    Testing out the new Influx DB Line Protocol Data Source
    3 Posts 2 Posters 959 Views 2 Watching
    • W Offline
      Wingnut2.0
      Hello,
      While testing the data source, the help section indicates the following -
      There are 2 env properties that configure how the Line Protocol endpoint behaves.
      lineProtocol.task.queueWarningSize - Size of line queue at to which raise an event warning of queue growth
      lineProtocol.pointValidation.cacheExpirySeconds - When creating data points Mango will cache the existing points on this data source for performance during validation, this is how long they should live in the cache
      These 2 lines do not exist in the env.properties file. Could you provide an example of what the recommended defaults should be?
      Thank you.
      • terrypackerT Offline
        terrypacker
        The defaults that will be used if no property exists are:
        lineProtocol.task.queueWarningSize: 10000
        lineProtocol.pointValidation.cacheExpirySeconds: 5000
        Basically you will have to experiment with your setup and these would only need to be adjusted when you see performance degradation.
        • W Offline
          Wingnut2.0
          Thank you, Terry.
          While testing, I am using the following input
          [[inputs.win_perf_counters.object]]
          # Processor usage, alternative to native, reports on a per core.
          ObjectName = "Processor"
          Instances = [""]
          Counters = [
          "% Idle Time",
          "% Interrupt Time",
          "% Privileged Time",
          "% User Time",
          "% Processor Time",
          "% DPC Time",
          Measurement = "win_cpu"
          # Set to true to include _Total instance when querying for all (
          IncludeTotal=true
          The message to be sent is the following
          win_cpu,host=LAPTOP,instance=2,objectname=Processor,source=telegraf Percent_DPC_Time=0,Percent_Idle_Time=89.79866790771484,Percent_Interrupt_Time=0,Percent_Privileged_Time=0,Percent_Processor_Time=3.9585533142089844,Percent_User_Time=3.098111152648926 1604960081000000000
          What is making it to Mango ends up looking like this
          Along with some additional errors for points that failed to be created.
          	 'test_Influx': Failed creating point with field key ²—‚œ±þÞÑE€d7ˆF}Ñú¢ªÓU™çœÌâï£ÉŤZ>Mç‹Ów?œýò׳?üã¯gÿŒïß¼Œ&óÅprYžo¯‡ÇÕùɏ‹OÕ¬~`úñ?«ËÅdø¥:ý¹Zü>}>?ùódQÍþ>¼¬óéíì²:]Tãêz6üûÉÙðòsµ˜_|¨&‹‹›j6¯.Oaðí×÷Õe5ú­ººx;š_gWÕÕÆÅ¿Þ.>No'ÍïŸüq6›ÎæMÝ_ùÓ×EµñÄý(V¿?3²oWNÐ@ÒPáÛ¿¨Aœÿ>¼yÅ‹_¦‹áx¹³áõhr}~òÓhÜ€Y5»¬õë|x]zd¶PrvmÊåÍí3¡ƒ˜M/«ù|:kÁý¿Œ¾T§’$T-ƒ‰ßî|{öfuÜÿôç«qµú-¢°cH‚hØú–zÝÌnoŸ because name -> Cannot be longer than 255 characters
          I do have Treat integers as Numeric types checked but seem to keep getting NumberFormatExceptions and Invalid Line Length errors. Can Mango only handle a single value being sent at a time?
          Thank you.
