    Adding multiple axes
    4 Posts 3 Posters 2.5k Views 3 Watching
    • D Offline
      dgm
      Hello, im trying to add minimum and maximum for another axis this is my attempt....
      options="{synchronizeGrid: false, valueAxes:[{minimum:0,maximum:100}],valueAxes2:[{minimum:0,maximum:200}] }"
      • I Offline
        iperry
        Hi @dgm
        You are close:
                    options="{
                        valueAxes:[
                            {title: 'Connected', titleColor: '#ff4d4d', minimum: 0, maximum: 1, integersOnly: true, baseValue: 2},
                            {title: '°C', titleColor: '#ff4d4d', minimum: -50, maximum: 50}
        Each axis is an element in the valueAxes array.
        Ian
        • D Offline
          dgm
          Thanks iperry!
          That was a major help. I am a total beginner!
          the max works when changed , but the min stays at zero no matter what i set it to. any ideas?
          also, unless I put axisColor:point1Color followed by color:point1Color chart wont render properly
          options="{synchronizeGrid:false, valueAxes:[{minimum:0,maximum:5000, axisColor:point1Color,color:point1Color},{minimum:0,maximum:5000,axisColor:point2Color,color:point2Color},{minimum:0,maximum:5000,axisColor:point3Color,color:point3Color},{minimum:0,maximum:5000,axisColor:point4Color,color:point4Color}]}"
            You need to add the strictMinMax property, this question has come up a lot in the forums. I suggest you use the search and have a browse with amcharts/serial chart as the search item, you'll gain a lot of experience very quickly I assure you.
            options="{valueAxes: [{
            			unit: '%',
            			unitPosition: right,
            			strictMinMax: true,
            			minimum: 10,
            			maximum: 60,
                                    axisColor: '#00CED1'
            For the graphs themselves if you want individual colours for each datapoint split them up and use series-#- attributes rather than just points and values.
            Enable the api menu item under administration -> edit menu -> Api Docs, turn it on and click save at the top.
            The maSerialChart will be under components.
