    Correct way to include a jQuery plugin
    2 Posts 2 Posters 1.2k Views 2 Watching
    • B Offline
      BobDay
      We want to use a jquery plugin (jqSimpleConnect.js) to draw div connector lines; As we don't have access to the angularjs environment in designer per se, is there a preferred way to (1) wrap a jQuery plugin in a directive/component and (2) declare the external js file?
      I believe I read that you do load jQuery in your .app. Thanks - sorry if this has been answered elsewhere - couldn't find it.
      Code FYI:
       * «Copyright 2012 José F. Maldonado»
       * Declare namespace
      jqSimpleConnect = new Object();
       * This member is an auxiliary counter used for generate unique identifiers.
      jqSimpleConnect._idGenerator = 0;
       * This member is an associative array which contains all the document's connections.
      jqSimpleConnect._connections = new Object();
       * Positions a connection, acording to the position of the elements which connects.
       * @param {object} connection A connection object.
      jqSimpleConnect._positionConnection = function(connection) {
          // Calculate the positions of the element's center.
          var posA = connection.elementA.offset();
          posA.left = parseInt(posA.left, 10) + parseInt(connection.elementA.outerWidth()/2, 10);
          posA.top = parseInt(posA.top, 10) + parseInt(connection.elementA.outerHeight()/2, 10);
          var posB = connection.elementB.offset();
          posB.left = parseInt(posB.left, 10) + parseInt(connection.elementB.outerWidth()/2, 10);
          posB.top = parseInt(posB.top, 10) + parseInt(connection.elementB.outerHeight()/2, 10);
          // Get the line's elements.
          var line1 = jQuery('#' + connection.id + '_1');
          var line2 = jQuery('#' + connection.id + '_2');
          var line3 = jQuery('#' + connection.id + '_3');
          // Verify if the elements are aligned in a horizontal or vertical line.
          if(posA.left == posB.left || posA.top == posB.top) {
              // Uses only one line (hide the other two).
              line1.show();
              line2.hide();
              line3.hide();
              // Verify if the line must be vertical or horizonal.
              if(posA.left == posB.left) {
                  // Vertical line.
                  jqSimpleConnect._positionVerticalLine(line1, posA, posB, connection.radius, connection.roundedCorners);
              } else {
                  // Horizontal line.
                  jqSimpleConnect._positionHorizontalLine(line1, posA, posB, connection.radius, connection.roundedCorners);
          } else {
              // Verify if must use two lines or three.
              if(connection.anchorA != connection.anchorB) {
                  // Use two lines (hide the third).
                  line1.show();
                  line2.show();
                  line3.hide();
                  // Check the anchors of the elements.
                  var corner = new Object();
                  if(connection.anchorA == 'vertical') {
                      // Find the corner's position.
                      corner.left = posA.left;
                      corner.top = posB.top;
                      // Draw lines.
                      jqSimpleConnect._positionVerticalLine(line1, posA, corner, connection.radius, connection.roundedCorners);
                      jqSimpleConnect._positionHorizontalLine(line2, posB, corner, connection.radius, connection.roundedCorners);
                  } else {
                      corner.left = posB.left;
                      corner.top = posA.top;
                      // Draw lines.
                      jqSimpleConnect._positionVerticalLine(line1, posB, corner, connection.radius, connection.roundedCorners);
                      jqSimpleConnect._positionHorizontalLine(line2, posA, corner, connection.radius, connection.roundedCorners);
              } else {
                  // Use three lines.
                  line1.show();
                  line2.show();
                  line3.show();
                  // Declare connection points.
                  var corner1 = new Object();
                  var corner2 = new Object();
                  // Find if the middle's line must be vertical o horizontal.
                      // Middle's line must be horizontal.
                      corner1.top = parseInt((posA.top + posB.top)/2, 10);
                      corner2.top = corner1.top;
                      corner1.left = posA.left;
                      corner2.left = posB.left;
                      // Draw lines.
                      jqSimpleConnect._positionVerticalLine(line1, posA, corner1, connection.radius, connection.roundedCorners);
                      jqSimpleConnect._positionVerticalLine(line2, posB, corner2, connection.radius, connection.roundedCorners);
                      jqSimpleConnect._positionHorizontalLine(line3, corner1, corner2, connection.radius, connection.roundedCorners);
                  } else {
                      // Middle's line must be vertical.
                      corner1.left = parseInt((posA.left + posB.left)/2, 10);
                      corner2.left = corner1.left;
                      corner1.top = posA.top;
                      corner2.top = posB.top;
                      // Draw lines.
                      jqSimpleConnect._positionHorizontalLine(line1, posA, corner1, connection.radius, connection.roundedCorners);
                      jqSimpleConnect._positionHorizontalLine(line2, posB, corner2, connection.radius, connection.roundedCorners);
                      jqSimpleConnect._positionVerticalLine(line3, corner1, corner2, connection.radius, connection.roundedCorners);
       * Draws a vertical line, between the two points, by changing the properties of a HTML element.
       *@param {object} jqElement A jQuery object of the HTML element used for represent the line.
       *@param {object} point1 An object with the properties 'left' and 'top' representing the position of the first point.
       *@param {object} point2 An object with the properties 'left' and 'top' representing the position of the second point.
       *@param {integer} radius The line's radius.
       *@param {boolean} roundedCorners A boolean indicating if the corners are going to be round.
      jqSimpleConnect._positionVerticalLine = function(jqElement, point1, point2, radius, roundedCorners) {
          var halfRadius = parseInt(radius/2, 10);
          jqElement.css('left', point1.left - halfRadius);
          jqElement.css('top', ((point1.top > point2.top)? (point2.top - halfRadius) : (point1.top - halfRadius)));
          jqElement.css('width', radius + 'px');
          jqElement.css('height', ((point1.top > point2.top)? (point1.top - point2.top + radius) : (point2.top - point1.top + radius) ) + 'px');
       * Draws a horizontal line, between the two points, by changing the properties of a HTML element.
      jqSimpleConnect._positionHorizontalLine = function(jqElement, point1, point2, radius, roundedCorners) {
          jqElement.css('top', point1.top - halfRadius);
          jqElement.css('left', ((point1.left > point2.left)? (point2.left - halfRadius) : (point1.left - halfRadius)));
          jqElement.css('height', radius + 'px');
          jqElement.css('width', ((point1.left > point2.left)? (point1.left - point2.left + radius) : (point2.left - point1.left + radius) ) + 'px');
       * Draws a connection between two elements.
       * @param {object} elementA A CSS selector or a jQuery's object for select the first element.
       * @param {object} elementB A CSS selector or a jQuery's object for select the second element.
       * @param {object} options An associative array with the properties 'color' (which defines the color of the connection), 'radius' (the width of the
       * connection), 'roundedCorners' (a boolean indicating if the corners must be round), 'anchorA' (the anchor type of the first element, which can be
       * 'horizontal' or 'vertical') and 'anchorB' (the anchor type of second element).
       * @returns {string} The connection identifier or 'null' if the connection could not be draw.
      jqSimpleConnect.connect = function(elementA, elementB, options) {
          // Verify if the element's selector are ok.
          if(elementA == null || jQuery(elementA).length == 0 ||
             elementB == null || jQuery(elementB).length == 0) {
             return null;
          elementA = jQuery(elementA);
          if(elementA.length > 1) elementA = elementA.first();
          elementB = jQuery(elementB);
          if(elementB.length > 1) elementB = elementB.first();
          // Create connection object.
          var connection = new Object();
          connection.id = 'jqSimpleConnect_' + jqSimpleConnect._idGenerator++;
          connection.elementA = elementA;
          connection.elementB = elementB;
          connection.color = (options != null && options.color != null)? options.color + '' : '#808080';
          connection.radius = (options != null && options.radius != null && !isNaN(options.radius))? parseInt(options.radius, 10) : 5;
          connection.anchorA = (options != null && options.anchorA != null && (options.anchorA == 'vertical' || options.anchorA == 'horizontal'))? options.anchorA : 'horizontal';
          connection.anchorB = (options != null && options.anchorB != null && (options.anchorB == 'vertical' || options.anchorB == 'horizontal'))? options.anchorB : 'horizontal';
          connection.roundedCorners = options != null && options.roundedCorners != null && (options.roundedCorners == true || options.roundedCorners == 'true');
          // Add connection to the connection's list.
          jqSimpleConnect._connections[connection.id] = connection;
          // Create HTML elements.
          var div = '<div id="divUniqueIdentifier" class="jqSimpleConnect '+connection.id+'" ' +
                    'style="width:'+connection.radius+'px; ' +
                           'height:'+connection.radius+'px; ' +
                           'background-color:'+connection.color+'; ' +
                           (connection.roundedCorners? 'border-radius:'+parseInt(connection.radius/2,10)+'px; -webkit-border-radius:'+parseInt(connection.radius/2,10)+'px; -moz-border-radius:'+parseInt(connection.radius/2,10)+'px; ' : '') +
                           'position:absolute;"></div>';
          jQuery('body').prepend(div.replace('divUniqueIdentifier', connection.id + '_1'));
          jQuery('body').prepend(div.replace('divUniqueIdentifier', connection.id + '_2'));
          jQuery('body').prepend(div.replace('divUniqueIdentifier', connection.id + '_3'));
          // Position connection.
          jqSimpleConnect._positionConnection(connection);
          // Return result.
          return connection.id;
       * Repaints a connection.
       * @param {string} connectionId The connection identifier.
       * @returns {boolean} 'true' if the operation was done, 'false' if the connection no exists.
      jqSimpleConnect.repaintConnection = function(connectionId) {
          var connection = jqSimpleConnect._connections[connectionId];
          if(connection != null) {
              return true;
          return false;
       * Repaints all the connections.
      jqSimpleConnect.repaintAll = function() {
          for(var key in jqSimpleConnect._connections) {
              jqSimpleConnect._positionConnection(jqSimpleConnect._connections[key]);
       * Removes a connection.
      jqSimpleConnect.removeConnection = function(connectionId) {
          if(jqSimpleConnect._connections[connectionId] != null) {
              // Remove HTML element.
              jQuery('.jqSimpleConnect.'+connectionId).remove();
              // Remove connection data.
              jqSimpleConnect._connections[connectionId] = null;
              delete jqSimpleConnect._connections[connectionId];
              // Return result.
              return true;
          return false;
       * Removes all the connections.
      jqSimpleConnect.removeAll = function() {
          // Remove HTML elements.
          jQuery('.jqSimpleConnect').remove();
          // Clear connections list.
              jqSimpleConnect._connections[key] = null;
              delete jqSimpleConnect._connections[key];
      • G Offline
        gresler_nec
        I know this is old, but I'm working on something similar in SVG. I took a stab at modifying jqSimpleConnect, and it appears to work in a Mango user module. Here's what I did in case @BobDay still needs it or anyone else finds it useful.
        First, I just put a copy of jqSimpleConnect.js in my public filestore, importing it in the define section of my user module. That let me start playing with it in the Chrome dev console until I could get it working. It defaults to putting the lines in the body, which are hidden behind the Mango UI. I tweaked it to use the Mango UI view area where custom pages are displayed and accounted for relative positioning. Finally, I wrapped it in a service.
        I won't assert that this is correct way, but on a simple test page I could successfully recreate the basic jqSimpleConnect example.
        In the user module, reference it in the three locations needed to make it a service.
        define([
            'angular',
            'require',
            './services/simpleConnectService.js',
        function(angular, require, ..., simpleConnectService) {
        'use strict';
        var yourModule = angular.module('yourModule', []);
        yourModule.service('simpleConnect', [simpleConnectService]);
        I didn't bother actually testing directives. I just injected it into a random test component I had, logged it to the console, saved as variable, and played with it interactively from there.
        temp1.connect('#div_a', '#div_b', {radius: 8, color: 'green'});
        Now for the wrapped/modified jQuery. I left comments to show what I changed.
        define([], function() {
        'use strict';
        // SimpleConnectService wraps jqSimpleConnect as an AngularJS service for Mango.
        // There are a few tweaks to make it work with the Mango dashboards, see "NOTE:" comments for modifications.
        function SimpleConnectService() {
            * This Source Code Form is subject to the terms of the Mozilla Public License, v. 2.0. If a copy of the MPL was not distributed with this file, You can obtain one at http://mozilla.org/MPL/2.0/.
             * Declare namespace
            // NOTE: Use the service itself.
            // jqSimpleConnect = new Object();
            let jqSimpleConnect = this;
                // NOTE: Get the position of the Mango UI view for displaying custom pages.
                let uiOffset = jQuery('div.ma-ui-main-view > div[ui-view]').offset();
                let uiPos = jQuery('div.ma-ui-main-view > div[ui-view]').position();
                uiPos.left = parseInt(uiOffset.left) - parseInt(uiPos.left);
                uiPos.top = parseInt(uiOffset.top) - parseInt(uiPos.top);
                // NOTE: Use the UI offset to calculate a relative offset.
                // posA.left = parseInt(posA.left, 10) + parseInt(connection.elementA.outerWidth()/2, 10);
                // posA.top = parseInt(posA.top, 10) + parseInt(connection.elementA.outerHeight()/2, 10);
                posA.left = parseInt(posA.left, 10) - uiPos.left + parseInt(connection.elementA.outerWidth()/2, 10);
                posA.top = parseInt(posA.top, 10) - uiPos.top + parseInt(connection.elementA.outerHeight()/2, 10);
                // posB.left = parseInt(posB.left, 10) + parseInt(connection.elementB.outerWidth()/2, 10);
                // posB.top = parseInt(posB.top, 10) + parseInt(connection.elementB.outerHeight()/2, 10);
                posB.left = parseInt(posB.left, 10) - uiPos.left + parseInt(connection.elementB.outerWidth()/2, 10);
                posB.top = parseInt(posB.top, 10) - uiPos.top + parseInt(connection.elementB.outerHeight()/2, 10);
                    line1.show();
                    line2.hide();
                    line3.hide();
                        // Vertical line.
                    } else {
                        // Horizontal line.
                } else {
                        line1.show();
                        line2.show();
                        line3.hide();
                            // Draw lines.
                        } else {
                            // Draw lines.
                    } else {
                        // Use three lines.
                        line1.show();
                        line2.show();
                        line3.show();
                            // Draw lines.
                        } else {
                            // Draw lines.
                // NOTE: Use length instead of size(). AngularJS/Mango's jQuery doesn't have size.
                // if(elementA == null || jQuery(elementA).size() == 0 ||
                //    elementB == null || jQuery(elementB).size() == 0) {
                //    return null;
                    // NOTE: Yell at me when I make a typo. Remove when it's working, or make this more useful.
                    console.warn('failed to locate elements');
                return null;
                // NOTE: Use length instead of size() here too.
                // if(elementA.size() > 1) elementA = elementA.first();
                // if(elementB.size() > 1) elementB = elementB.first();
                connection.click = (options != null && options.click != null)? options.click : null;
                connection.mouseover = (options != null && options.mouseover != null)? options.mouseover : null;
                connection.mouseout = (options != null && options.mouseout != null)? options.mouseout : null;
                // NOTE: 'body' will place elements behind the page. Instead of messing with z-index, use the Mango UI view.
                // jQuery('body').prepend(div.replace('divUniqueIdentifier', connection.id + '_1'));
                // jQuery('body').prepend(div.replace('divUniqueIdentifier', connection.id + '_2'));
                // jQuery('body').prepend(div.replace('divUniqueIdentifier', connection.id + '_3'));
                jQuery('div.ma-ui-main-view > div[ui-view]').prepend(div.replace('divUniqueIdentifier', connection.id + '_1'));
                jQuery('div.ma-ui-main-view > div[ui-view]').prepend(div.replace('divUniqueIdentifier', connection.id + '_2'));
                jQuery('div.ma-ui-main-view > div[ui-view]').prepend(div.replace('divUniqueIdentifier', connection.id + '_3'));
                jQuery("."+connection.id).click(function() {
                    if(typeof connection.click == "function") {
                        connection.click(connection);
                }).on("mouseover", function() {
                    if(typeof connection.mouseover == "function") {
                        connection.mouseover(connection);
                }).on("mouseout", function() {
                    if(typeof connection.mouseout == "function") {
                        connection.mouseout(connection);
                // Return result.
                    return true;
                return false;
                    // Return result.
                    return true;
                return false;
        // End of jqSimpleConnect.
        } return SimpleConnectService;
