    How do I selectively delete a large number of points?
    5 Posts 3 Posters 2.5k Views 3 Watching
    • V Offline
      Vlasta
      I need to selectively remove a large portion of data points (~50k points, so doing it manually is not an option).
      I exported all my points as a csv file, and separated ones I want to keep, and ones I want to purge.
      I was hoping I could remove points via csv file import/export, but this does not seem to be possible. What is the best way to do a selective point deletion? Is it possible (and advisable) to delete directly from the database?
      Optionally, since I don't yet have any data associated with these points, could I delete the whole lot, and use csv import to only bring back points I need? If so, how would I delete it?
        Hi Vlasta, you are correct in thinking you could delete everything and then recreate what is desired via the importer, but this would lose point value histories.
        I would do this by massaging your CSV of the points you wish to delete into a list of XIDs and then doing it on the SQL console. So, you have an 'xid' column in your CSV, and if you can get it into the format: ('xid1', 'xid2', .... ) you can do something like this at the SQL console....
        DELETE FROM dataPoints WHERE xid IN ('DP_012345', 'DP_123456', .... 'DP_567890');
          Note that deleting the data points using the SQL console will not delete the point values straight away. However these will be deleted when the data purge occurs, usually nightly.
          • V Offline
            Vlasta
            Thanks, both answers helped a lot.
            Is there a way to make System Settings -> 'Purge now...' remove more than 100000 records per run?
              Unfortunately there is no way.
              You can also do it from the SQL console, try this
              DELETE FROM pointValues WHERE dataPointId NOT IN (SELECT ID FROM dataPoints) LIMIT xxx
