<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[CRUD for data sources]]></title><description><![CDATA[<p dir="auto">I'm having issues with the cURL call to create a data source. This is the code I'm using-- the authentication part has worked in other areas, but now. while I'm getting TRUE for the second curl_execl, I'm getting an HTTP status of 403. If I set CURLOPT_POST to 0 I get data returned correctly for a GET, so I seem to be authenticated just fine. It seems that the POST is the part I'm having problems with. I've used the swagger page with no issue and have created my $devices array directly from data that worked there (changing the xid). I'm not sure what's wrong with the POST that it doesn't work.</p>
<p dir="auto">$curl = curl_init();</p>
<p dir="auto">$headers = array(<br />
'Accept: application/json',<br />
'Accept-Encoding: gzip',<br />
'Accept-Language: en-US,en;q=0.5',<br />
'Connection: keep-alive',<br />
'Cache-Control: no-cache',<br />
'password: admin',<br />
'logout: true'<br />
);</p>
<p dir="auto">curl_setopt_array($curl, array(<br />
CURLOPT_RETURNTRANSFER =&gt; TRUE,<br />
CURLOPT_HEADER =&gt; TRUE,<br />
CURLOPT_VERBOSE =&gt; TRUE,<br />
CURLOPT_HTTPHEADER =&gt; $headers,<br />
CURLOPT_URL =&gt; 'http://&lt;url&gt;:8080/rest/v1/login/admin'<br />
));</p>
<p dir="auto">$response = curl_exec($curl);<br />
$tmp = explode('XSRF-TOKEN=', $response);<br />
$tmp = explode(';',$tmp[1]);<br />
$xsrf_token = $tmp[0];<br />
$tmp = explode('MANGO8080=', $response);<br />
$mango8080 = $tmp[0];<br />
curl_close($curl);</p>
'Content-Type: application/json', //multipart/form-data<br />
'Cookie: XSRF-TOKEN='.$xsrf_token.';MANGO8080='.$mango8080<br />
);</p>
//CURLOPT_RETURNTRANSFER =&gt; TRUE,<br />
CURLOPT_POST =&gt; TRUE,<br />
CURLOPT_POSTFIELDS =&gt; $device, //HERE either $device or http_build_query($device) which yields 'xid=DS_HR_POST&amp;name=HR_TEST_MIN_VARS_POST&amp;modelType=SNMP&amp;host=&lt;url&gt;'<br />
CURLOPT_URL =&gt; 'http://&lt;url&gt;:8080/rest/v1/data-sources'<br />
));</p>
error_log(json_encode(curl_getinfo($curl)));<br />
error_log($response);<br />
<p dir="auto">curl_getinfo printout:</p>
<p dir="auto">{"url":"http://&lt;url&gt;.:8080/rest/v1/data-sources","content_type":null,"http_code":403,"header_size":291,"request_size":359,"filetime":-1,"ssl_verify_result":0,"redirect_count":0,"total_time":0.004956,"namelookup_time":7.7e-5,"connect_time":0.000631,"pretransfer_time":0.000642,"size_upload":0,"size_download":0,"speed_download":0,"speed_upload":0,"download_content_length":0,"upload_content_length":473,"starttransfer_time":0.00491,"redirect_time":0,"certinfo":[]}</p>
<p dir="auto">$response printout: 1 this way, blank if CURLOPT_RETURNTRANSFER = TRUE</p>
]]></description><link>https://forum.mango-os.com/topic/2697/crud-for-data-sources</link><generator>RSS for Node</generator><lastBuildDate>Tue, 19 May 2026 21:28:57 GMT</lastBuildDate><atom:link href="https://forum.mango-os.com/topic/2697.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 06 Mar 2017 16:07:49 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to CRUD for data sources on Mon, 06 Mar 2017 19:14:14 GMT]]></title><description><![CDATA[<p dir="auto">Glad to hear it, thanks for sharing the resolution!</p>
]]></description><link>https://forum.mango-os.com/post/14053</link><guid isPermaLink="true">https://forum.mango-os.com/post/14053</guid><dc:creator><![CDATA[phildunlap]]></dc:creator><pubDate>Mon, 06 Mar 2017 19:14:14 GMT</pubDate></item><item><title><![CDATA[Reply to CRUD for data sources on Mon, 06 Mar 2017 19:09:24 GMT]]></title><description><![CDATA[<p dir="auto">I fixed it-- the issue was that $devices needed to be json_encode()'ed when being sent via CURLOPT_POSTFIELDS (as well as Content-Type: application/json)</p>
]]></description><link>https://forum.mango-os.com/post/14052</link><guid isPermaLink="true">https://forum.mango-os.com/post/14052</guid><dc:creator><![CDATA[hrivers]]></dc:creator><pubDate>Mon, 06 Mar 2017 19:09:24 GMT</pubDate></item><item><title><![CDATA[Reply to CRUD for data sources on Mon, 06 Mar 2017 17:37:38 GMT]]></title><description><![CDATA[<p dir="auto">Hi hrivers,</p>
<p dir="auto">Your Content-Type header should be application/json</p>
<p dir="auto">Here is a successful POST to /rest/v1/data-sources creating an HTTP Receiver made through swagger, gotten from the network tab of the developer tools in the browser:</p>
<pre><code>POST /rest/v1/data-sources HTTP/1.1
Host: localhost:8080
Content-Length: 534
Pragma: no-cache
Origin: http://localhost:8080
X-Xsrf-Token: [xsrf-token-value]
User-Agent: Mozilla/5.0 (Windows NT 6.3; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/56.0.2924.87 Safari/537.36
Referer: http://localhost:8080/swagger/
Accept-Encoding: gzip, deflate, br
Accept-Language: en-US,en;q=0.8
Cookie: XSRF-TOKEN=[xsrf-token-value]; MANGO8080=[cookie-value]
      "xid": "DS_7845792",
      "name": "http",
      "enabled": false,
      "modelType": "HTTP_RECEIVER",
      "validationMessages": [],
      "setPointUrl": "",
      "ipWhiteList": [
      "deviceIdWhiteList": [
      "editPermission": "",
      "purgeSettings": {
        "override": false,
        "frequency": {
          "periods": 1,
          "type": "YEARS"
      "alarmLevels": {
        "SET_POINT_FAILURE": "URGENT"
]]></description><link>https://forum.mango-os.com/post/14051</link><guid isPermaLink="true">https://forum.mango-os.com/post/14051</guid><dc:creator><![CDATA[phildunlap]]></dc:creator><pubDate>Mon, 06 Mar 2017 17:37:38 GMT</pubDate></item><item><title><![CDATA[Reply to CRUD for data sources on Mon, 06 Mar 2017 17:06:48 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/jared-wiltshire" aria-label="Profile: Jared-Wiltshire">@<bdi>Jared-Wiltshire</bdi></a> I re-wrote my cURL query as follows:</p>
'Content-Type: multipart/form-data', //as opposed to application/json<br />
'Cookie: XSRF-TOKEN='.$xsrf_token.';MANGO8080='.$mango8080,<br />
'X-XSRF-TOKEN:'.$xsrf_token<br />
);</p>
<pre><code>		curl_setopt_array($curl, array(
			CURLOPT_POSTFIELDS =&gt; http_build_query($device), //as opposed to $device
<p dir="auto">and in return I got a new error: Could not parse multipart servlet request; nested exception is org.apache.commons.fileupload.FileUploadException: the request was rejected because no multipart boundary was found</p>
<p dir="auto">Have you seen this before? Do you have any suggestions?</p>
]]></description><link>https://forum.mango-os.com/post/14050</link><guid isPermaLink="true">https://forum.mango-os.com/post/14050</guid><dc:creator><![CDATA[hrivers]]></dc:creator><pubDate>Mon, 06 Mar 2017 17:06:48 GMT</pubDate></item><item><title><![CDATA[Reply to CRUD for data sources on Mon, 06 Mar 2017 16:59:55 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/hrivers" aria-label="Profile: hrivers">@<bdi>hrivers</bdi></a> said in <a href="/forum/post/14046">CRUD for data sources</a>:</p>
<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/jared-wiltshire" aria-label="Profile: Jared-Wiltshire">@<bdi>Jared-Wiltshire</bdi></a> When I modified my code to add that, I get an error stating there's an unexpected character in numeric value: expected digit (0-9) to follow minus sign, for valid numeric value. Is this my xsrf token or an issue with the post data? My xsrf token is an alphanumeric string with hypens, and my device is defined as follows:</p>
<p dir="auto">$device = array(<br />
"xid" =&gt; "DS_HR_POST",<br />
"name" =&gt; "HR TEST MIN VARS POST",<br />
"modelType" =&gt; "SNMP",<br />
"host" =&gt; "&lt;valid ip address&gt;"<br />
);</p>
<p dir="auto">Looks like an issue with the POST body, its a JSON parsing error.</p>
]]></description><link>https://forum.mango-os.com/post/14047</link><guid isPermaLink="true">https://forum.mango-os.com/post/14047</guid><dc:creator><![CDATA[Jared Wiltshire]]></dc:creator><pubDate>Mon, 06 Mar 2017 16:59:55 GMT</pubDate></item><item><title><![CDATA[Reply to CRUD for data sources on Mon, 06 Mar 2017 16:59:06 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/jared-wiltshire" aria-label="Profile: Jared-Wiltshire">@<bdi>Jared-Wiltshire</bdi></a> When I modified my code to add that, I get an error stating there's an unexpected character in numeric value: expected digit (0-9) to follow minus sign, for valid numeric value. Is this my xsrf token or an issue with the post data? My xsrf token is an alphanumeric string with hypens, and my device is defined as follows:</p>
);</p>
]]></description><link>https://forum.mango-os.com/post/14046</link><guid isPermaLink="true">https://forum.mango-os.com/post/14046</guid><dc:creator><![CDATA[hrivers]]></dc:creator><pubDate>Mon, 06 Mar 2017 16:59:06 GMT</pubDate></item><item><title><![CDATA[Reply to CRUD for data sources on Mon, 06 Mar 2017 16:51:50 GMT]]></title><description><![CDATA[<p dir="auto">As <a class="plugin-mentions-user plugin-mentions-a" href="/user/gary" aria-label="Profile: gary">@<bdi>gary</bdi></a> has pointed out, you are running up against the CSRF protection. CRSF protection only affects POST requests which is why your GET request is working.</p>
<p dir="auto">You need to read the XSRF-TOKEN cookie which the server tells you to set  and then send that back to the server with every request as a 'X-XSRF-TOKEN' header.</p>
<p dir="auto">We are going to make this easier in Mango 3.0 by implementing token authentication which will not require CSRF protection.</p>
]]></description><link>https://forum.mango-os.com/post/14043</link><guid isPermaLink="true">https://forum.mango-os.com/post/14043</guid><dc:creator><![CDATA[Jared Wiltshire]]></dc:creator><pubDate>Mon, 06 Mar 2017 16:51:50 GMT</pubDate></item><item><title><![CDATA[Reply to CRUD for data sources on Mon, 06 Mar 2017 16:50:36 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/gary" aria-label="Profile: gary">@<bdi>gary</bdi></a> said in <a href="/forum/post/14040">CRUD for data sources</a>:</p>
<p dir="auto">'x-xsrf-token: ' . $xsrf_token</p>
<p dir="auto">That gives me a status 400 with the following message:</p>
<p dir="auto">{"message":"Unexpected character ('-' (code 45)) in numeric value: expected digit (0-9) to follow minus sign, for valid numeric value\n at [Source: java.io.PushbackInputStream@2f3c2d0; line: 1, column: 3]","stackTrace":"com.fasterxml.jackson.core.JsonParser._constructError(JsonParser.java:1419)\ncom.fasterxml.jackson.core.base.ParserMinimalBase._reportError(ParserMinimalBase.java:508)\ncom.fasterxml.jackson.core.base.ParserBase.reportUnexpectedNumberChar(ParserBase.java:939)\ncom.fasterxml.jackson.core.json.UTF8StreamJsonParser._handleInvalidNumberStart(UTF8StreamJsonParser.java:2487)\ncom.fasterxml.jackson.core.json.UTF8StreamJsonParser._parseNegNumber(UTF8StreamJsonParser.java:1245)\ncom.fasterxml.jackson.core.json.UTF8StreamJsonParser._nextTokenNotInObject(UTF8StreamJsonParser.java:777)\ncom.fasterxml.jackson.core.json.UTF8StreamJsonParser.nextToken(UTF8StreamJsonParser.java:690)\ncom.fasterxml.jackson.databind.ObjectMapper._initForReading(ObjectMapper.java:3090)\ncom.fasterxml.jackson.databind.ObjectMapper._readMapAndClose(ObjectMapper.java:3036)\ncom.fasterxml.jackson.databind.ObjectMapper.readValue(ObjectMapper.java:2206)\norg.springframework.http.converter.json.AbstractJackson2HttpMessageConverter.readJavaType(AbstractJackson2HttpMessageConverter.java:221)\norg.springframework.http.converter.json.AbstractJackson2HttpMessageConverter.read(AbstractJackson2HttpMessageConverter.java:208)\norg.springframework.web.servlet.mvc.method.annotation.AbstractMessageConverterMethodArgumentResolver.readWithMessageConverters(AbstractMessageConverterMethodArgumentResolver.java:197)\norg.springframework.web.servlet.mvc.method.annotation.RequestResponseBodyMethodProcessor.readWithMessageConverters(RequestResponseBodyMethodProcessor.java:147)\norg.springframework.web.servlet.mvc.method.annotation.RequestResponseBodyMethodProcessor.resolveArgument(RequestResponseBodyMethodProcessor.java:125)\norg.springframework.web.method.support.HandlerMethodArgumentResolverComposite.resolveArgument(HandlerMethodArgumentResolverComposite.java:78)\norg.springframework.web.method.support.InvocableHandlerMethod.getMethodArgumentValues(InvocableHandlerMethod.java:162)\norg.springframework.web.method.support.InvocableHandlerMethod.invokeForRequest(InvocableHandlerMethod.java:129)\norg.springframework.web.servlet.mvc.method.annotation.ServletInvocableHandlerMethod.invokeAndHandle(ServletInvocableHandlerMethod.java:110)\norg.springframework.web.servlet.mvc.method.annotation.RequestMappingHandlerAdapter.invokeHandlerMethod(RequestMappingHandlerAdapter.java:806)\norg.springframework.web.servlet.mvc.method.annotation.RequestMappingHandlerAdapter.handleInternal(RequestMappingHandlerAdapter.java:729)\norg.springframework.web.servlet.mvc.method.AbstractHandlerMethodAdapter.handle(AbstractHandlerMethodAdapter.java:85)\norg.springframework.web.servlet.DispatcherServlet.doDispatch(DispatcherServlet.java:959)\norg.springframework.web.servlet.DispatcherServlet.doService(DispatcherServlet.java:893)\norg.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:970)\norg.springframework.web.servlet.FrameworkServlet.doPost(FrameworkServlet.java:872)\njavax.servlet.http.HttpServlet.service(HttpServlet.java:707)\norg.springframework.web.servlet.FrameworkServlet.service(FrameworkServlet.java:846)\njavax.servlet.http.HttpServlet.service(HttpServlet.java:790)\norg.eclipse.jetty.servlet.ServletHolder.handle(ServletHolder.java:845)\norg.eclipse.jetty.servlet.ServletHandler$CachedChain.doFilter(ServletHandler.java:1689)\norg.eclipse.jetty.servlets.GzipFilter.doFilter(GzipFilter.java:51)\norg.eclipse.jetty.servlet.ServletHandler$CachedChain.doFilter(ServletHandler.java:1676)\norg.springframework.web.filter.CharacterEncodingFilter.doFilterInternal(CharacterEncodingFilter.java:85)\norg.springframework.web.filter.OncePerRequestFilter.doFilter(OncePerRequestFilter.java:107)\norg.eclipse.jetty.servlet.ServletHandler$CachedChain.doFilter(ServletHandler.java:1676)\norg.springframework.web.filter.ShallowEtagHeaderFilter.doFilterInternal(ShallowEtagHeaderFilter.java:87)\ncom.serotonin.m2m2.web.filter.MangoShallowEtagHeaderFilter.doFilterInternal(MangoShallowEtagHeaderFilter.java:47)\norg.springframework.web.filter.OncePerRequestFilter.doFilter(OncePerRequestFilter.java:107)\norg.eclipse.jetty.servlet.ServletHandler$CachedChain.doFilter(ServletHandler.java:1676)\norg.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:317)\norg.springframework.security.web.access.intercept.FilterSecurityInterceptor.invoke(FilterSecurityInterceptor.java:127)\norg.springframework.security.web.access.intercept.FilterSecurityInterceptor.doFilter(FilterSecurityInterceptor.java:91)\norg.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:331)\norg.springframework.security.web.access.ExceptionTranslationFilter.doFilter(ExceptionTranslationFilter.java:115)\norg.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:331)\norg.springframework.security.web.session.SessionManagementFilter.doFilter(SessionManagementFilter.java:137)\norg.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:331)\norg.springframework.security.web.authentication.AnonymousAuthenticationFilter.doFilter(AnonymousAuthenticationFilter.java:111)\norg.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:331)\norg.springframework.security.web.servletapi.SecurityContextHolderAwareRequestFilter.doFilter(SecurityContextHolderAwareRequestFilter.java:169)\norg.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:331)\norg.springframework.security.web.savedrequest.RequestCacheAwareFilter.doFilter(RequestCacheAwareFilter.java:63)\norg.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:331)\norg.springframework.security.web.authentication.logout.LogoutFilter.doFilter(LogoutFilter.java:121)\norg.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:331)\ncom.serotonin.m2m2.web.mvc.spring.security.CsrfHeaderFilter.doFilterInternal(CsrfHeaderFilter.java:41)\norg.springframework.web.filter.OncePerRequestFilter.doFilter(OncePerRequestFilter.java:107)\norg.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:331)\norg.springframework.security.web.csrf.CsrfFilter.doFilterInternal(CsrfFilter.java:124)\norg.springframework.web.filter.OncePerRequestFilter.doFilter(OncePerRequestFilter.java:107)\norg.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:331)\norg.springframework.security.web.header.HeaderWriterFilter.doFilterInternal(HeaderWriterFilter.java:66)\norg.springframework.web.filter.OncePerRequestFilter.doFilter(OncePerRequestFilter.java:107)\norg.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:331)\norg.springframework.security.web.context.SecurityContextPersistenceFilter.doFilter(SecurityContextPersistenceFilter.java:105)\norg.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:331)\norg.springframework.security.web.context.request.async.WebAsyncManagerIntegrationFilter.doFilterInternal(WebAsyncManagerIntegrationFilter.java:56)\norg.springframework.web.filter.OncePerRequestFilter.doFilter(OncePerRequestFilter.java:107)\norg.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:331)\norg.springframework.security.web.FilterChainProxy.doFilterInternal(FilterChainProxy.java:214)\norg.springframework.security.web.FilterChainProxy.doFilter(FilterChainProxy.java:177)\norg.springframework.web.filter.DelegatingFilterProxy.invokeDelegate(DelegatingFilterProxy.java:346)\norg.springframework.web.filter.DelegatingFilterProxy.doFilter(DelegatingFilterProxy.java:262)\norg.eclipse.jetty.servlet.ServletHandler$CachedChain.doFilter(ServletHandler.java:1668)\norg.eclipse.jetty.servlet.ServletHandler.doHandle(ServletHandler.java:581)\norg.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:143)\norg.eclipse.jetty.security.SecurityHandler.handle(SecurityHandler.java:548)\norg.eclipse.jetty.server.session.SessionHandler.doHandle(SessionHandler.java:226)\norg.eclipse.jetty.server.handler.ContextHandler.doHandle(ContextHandler.java:1180)\norg.eclipse.jetty.servlet.ServletHandler.doScope(ServletHandler.java:511)\norg.eclipse.jetty.server.session.SessionHandler.doScope(SessionHandler.java:185)\norg.eclipse.jetty.server.handler.ContextHandler.doScope(ContextHandler.java:1112)\norg.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:141)\norg.eclipse.jetty.server.handler.ContextHandlerCollection.handle(ContextHandlerCollection.java:213)\norg.eclipse.jetty.server.handler.HandlerWrapper.handle(HandlerWrapper.java:134)\norg.eclipse.jetty.server.Server.handle(Server.java:524)\norg.eclipse.jetty.server.HttpChannel.handle(HttpChannel.java:319)\norg.eclipse.jetty.server.HttpConnection.onFillable(HttpConnection.java:253)\norg.eclipse.jetty.io.AbstractConnection$ReadCallback.succeeded(AbstractConnection.java:273)\norg.eclipse.jetty.io.FillInterest.fillable(FillInterest.java:95)\norg.eclipse.jetty.io.SelectChannelEndPoint$2.run(SelectChannelEndPoint.java:93)\norg.eclipse.jetty.util.thread.strategy.ExecuteProduceConsume.executeProduceConsume(ExecuteProduceConsume.java:303)\norg.eclipse.jetty.util.thread.strategy.ExecuteProduceConsume.produceConsume(ExecuteProduceConsume.java:148)\norg.eclipse.jetty.util.thread.strategy.ExecuteProduceConsume.run(ExecuteProduceConsume.java:136)\norg.eclipse.jetty.util.thread.QueuedThreadPool.runJob(QueuedThreadPool.java:671)\norg.eclipse.jetty.util.thread.QueuedThreadPool$2.run(QueuedThreadPool.java:589)\njava.lang.Thread.run(Thread.java:745)\n"}</p>
]]></description><link>https://forum.mango-os.com/post/14042</link><guid isPermaLink="true">https://forum.mango-os.com/post/14042</guid><dc:creator><![CDATA[hrivers]]></dc:creator><pubDate>Mon, 06 Mar 2017 16:50:36 GMT</pubDate></item><item><title><![CDATA[Reply to CRUD for data sources on Mon, 06 Mar 2017 16:16:32 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/hrivers" aria-label="Profile: hrivers">@<bdi>hrivers</bdi></a> In my experience with the Mango API, sometimes you need to include the header 'x-xsrf-token' as well as the cookies.</p>
<p dir="auto">Try this modification:</p>
<pre><code>$headers = array(
'x-xsrf-token: ' . $xsrf_token             //ADDED
<p dir="auto">Gary</p>
]]></description><link>https://forum.mango-os.com/post/14040</link><guid isPermaLink="true">https://forum.mango-os.com/post/14040</guid><dc:creator><![CDATA[gary]]></dc:creator><pubDate>Mon, 06 Mar 2017 16:16:32 GMT</pubDate></item></channel></rss>
