    Assigning old timestamp to data point
    12 Posts 3 Posters 8.1k Views 1 Watching
      Hi Bryan,
      Here are a few things that should help you understand the Mango Scripting environment a bit better.
      http://infiniteautomation.com/wiki/doku.php?id=automation:meta_data_points#context_objects
      Script variables are objects. So for example you could do
      return p1.value;
      and this would return the current value of the point. Or you could do:
      return p1.time;
      This would return the current time stamp of the point.
      If you read through the rest of the wiki you'll see all the different properties of the objects
      Also see this section on time values: http://infiniteautomation.com/wiki/doku.php?id=automation:meta_data_points#time_values
      Let me know if this helps
      • Woody BeverleyW Offline
        Woody Beverley
        Hello Bryan,
        I think what you are looking for is this...
        'To explicitly set the timestamp of a value, set the TIMESTAMP context variable before your return statement. The value to which to set this variable must be milliseconds since the epoch (not a native date). For example:
        TIMESTAMP = new Date().getTime();
        return p.value + 1;*
        Here's a Meta Script example. In this example I'm monitoring a binary point named TestUpdatePtvalue that updates every 5 secs. This script returns the value of TestUpdatePtValue on every call but if the value is the same as the last time it uses the same timestamp.
        if (TestUpdatePt.value)
        ReturnValue = true;
        else
        ReturnValue = false;
        if ( ReturnValue == my.value ) {
        if (my.time >0)
           TIMESTAMP = my.time;
        return ReturnValue;
        Now for the bad news, I just discovered that this script won't work in the 2.6.0 beta. We will get that fixed as soon as possible.
        -WoodyB
        • B Offline
          bryanh
          Thank you very much for your replies. The script return p####.time works perfectly,
          Thank you for the script Woody. For now I will move forward with Joel's suggestion but I will keep the script in mind.
          Thank you again
          Bryan
          • B Offline
            bryanh
            I have discovered another issue that needs to be solved.
            The points that I want to get the timestamp for are in a data source that updates every 2500 milliseconds.
            Even if I run the return p####.time script it returns the timestamp of the last update
            Is there a way to freeze the timestamp in the data source?
            Bryan
              Woody Beverley
              Hey Bryan,
              Yeah that's what the script I wrote above kind of does.
              "This script returns the value of TestUpdatePtValue on every call but if the value is the same as the last time it uses the same timestamp."
              -WoodyB
              • B Offline
                bryanh
                Hi Woody,
                Okay. But you mentioned that this script does not work on the current beta version of Mango.
                But once that is updated I will try the new script.
                Bryan
                  Woody Beverley
                  The script above now works in 2.6.0 beta as of build 353
                  -WoodyB
                  • B Offline
                    bryanh
                    I have tried the script but it doesn't work. However if I go in the data point details page for an alarm that is already active it says it become active on aug 10 10:37. Is there a way to export that time to DGLux instead of the current timestamp of the point?
                    • B Offline
                      bryanh
                      Here is a screen shot of the point in question in the point details page:
                      upload-2cc7cc8b-f804-4523-82a3-887fbee503df
                      However if I look at a watch list containing this point it displays the time as now, for example 8:37 am as of writing this
                        DGLux has limited capabilities as far as integrating with alarms and other parts of Mango. Your best path forward is to figure out how to make that script work or why it isn't working. We tested it on Mango 2.5 and it worked. It should work on 2.6 as well but we can take another look and see if the script needs to be modified.
                        • B Offline
                          bryanh
                          Here are some screen shots that might help. First is a watch list containing the point containing the script (Time_Stamp) and the alarm that it is connected to (mal_cp_ol). They have the same time stamp:
                          upload-d4d083ef-48fd-489b-98f8-f5faa56866a2
                          Here is the script. Perhaps I am not using it correctly:
                          upload-8d9c0278-14fc-431d-8370-7bef2b054e7e
