    Mango 4.2.0 Release
    4 Posts 4 Posters 2.1k Views 4 Watching
    • terrypackerT Offline
      terrypacker
      Version 4.2.0
      • Mango is now built for Java 11, it is now a hard requirement to use Java 11 or higher to run Mango
      • Fix bugs in ipv6 network tools to accurately whitelist ipv6 addresses, would previously blacklist all ipv6
      • Fix bugs when importing data points that include event detectors after exceeding the amount of data points allowed by the license
      • Availability to monitor the common pool size inside ForkJoinPool, as an internal point for metrics.
      • Fix bug in data point notify events to more accurately fire the correct event types that control meta points and event detectors
      • Add properties to enable/disable disk usage monitoring for SQL and TSDB directories (internal.monitor.diskUsage.monitorSql and internal.monitor.diskUsage.monitorTsdb)
      • Disable disk usage monitoring for SQL and TSDB directories by default
      • Add property to enable/disable use of OSHI native library for metrics (internal.monitor.enableOperatingSystemInfo)
      • Only get and update the process once when polling OSHI native library
      • Remove system metrics that called getAllStackTraces(): com.serotonin.m2m2.rt.maint.WorkItemMonitor.maxStackHeight and com.serotonin.m2m2.rt.maint.WorkItemMonitor.threadCount
      • Dont allow concurrent polling for metrics in ServerMonitoringService and DiskMonitoringService
      • Fix bug where "sessionCookie.persistPeriodSeconds" setting was ignored
      • Add setup page to configure admin password and locale on first login
      • Move timezone env property use to be before Logging initializes so logging uses this timezone
      • Add comma separated env property for MySQL backups to allow passing options to mysqldump, for large systems use db.mysql.extraDumpArgs=--single-transaction,--skip-lock-tables
      ricardoR 1 Reply Last reply Reply Quote 1
      • ricardoR Offline
        ricardo @terrypacker
        @terrypacker said in Mango 4.2.0 Release:
        Any migration guide from V4b12?
        M 1 Reply Last reply Reply Quote 1
          Malaguena @ricardo
          @ricardo @terrypacker we are also planning to upgrade from v4b12, any recommendation for upgrade?
            @ricardo @Malaguena
            We do not have specific upgrade guides from beta versions, however you should read
            https://docs-v4.mango-os.com/upgrade-to-v4
