Fetching Datafeed FROM pachube
Hi, I see most of the pachube stuff already written in the HOWTO is on getting data from Mango to Pachube.
How do I get data from pachube into Mango?
I have a pachube API key, entered into the datasource. In data point, I can put the feed ID as a number. The datastream ID, I'm not so sure. Do I put the URL, or just the stream name? And how do I fetch out the current value data point from the other data in that stream?
thanks for any help!
Pachube feeds are (typically) multi-valued, i.e. many values - usually indexed from 0 to n-1 - for a single timestamp. Mango is single valued, so you use the datastream id (the value index) to determine which value in the feed you want for the point.
So for an example, here is the URL:
https://api.pachube.com/v2/feeds/47944/datastreams/YAMBUKWF
The feed ID is: 47944
Data type: Numeric
StreamID is: current_value
Settable: NoIs that correct?
BTW. I'm not actually getting a connection to external data sources at the office, but at home its OK. We have a proxy set up at work under IE-Connection Settings-Lan-Proxy I have to enable. Would that cause a problem for Tomcat or Java and connectivity to the external net?
I can't access the data stream. It asks for a password.
Re proxy, see the HTTP settings on the system settings page.
I guess you need to be logged in to Pachube. Have a look at:
http://pachube.com/feeds/47944?page=13
If I do a http request on https://api.pachube.com/v2/feeds/47944/datastreams/YAMBUKWF
I get returned:
{"at":"2012-05-04T06:45:09.734405Z","max_value":"31.9","min_value":"-0.6","unit":{"symbol":"W","type":"derivedSI","label":"Watt"},"id":"YAMBUKWF","version":"1.0.0","current_value":"6.3"}
The datapoint I'm interested in is current_value
Mango always gets the current value. (It can easily determine things like min and max itself.) Your feed id is 47944, and your data stream id will be YAMBUKWF.
That works now, thanks!
