    How to implement metadata?
    5 Posts 2 Posters 2.7k Views 2 Watching
    • T Offline
      tcontrada
      I have a Data point from a MODBUS device that I read on a periodic basis.
      The raw data from the device must be run through a calculation in order to display in the graphical view widget.
      I was trying the Metadata data point and was not able to get it to work.
      my calculation is simple in javascript:
      var my = (p1-640)/16.0;
      return my;
      does not seem to work, meaning the graphical widget does not update.
      What am I missing, is there an example similar to this?
        Hi tcontrada,
        i would have written that as
        return (p1.value - 640)/16.0;
        the "my" would probably be aliasing the variable name for the point to refer to itself, and one should call for the .value property of the context point.
        I do not know what you mean, "does not seem to work, meaning the graphical widget does not update." but I suspect the problem is the same. Check it on the data point details page if you are making a custom dashboard, just so one can more easily know where things are going wrong.
        • T Offline
          tcontrada
          I see, working now....Thanks!
            No problem! Just so you know, these calculations could probably be performed in the modbus point locator, which would probably be more efficient. It's value*multiplier + additive, so
            (value-640)/16 --> value*.0.0625 - 40 would be equivalent, so multiplier=0.0625 additive=-40 but there can be benefits to using a Meta point, if you're wanting to keep the raw values around too for some reason.
            • T Offline
              tcontrada
              OK, cool, I will try that as well...Thanks!
