    How to get the time of the last received data for a DataSource?
    12 Posts 4 Posters 7.3k Views 3 Watching
    • V Offline
      v8dave
      I want to create an overview screen on the dashboard that shows the active state of the systems connected to the server.
      What I want to do is show an LED type indicator on the display based on the time from last is more than say 5 mins. This way the operator can see if there is a problem with any unit.
      How do I get this time and how do I calculate if this is more than the 5 mins since the last received data?
        Hi Dave,
        I would use the "GET /v1/point-values/{xid}/latest" endpoint. It has a query parameter for a limit of points to return, so you can use 2. Give it a look in swagger! Then,
        if( result.length < 2 || Math.abs(result[0].timestamp - result[1].timestamp) < 300000)
            ledBlinking = true; //Or unhide or what have you
        V 1 Reply Last reply Reply Quote 0
        • V Offline
          v8dave
          I was wondering how I could do this from the webpage but I think I can use an HTTP getter to poll for this and then set a tag that I can then use on the webpage.
          I'll give this a try and see how it works. I'll report back so others who need to the same will know if this work.s
            You can easily get the timestamp of the last value with
            {{myPoint.time}}
            Maybe check out the examples on /modules/dashboards/web/mdAdmin/#/dashboard/examples/basics/live-values
            • V Offline
              v8dave @phildunlap
              @phildunlap said in How to get the time of the last received data for a DataSource?:
              I tried this in an HTTP RECEIVER but it returns error 403 when I try to parse this in the data point. Testing in the receiver setup works.
              • V Offline
                v8dave @JoelHaggar
                @JoelHaggar said in How to get the time of the last received data for a DataSource?:
                {{myPoint.time}}
                That might work if I could compare this to the current time.
                  I'm not the expert on JavaScript here but that should be really easy to do. One thing you could do is have a virtual data point that updates every minute and compare it to the time of that point. One of the other guys can probably post a code example tomorrow.
                    This will work:
                    <ma-now update-interval="1 SECONDS" output="currentTime"></ma-now>
                    <ma-get-point-value point-xid="YOUR_XID" point="myPoint"></ma-get-point-value>
                    <!-- Show text if there are no recent values -->
                    <span ng-show="(currentTime - myPoint.time) > 300000">No recent value</span>
                    <!-- Switch img src -->
                    <img ng-src="(currentTime - myPoint.time) > 300000 ? 'bad.png' : 'ok.png'">
                    • V Offline
                      v8dave
                      I tried the following but the image doesn't show
                      <ma-get-point-value point-xid="DP_799565" point="mywatchdog"></ma-get-point-value>
                      Data State: - <img ng-src="img/ligthbulb_on.png">
                      <img ng-src="(currentTime - mywatchdog.time > 300000) ? 'img/ligthbulb_off.png' : 'img/ligthbulb_on.png'">
                      I used the first one to make sure the image would show and it does but the line you gave me (last line) shows a missing image
                        Check the position of your brackets in the expression.
                        • V Offline
                          v8dave
                          Same result. No image displayed
                          <img ng-src="(currentTime - mywatchdog.time) > 300000 ? 'img/ligthbulb_off.png' : 'img/ligthbulb_on.png'">
                          • V Offline
                            v8dave
                            I think I got it to work. I won't know until the data starts to come in again. Needed the dual curly brackets :)
                            <img ng-src="{{(currentTime - mywatchdog.time) > 300000 ? 'img/ligthbulb_off.png' : 'img/ligthbulb_on.png'}}">
