    Script to convert from Hex to Dec
    4 Posts 3 Posters 2.6k Views 3 Watching
    • J Offline
      Jorge Gonzalez
      Hello, the snmp device send the data in hexadecimal format for example: Battery voltage = 12:7D, I want to solve it with a Metadata Source, but I dont have information how I can create a script.
      Please could You Help me with this script and could you share information about how to create scripts???.
      In advance, thanks so much
      Jorge G
      • CraigWebC Offline
        CraigWeb
        Hi Jorge
        you can use parseInt for this:
        return parseInt(p.value, 16)
        • J Offline
          Jorge Gonzalez
          @craigweb said in Script to convert from Hex to Dec:
          Thanks so much Craig, but it didnt work. please let me to explain You:
          the hex data is arriving as 13:32 (it is Hex 1332, so must be in Dec Value=4194)
          With your Script I got the Dec value from just the first number (Hex13 =Dec19)
          this device send a string like 13:30:27:14:01:33:02:6c:02:76.
          then I need to get
          13:32:4194
          27:14=10000
          01:33=307
          02:6c=620
          02:76=630
          After i get the values, then we will need to scale it:
          41950,01=41,95
          (10000
          0.1)-1000=0
          3070.1=30,7
          (620
          0.1)-40=22
          (630*0.1)-40=23
          I understand how to define a script to multiply, but some data need to be multiply and the final result will be minus 40, for example:
          Data 02:76 = Hex630= ((630*0,1)-40)=23
          As you can see im in a problem, please could you support me
          In advance thanks so much
          Jorge G
          • ThomasEinastoT Offline
            ThomasEinasto
            @jorge-gonzalez said in Script to convert from Hex to Dec:
            13:32
            @Jorge-Gonzalez, documentation to solve your problems.
            Firstly see what parseInt does - https://developer.mozilla.org/en-US/docs/Web/JavaScript/Reference/Global_Objects/parseInt
            There you can see that the hexdecimal value has to be in correct format be it with 0x or without. Your string splits 2 bytes in the hexdecimal format by using a colon. You need to remove it. Simply do it by utilizing .replace method on a string before putting it into parseInt. Or if you have a string which contains multiple values utilize .split method on a string and then put the bytes together before putting the value into parseInt.
            Replace method explanation
            https://www.w3schools.com/jsref/jsref_replace.asp
            Split method explanation
            https://www.w3schools.com/jsref/jsref_split.asp
            Following function is following the detailed explanation you provided in the post.
            function stringsplitter (string) {
            var result = {};
            // This contains the bytes of data
            result.arrayofbytes = string.split(':');
            // Get byte count of data inside the string
            result.bytecount = result.arrayofbytes.length;
            // Start at the beginning
            var variablecounter = 0;
            result.hexdata = [];
            result.decimaldata = [];
            // Loop over the array, but taking into account that we have 2 byte data, use try/catch so that function will return if something should fail
            try{
            for (var x = 0;x < result.bytecount / 2;x++){
            result.hexdata[x] = result.arrayofbytes[variablecounter] + result.arrayofbytes[variablecounter+1];
            result.decimaldata[x] = parseInt(result.hexdata[x],16);
            variablecounter += 2;
            }catch(err){
             return err
            // return object with all our data which includes hexdecimal data, decimaldata and byte count inside the string
            return result;
            // Example usage
            var devicestring = '13:30:27:14:01:33:02:6c:02:76';
            var data = stringsplitter(devicestring);
            //get array in hexdecimal and decimal format
            var hexdata = data.hexdata;
            var decimaldata = data.decimaldata;
            // first value in hexdecimal and decimal format
            var firstvaluehex = hexdata[0];
            var firstvaluedecimal = decimaldata[0];
            // Second value in hexdecimal and decimal format
            var secondvaluehex = hexdata[1];
            var secondvaluedecimal = decimaldata[1];
            // Following that your post had used an example with the last value
            var lastvalue = decimaldata[4];
            // Should be 23
            var lastvaluecorrected = lastvalue * 0.1 - 40;
            Thomas
