    Events Table for a Specific Data Source.
    11 Posts 2 Posters 5.7k Views 3 Watching
    • Z Offline
      zenvakil
      Re: How to access active events of data point
      Hey There,
      I was wondering if anyone knew an easy way to make an events table that shows all events only for a specific data source?.
        This is really basic but:
        <ma-point-query query="'eq(dataSourceXid,[DATASOURCE_XID])&sort(deviceName,name)&limit(200)'" points="eventPoints"></ma-point-query>
        <md-table-container>
                 <table md-table>
        <thead md-head >
                      <tr md-row>
                        <th md-column><span>Device name</span></th>
                        <th md-column><span>Point name</span></th>
                        <th md-column><span>Active Events</span></th>
                      </tr>
                    </thead>
        <tbody>
        <tr ng-repeat="pt in eventPoints">
        <td> {{pt.deviceName}} </td><td> {{pt.name}} </td><td><ma-get-point-value point="pt"></ma-get-point-value>  {{pt.activeEvents}} </td>
        </tr>
        </tbody>
        </table>
        </md-table-container>
        Am doing this off the top of my head here so not 100% sure it'll work as I haven't tested it...
        Z 1 Reply Last reply Reply Quote 0
        • Z Offline
          zenvakil @MattFox
          @mattfox said in Events Table for a Specific Data Source.:
          Hey Matt,
          Thanks so much for the help, I've tried what you had there but it doesn't seem to work, I would appreciate a bit more help if you had the time.
          Thanks again :)
            Get rid of the [] around your datasource XID for a start -it needs to be the exact same as your datasource XID.
            2, if still nothing, write into the dashboard designer on the edit view: {{eventPoints}}
            • Z Offline
              zenvakil @MattFox
              @mattfox
              Thanks a lot again Matt,
              Removing the square brackets has helped identify the Data Source, but the active Events of pt still doesn' t seem to be working.
              I've attached images for the events table and the result of {{eventPoints}}.
                Looks like because there are no current active events, hence why it's empty. You have actually set up events for these individual points haven't you?
                • Z Offline
                  zenvakil @MattFox
                  @mattfox
                  Hey Matt,
                  Yeah, there are currently active events on most of those point, they show up on <ma-events-table> method.
                    Ah I see.. looks like this has changed a bit since I've last commented on that thread..
                    Sorry about that!
                    Let's use the events table component... I have no idea how well this will sit in amongst the table I provided! Some styling may be in order...
                    In fact... you may be able to replace my table tds in entirety with just one <td></td> and plonk this in the middle!
                    <ma-events-table single-point="true" point-id="pt.id" limit="5" active-status="'active'"></ma-events-table>
                    Use that in place of the ma-get-point-values, it's all written in the components api information in the dashboard menu.
                    /ui/docs/ng-mango/ma-events-table
                    • Z Offline
                      zenvakil @MattFox
                      @mattfox
                      Thanks Mate,
                      That looks like its worked, it needs a bit of a visual change up, as it shows a new events table for each individual data point, but it looks like thats not too bad.
                        No worries, it might involve CSS to hide unwanted elements.
                        Alternatively...
                        perhaps hacking Jared's events viewer code to display a truncated version of this might be beneficial...
                        I'll consider it since it might be beneficial for my dashboard also....
                        • Z Offline
                          zenvakil
                          Any new ideas for this? I've just come back to the topic so was wondering if anyone had any insights?
