    No ports shown on NMEA listener properties; want to read from file instead of port
    3 Posts 1 Posters 4.3k Views 1 Watching
      PCM
      The "NMEA listener properties" data source does not list any ports in its pull-down menu.
      I would like to fix that, but even if ports were listed, I need to read from a file instead of a local RS232 port. I set up a named pipe to redirect the serial port from a remote computer to the Mango computer by using mkfifo. I can 'cat' the local file to stdout and view the NMEA stream updating in real time, so I should be able to read that FIFO file rather than /dev/ttyS0. How can I do that? Reading from a file is also a useful way to import old NMEA data into Mango.
      But first, why don't I see any serial ports listed in the NMEA listener data source page?
      Linux 2.6.32-29-generic i686
      Distributor ID: Ubuntu
      Description: Ubuntu 10.04.2 LTS
      Release: 10.04
      Codename: lucid
      $ locate RXTXcomm.jar **
      /usr/lib/jvm/java-6-openjdk/jre/lib/ext/RXTXcomm.jar
      /var/lib/tomcat6/webapps/ROOT/WEB-INF/lib/RXTXcomm.jar
      $ locate librxtxSerial.so **
      /usr/lib/jvm/java-6-openjdk/jre/lib/i386/librxtxSerial.so
      Thanks!
        PCM
        Solution:
        In Debian/Ubuntu the serial ports are in group 'dialout.' However, user tomcat6 is not a member of group dialout, and consequently could not see the ports.
        $ ls -l /dev/ttyS*
        crw-rw---- 1 root dialout 4, 64 2011-03-23 20:42 /dev/ttyS0
        crw-rw---- 1 root dialout 4, 65 2011-03-03 10:28 /dev/ttyS1
        crw-rw---- 1 root dialout 4, 66 2011-03-03 10:28 /dev/ttyS2
        crw-rw---- 1 root dialout 4, 67 2011-03-03 10:28 /dev/ttyS3
        To fix the problem, user tomcat6 must be added to group dialout:
        root@ubuntuserver# usermod -G dialout tomcat6
        Now Tomcat6 can see the serial ports, but Mango will not report them until it is restarted.
        To restart Mango:
        root@ubuntuserver# /etc/init.d/tomcat6 restart
        • Stopping Tomcat servlet engine tomcat6 [ OK ]
        • Starting Tomcat servlet engine tomcat6
        Now Mango shows the serial ports in the pulldown menu
        When I searched for this in the forum, I had searched for 'NMEA.' Once I noticed the same 'missing ports' problem was also on the 'Modbus serial' data source page, I narrowed it to a serial port problem, and searched the forum for 'rxtx' and found out that [url=http://mango.serotoninsoftware.com/forum/posts/list/0/189.page#1362]'a reboot was mandatory,' so I restarted Tomcat.
        [solved]
        It would be useful to have a Mango wiki so that these issues can be organized and updated in a more structured manner than what a forum can support.
