    more than 4 Axes
    8 Posts 2 Posters 2.9k Views 2 Watching
    • D Offline
      dgm
      I have a serial chart with 4 axis, "left", "right", "left-2 ", "right-2 " and I have the corresponding min,max ,axisColor assignments in the valueAxes array. The synchronizeGrid is off, all works fine!
      When I try to add a 5th axis, it doesnt like the "left-4". I have tried searching this forum and the amcharts docs. I must be missing it
        MattFox @dgm
        @dgm There is no left-4 i'm afraid, this can be seen in the code provided by infinite for the mangoUI dashboard, also thanks for scouring the forums first then asking, it prevents doubling up on the same content:
        https://github.com/infiniteautomation/ma-dashboards/blob/main/UI/web-src/ngMango/directives/serialChart.js
         valueAxes: [{
                        position: 'left',
                        axisThickness: 2
                        position: 'right',
                        axisThickness: 2
                        position: 'left',
                        offset: 50,
                        axisThickness: 2
                        position: 'right',
                        offset: 50,
                        axisThickness: 2
        However, from looking at this, perhaps it's not impossible to set your own using the code above as a guide, make your own "left-4" with a value axes option and give it an offset.
        There is a check in the code to map values to their corresponding axes, so I think this is more than feasible for you.
        chart.valueAxes.some(axis => {
                        if (axis.id === opts.valueAxis) {
                            graphAxis = axis;
                            return true;
        See how you go
        • D Offline
          dgm
          Thanks for the help!
          Unfortunately I cant seem to get past the 4 , and i had to go back to using
          series-x-axis="left-2" and etc. to make it work. I was not able to get the additional parameters in the valueAxes array to work.
          as for the check in the code, my javascript skill is there yet.
            First, are you using the individual point-x-series attributes instead of points and values?
            If you are using the latter, input into the page between braces your points variable to see their order:
            {{points}}
            Then from that put them into each series attribute:
            series-1-point="points[0]" series-2-point="points[1]" series-1-values="pointVals['values_'+points[0].xid ]"
            or something to that effect, I can't remember the format of the values output from the ma-point-values directive.
            You'll be able to assign each series to an axis then.
            • D Offline
              dgm
              MattFox,
              this is how I had been doing it( times 4 as I have 4 pens charting)
              series-1-values="point1Values" series-1-point="point1" series-1-type="{{point1ChartType}}" series-1-color="{{point1Color}}" series-1-axis="left"
              ... of course series 3 and 4 used series-3-axis="left-2" and series-4-axis="right-2"
              then, I removed the all the series-x-axis attributes etc. and tried to add the code you suggested from mangoUI dashboard into my valueAxes array.
                use three ` (tilde) each side of your text. It makes it easier to view the markup/code
                You still need to set the series-x-axis values with your valueAxes markup so the code can link the two together.
                • D Offline
                  dgm
                  Thanks MattFox,
                  So, I created a series-5-axis="right-4" . Then added a 5th part to the valueAxes array like so:
                  position: 'right',
                  offset: 100,
                  axisThickness: 2
                  everything checks out!
                    Nicely done, glad I could be of assistance!
