    ReadPropertyMultipleRequest
    3 Posts 2 Posters 4.1k Views 1 Watching
    • R Offline
      robert bouwens
      when reading all properties from an object, then all properties defined will be returned.
      a bit too much.
           * add only defined/implemented properties.
           * @param obj
           * @param results
           * @param pid
           * @param pin
      	private void addProperty(BACnetObject obj, List<Result> results,
      			PropertyIdentifier pid, UnsignedInteger pin) {
      		if (pid.intValue() == PropertyIdentifier.all.intValue()) {
                              // the properties implemented
      			List<PropertyIdentifier> properties = obj.getProperties();
      			for (PropertyIdentifier pd : properties) {
      				addProperty(obj, results, pd, pin);
      		} else if (pid.intValue() == PropertyIdentifier.required.intValue()) {
      			for (PropertyTypeDefinition def : ObjectProperties
      					.getRequiredPropertyTypeDefinitions(obj.getId()
      							.getObjectType()))
      				addProperty(obj, results, def.getPropertyIdentifier(), pin);
      		} else if (pid.intValue() == PropertyIdentifier.optional.intValue()) {
      					.getOptionalPropertyTypeDefinitions(obj.getId()
      							.getObjectType()))
      		} else {
      			// Get the specified property.
      			try {
      				results.add(new Result(pid, pin, obj.getPropertyRequired(pid,
      						pin)));
      			} catch (BACnetServiceException e) {
      				results.add(new Result(pid, pin, new BACnetError(e
      						.getErrorClass(), e.getErrorCode())));
      in the class BACnetObject we add:
           * return all implemented properties
           * @return
          public List<PropertyIdentifier> getProperties()
          	ArrayList<PropertyIdentifier> list = new ArrayList<PropertyIdentifier>();
          	for ( PropertyIdentifier pid : properties.keySet())
          		list.add(pid);
          	return list;
      with this modification only implemented and default properties will be taken into account.
      robert
        The second piece of code is ok, but where should the first go?
