.web.servlet.mvc.method.AbstractHandlerMethodAdapter.handle(AbstractHandlerMethodAdapter.java:85)\norg.springframework.web.servlet.DispatcherServlet.doDispatch(DispatcherServlet.java:959)\norg.springframework.web.servlet.DispatcherServlet.doService(DispatcherServlet.java:893)\norg.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:970)\norg.springframework.web.servlet.FrameworkServlet.doPost(FrameworkServlet.java:872)\njavax.servlet.http.HttpServlet.service(HttpServlet.java:707)\norg.springframework.web.servlet.FrameworkServlet.service(FrameworkServlet.java:846)\njavax.servlet.http.HttpServlet.service(HttpServlet.java:790)\norg.eclipse.jetty.servlet.ServletHolder.handle(ServletHolder.java:845)\norg.eclipse.jetty.servlet.ServletHandler$CachedChain.doFilter(ServletHandler.java:1689)\norg.eclipse.jetty.servlets.GzipFilter.doFilter(GzipFilter.java:51)\norg.eclipse.jetty.servlet.ServletHandler$CachedChain.doFilter(ServletHandler.java:1676)\norg.springframework.web.filter.CharacterEncodingFilter.doFilterInternal(CharacterEncodingFilter.java:85)\norg.springframework.web.filter.OncePerRequestFilter.doFilter(OncePerRequestFilter.java:107)\norg.eclipse.jetty.servlet.ServletHandler$CachedChain.doFilter(ServletHandler.java:1676)\norg.springframework.web.filter.ShallowEtagHeaderFilter.doFilterInternal(ShallowEtagHeaderFilter.java:87)\ncom.serotonin.m2m2.web.filter.MangoShallowEtagHeaderFilter.doFilterInternal(MangoShallowEtagHeaderFilter.java:47)\norg.springframework.web.filter.OncePerRequestFilter.doFilter(OncePerRequestFilter.java:107)\norg.eclipse.jetty.servlet.ServletHandler$CachedChain.doFilter(ServletHandler.java:1676)\norg.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:317)\norg.springframework.security.web.access.intercept.FilterSecurityInterceptor.invoke(FilterSecurityInterceptor.java:127)\norg.springframework.security.web.access.intercept.FilterSecurityInterceptor.doFilter(FilterSecurityInterceptor.java:91)\norg.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:331)\norg.springframework.security.web.access.ExceptionTranslationFilter.doFilter(ExceptionTranslationFilter.java:115)\norg.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:331)\norg.springframework.security.web.session.SessionManagementFilter.doFilter(SessionManagementFilter.java:137)\norg.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:331)\norg.springframework.security.web.authentication.AnonymousAuthenticationFilter.doFilter(AnonymousAuthenticationFilter.java:111)\norg.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:331)\norg.springframework.security.web.servletapi.SecurityContextHolderAwareRequestFilter.doFilter(SecurityContextHolderAwareRequestFilter.java:169)\norg.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:331)\norg.springframework.security.web.savedrequest.RequestCacheAwareFilter.doFilter(RequestCacheAwareFilter.java:63)\norg.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:331)\norg.springframework.security.web.authentication.logout.LogoutFilter.doFilter(LogoutFilter.java:121)\norg.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:331)\ncom.serotonin.m2m2.web.mvc.spring.security.CsrfHeaderFilter.doFilterInternal(CsrfHeaderFilter.java:41)\norg.springframework.web.filter.OncePerRequestFilter.doFilter(OncePerRequestFilter.java:107)\norg.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:331)\norg.springframework.security.web.csrf.CsrfFilter.doFilterInternal(CsrfFilter.java:124)\norg.springframework.web.filter.OncePerRequestFilter.doFilter(OncePerRequestFilter.java:107)\norg.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:331)\norg.springframework.security.web.header.HeaderWriterFilter.doFilterInternal(HeaderWriterFilter.java:66)\norg.springframework.web.filter.OncePerRequestFilter.doFilter(OncePerRequestFilter.java:107)\norg.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:331)\norg.springframework.security.web.context.SecurityContextPersistenceFilter.doFilter(SecurityContextPersistenceFilter.java:105)\norg.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:331)\norg.springframework.security.web.context.request.async.WebAsyncManagerIntegrationFilter.doFilterInternal(WebAsyncManagerIntegrationFilter.java:56)\norg.springframework.web.filter.OncePerRequestFilter.doFilter(OncePerRequestFilter.java:107)\norg.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:331)\norg.springframework.security.web.FilterChainProxy.doFilterInternal(FilterChainProxy.java:214)\norg.springframework.security.web.FilterChainProxy.doFilter(FilterChainProxy.java:177)\norg.springframework.web.filter.DelegatingFilterProxy.invokeDelegate(DelegatingFilterProxy.java:346)\norg.springframework.web.filter.DelegatingFilterProxy.doFilter(DelegatingFilterProxy.java:262)\norg.eclipse.jetty.servlet.ServletHandler$CachedChain.doFilter(ServletHandler.java:1668)\norg.eclipse.jetty.servlet.ServletHandler.doHandle(ServletHandler.java:581)\norg.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:143)\norg.eclipse.jetty.security.SecurityHandler.handle(SecurityHandler.java:548)\norg.eclipse.jetty.server.session.SessionHandler.doHandle(SessionHandler.java:226)\norg.eclipse.jetty.server.handler.ContextHandler.doHandle(ContextHandler.java:1180)\norg.eclipse.jetty.servlet.ServletHandler.doScope(ServletHandler.java:511)\norg.eclipse.jetty.server.session.SessionHandler.doScope(SessionHandler.java:185)\norg.eclipse.jetty.server.handler.ContextHandler.doScope(ContextHandler.java:1112)\norg.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:141)\norg.eclipse.jetty.server.handler.ContextHandlerCollection.handle(ContextHandlerCollection.java:213)\norg.eclipse.jetty.server.handler.HandlerWrapper.handle(HandlerWrapper.java:134)\norg.eclipse.jetty.server.Server.handle(Server.java:524)\norg.eclipse.jetty.server.HttpChannel.handle(HttpChannel.java:319)\norg.eclipse.jetty.server.HttpConnection.onFillable(HttpConnection.java:253)\norg.eclipse.jetty.io.AbstractConnection$ReadCallback.succeeded(AbstractConnection.java:273)\norg.eclipse.jetty.io.FillInterest.fillable(FillInterest.java:95)\norg.eclipse.jetty.io.SelectChannelEndPoint$2.run(SelectChannelEndPoint.java:93)\norg.eclipse.jetty.util.thread.strategy.ExecuteProduceConsume.executeProduceConsume(ExecuteProduceConsume.java:303)\norg.eclipse.jetty.util.thread.strategy.ExecuteProduceConsume.produceConsume(ExecuteProduceConsume.java:148)\norg.eclipse.jetty.util.thread.strategy.ExecuteProduceConsume.run(ExecuteProduceConsume.java:136)\norg.eclipse.jetty.util.thread.QueuedThreadPool.runJob(QueuedThreadPool.java:671)\norg.eclipse.jetty.util.thread.QueuedThreadPool$2.run(QueuedThreadPool.java:589)\njava.lang.Thread.run(Thread.java:745)\n"}
            As @gary has pointed out, you are running up against the CSRF protection. CRSF protection only affects POST requests which is why your GET request is working.
            You need to read the XSRF-TOKEN cookie which the server tells you to set and then send that back to the server with every request as a 'X-XSRF-TOKEN' header.
            We are going to make this easier in Mango 3.0 by implementing token authentication which will not require CSRF protection.
            • H Offline
              hrivers @Jared Wiltshire
              @Jared-Wiltshire When I modified my code to add that, I get an error stating there's an unexpected character in numeric value: expected digit (0-9) to follow minus sign, for valid numeric value. Is this my xsrf token or an issue with the post data? My xsrf token is an alphanumeric string with hypens, and my device is defined as follows:
              $device = array(
              "xid" => "DS_HR_POST",
              "name" => "HR TEST MIN VARS POST",
              "modelType" => "SNMP",
              "host" => "<valid ip address>"
                @hrivers said in CRUD for data sources:
                $device = array(
                Looks like an issue with the POST body, its a JSON parsing error.
                • H Offline
                  @Jared-Wiltshire I re-wrote my cURL query as follows:
                  $headers = array(
                  'Content-Type: multipart/form-data', //as opposed to application/json
                  'X-XSRF-TOKEN:'.$xsrf_token
                  			CURLOPT_POSTFIELDS => http_build_query($device), //as opposed to $device
                  and in return I got a new error: Could not parse multipart servlet request; nested exception is org.apache.commons.fileupload.FileUploadException: the request was rejected because no multipart boundary was found
                  Have you seen this before? Do you have any suggestions?
                    Hi hrivers,
                    Your Content-Type header should be application/json
                    Here is a successful POST to /rest/v1/data-sources creating an HTTP Receiver made through swagger, gotten from the network tab of the developer tools in the browser:
                    POST /rest/v1/data-sources HTTP/1.1
                    Host: localhost:8080
                    Content-Length: 534
                    Pragma: no-cache
                    Origin: http://localhost:8080
                    X-Xsrf-Token: [xsrf-token-value]
                    User-Agent: Mozilla/5.0 (Windows NT 6.3; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/56.0.2924.87 Safari/537.36
                    Referer: http://localhost:8080/swagger/
                    Accept-Encoding: gzip, deflate, br
                    Accept-Language: en-US,en;q=0.8
                    Cookie: XSRF-TOKEN=[xsrf-token-value]; MANGO8080=[cookie-value]
                          "xid": "DS_7845792",
                          "name": "http",
                          "enabled": false,
                          "modelType": "HTTP_RECEIVER",
                          "validationMessages": [],
                          "setPointUrl": "",
                          "ipWhiteList": [
                          "deviceIdWhiteList": [
                          "editPermission": "",
                          "purgeSettings": {
                            "override": false,
                            "frequency": {
                              "periods": 1,
                              "type": "YEARS"
                          "alarmLevels": {
                            "SET_POINT_FAILURE": "URGENT"
                    • H Offline
                      hrivers @phildunlap
                      I fixed it-- the issue was that $devices needed to be json_encode()'ed when being sent via CURLOPT_POSTFIELDS (as well as Content-Type: application/json)
                        Glad to hear it, thanks for sharing the resolution!
