    Virtual Serial Client
    28 Posts 3 Posters 28.4k Views 3 Watching
      Agreed, something is definitely amiss here.
      Have you tried sending all of this with the wildcard regex and the hex box unchecked?
      I'm out of thoughts. With the knowledge I have I've tested all that comes to my mind.
      @terrypacker You're up!
      I'm gonna see what you find because I'm at a loss here...
      • terrypackerT Offline
        terrypacker
        @jcaballeroa go ahead and post the JSON export for this data source and its point(s). Also include the virtual serial port export JSON. I will setup a local test and see if I can replicate your problem.
        Also:
        1. What version of Mango are you using?
        2. What is the version of the data source module?
        • J Offline
          jcaballeroa
          @MattFox
          Yes, but the result is the same. No Data in log and no data in Data Point.
          @terrypacker
          I have tried in 2 versions of Mango: 3.5.6 and 3.7.4. Now I am using version 3.7.4
          The version of Data Source Module: 3.7.0
          Then the JSON with the requested information:
          "virtualSerialPorts":[
          "xid":"VSP_Client",
          "address":"localhost",
          "port":9000,
          "portName":"1",
          "type":"SERIAL_SOCKET_BRIDGE",
          "timeout":0
          "dataPoints":[
          "purgePeriod":1,
          "setExtremeLowLimit":-179769313486231570814527423731704356798070567525844996598917476803157260780028538760589558632766878171540458953514382464234321326889464182768467546703537516986049910576551282076245490090389328944075868508455133942304583236903222948165808559332123348274797826204144723168738177180919299881250404026184124858368,
          "dataSourceXid":"DS_e4aa6461-15c2-4f52-8fc8-5deac4ecc66c",
          "discardHighLimit":179769313486231570814527423731704356798070567525844996598917476803157260780028538760589558632766878171540458953514382464234321326889464182768467546703537516986049910576551282076245490090389328944075868508455133942304583236903222948165808559332123348274797826204144723168738177180919299881250404026184124858368,
          "deviceName":"hdfhdh",
          "enabled":true,
          "rollup":"NONE",
          "purgeOverride":false,
          "chartRenderer":{
          "limit":10,
          "type":"TABLE"
          "xid":"DP_97638d3f-6fb2-42dd-bad5-367219b78e98",
          "eventDetectors":[
          "textRenderer":{
          "useUnitAsSuffix":false,
          "type":"PLAIN",
          "suffix":""
          "loggingType":"ON_CHANGE",
          "defaultCacheSize":1,
          "readPermission":"",
          "setPermission":"",
          "tolerance":0,
          "purgeType":"YEARS",
          "plotType":"STEP",
          "intervalLoggingPeriod":1,
          "discardExtremeValues":false,
          "tags":{
          "unit":"",
          "pointLocator":{
          "valueIndex":0,
          "dataType":"ALPHANUMERIC",
          "valueRegex":"(.*)",
          "pointIdentifier":""
          "discardLowLimit":-179769313486231570814527423731704356798070567525844996598917476803157260780028538760589558632766878171540458953514382464234321326889464182768467546703537516986049910576551282076245490090389328944075868508455133942304583236903222948165808559332123348274797826204144723168738177180919299881250404026184124858368,
          "setExtremeHighLimit":179769313486231570814527423731704356798070567525844996598917476803157260780028538760589558632766878171540458953514382464234321326889464182768467546703537516986049910576551282076245490090389328944075868508455133942304583236903222948165808559332123348274797826204144723168738177180919299881250404026184124858368,
          "name":"pyupyp",
          "chartColour":"",
          "simplifyType":"NONE"
          "dataSources":[
          "purgePeriod":1,
          "stopBits":"STOP_BITS_1",
          "parity":"NONE",
          "dataBits":"DATA_BITS_8",
          "type":"SERIAL",
          "flowControlIn":"NONE",
          "enabled":true,
          "logIO":true,
          "xid":"DS_e4aa6461-15c2-4f52-8fc8-5deac4ecc66c",
          "messageRegex":"",
          "hex":false,
          "maxMessageSize":1024,
          "editPermission":"",
          "commPortId":"1",
          "maxHistoricalIOLogs":1,
          "baudRate":9600,
          "retries":1,
          "pointIdentifierIndex":0,
          "ioLogFileSizeMBytes":1,
          "messageTerminator":"",
          "alarmLevels":{
          "POINT_READ_PATTERN_MISMATCH_EVENT":"URGENT",
          "POINT_WRITE_EXCEPTION":"URGENT",
          "DATA_SOURCE_EXCEPTION":"URGENT",
          "POINT_READ_EXCEPTION":"URGENT"
          "flowControlOut":"NONE",
          "useTerminator":false,
          "name":"hdfhdh"
            terrypacker
            Ok I think I've got it figured out. You are trying to do something that isn't supported by that combination of data source and virtual serial port type.
            The Serial Data Source is event driven and will only work with the Serial Server type of virtual port as that is the only one that generates events. The Serial Client must be controlled by a polling data source to read and write out of the socket each poll. We probably could/should implement an event driven approach for this other type of port but I'll leave that for now.
            Stepping back from the problem it seems the reason the queryable setting on the TcpIp data source works is because after it sends a command it reads the response out of the socket. Probably not ideal as it will be sending something out of the port each poll.
            Is there no way to use a Virtual Server type serial port and have the device initiate the connection to a port on the Mango machine?
            • J Offline
              jcaballeroa
              @terrypacker
              Thank you very much for your answer.
              The problem is that there is no way to make the peripheral establish the socket towards Mango. For me it is a black box, which I cannot touch, it is a commercial device that I have acquired. And his way of working is that, he expects the remote device (in this case Mango) to establish a client socket by opening the connection and only then begins to send information through this socket (without the need for any command to be sent for it) . We can discuss whether this method is good or bad, but it is the way it works, and it is not possible to change it unfortunately.
                Use socat then.
                Make it act like a relay!
                One socat service linking your server to a mango serial server!
                If you can't use linux it can be done with a node js app or a c# app.
                • J Offline
                  jcaballeroa
                  Yes, it is a very good idea. I had already thought of something similar, in my case I had thought to use Phyton. So that my python app would open a socket against the peripheral and listen to everything it receives, and then send it to Mango through a Virtual Serial Port configured as Server Port.
                  Thanks!!
                    Anytime, that's what we're (the forum) here for.
